Question about Whirlpool AKZ159IX Oven
  • 248 Answers
This code is usually an oven sensor that is telling the control that the oven is too hot, This is why the fan stays on. Try replacing oven sensor. This is the steel rod on inside oven in back wall at top left or right. Even though you can usually unscrew from front, it often won't come out far enough to unplug it from harness. If it does, be sure you get plug back through both walls of oven, or it will melt. Use end of small screwdriver stuck in the connector to guide through back wall. If doesn't come out you mist pull oven out if wall and access from rear.
Posted on Nov 20, 2007
0 characters
3 Points
My oven is showing f3 once its preheated and i set the timer it keeps beeping till i shut if off...what do i do??
That F-3 is a bad oven control or a bad sensor or both. 81aa179.jpgTo verify a bad sensor unplug the quick connect and check for continuity (bad if open)
Check for continuity between each wire and ground. If the sensor is grounded it is bad
Mar 22, 2010 | Ovens
F3 keeps showing up
Hi There
First of i want to wish you a merry x-mass i sending you this to read.
F3 Shorted oven temperature sensor Replace oven temperature sensorhope this helps and ty for writing to fix ya.
Best Regards Richard
Dec 24, 2009 | Ovens
Jenn-air SVD48600P oven will not work / F3 error . I recently replace the expense control / clock unit on my oven because it would not heat. This was advice from repair person. Once replaced the over...
Hi jmhostetler9,
This F3 that keeps flashing on your oven is caused by a shorted or open oven temperature sensor (RTD). To fix this problem check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model # ready when you call.
Hope this helps.
Thank you for using FixYa.
Dec 22, 2009 | Jenn-Air JJW8530C Expressions Collection...
Kenmore wall oven keeps showing error codes f5 and f3. Unit will not say on.
oven went into E2 F3 oven code while cooking a chicken and broil burner came on turned off oven but broil burner stayed lit, then had to unplug
Nov 13, 2009 | Kenmore 47702 / 47704 / 47709 Electric...
Kenmore oven showing an F3 and later F5
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Nov 11, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Linking F3 when trying to turn on the oven
While using the self clean feature you burned out the oven temp sensor.
Replace the oven temp sensor.
Do not use self clean on any oven unless you want to replace parts,
Feb 24, 2009 | Kenmore 30172 / 30174 / 30179 Gas Single...
Error codes
Hello raco1
I need your model number to look up the fault code !!!!
You said , you see fault codes, FD F3 and E2 F3 is showing up on display pane
Looks like this may be your problem
F3 - E2 - Oven to hot -Replace oven temperature sensor
Waiting for your response.
When responding send me this whole communication . Not just your answer!
Thank you Huuum.
Oct 03, 2008 | Whirlpool RBD305PD Electric Double Oven
f-3 means the oven temp sensor is bad. the fan wont turn off because it thinks the oven it hot even though its not. replace oven sensor to fix problem
Nov 20, 2007 | Whirlpool AKZ159IX Oven
Whirlpool AKZ159IX Oven Logo
164 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Richard Roth
Richard Roth
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
