Kenmore heavy duty series 70 won't spin - Washing Machines
  • Washing Mach... Master
  • 1,606 Answers
Will it drain ? IF wont drain either , then the lid switch is bad . (The piece on the washer where the lid actuator goes into the washer top ) . If it will drain , then the motor/trans coupling is bad , if it will not agitate/spin .
Posted on Jul 22, 2009
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Kenmore heavy duty 70 series model 110-8237012
probably your drain pump leaking it has a seal right where it attaches to motor,,,,mine is leaking there but haven't replaced it yet! lol
Feb 27, 2010 | Kenmore Washing Machines
Kenmore washer won't spin older 70 series heavy duty
2 most common problems is if it will not even make a sound the lid switch is broken or if sound and no spinning the the motor drive coupler 285753 is the part
Aug 23, 2009 | Kenmore Washing Machines
Dryer wont start.
can you hear the motor or does the unit humm or vibrate when it is turned on
if yes then have a look at the belt
if not it's time sor a service call
Aug 04, 2009 | Kenmore 700 6972 Dryer
Help with Kenmore washer 70 Series
I called a repair man. The machine, it turns out is gear driven, and all the gears were shot.
May 27, 2009 | Kenmore Washing Machines
Washer will not empyy water or spin or wash on any cycle
something caught in drain pump, clamp hoses and remove pump inspect repair or replace.
Apr 04, 2009 | Kenmore 22422 Top Load Washer
Kenmore 82372110 70 series heavy duty plus won't spin
If it drains and won't spin you have to replace the direct drive coupling.
Feb 25, 2009 | Kenmore Washing Machines
Slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
Dec 30, 2008 | Kenmore 22422 Top Load Washer
Kenmore 70 series Agitation and Spin Cycyle clicking
Sounds like you have a broken motor coupler. Not expensive. #13 on the diagram. Part # 285753, dave www.washermd.com
Dec 12, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
445 people viewed this question
Top Washing Machines Experts
