Question about Intel DG965WH Motherboard
Motherboard and ram..
Hello there,
I am just wondering can you put a DDR2 1gb 800 ram in a motherboard that can only take 533 as a max?
Many thanks.
  • 165 Answers
DG965WH Board works well with 533 RAM, but is very finicky about 800, if you use 800, use only what is recomended.
I used kingston KVR533D2N4K2/2G with good luck on 4 motherboards.
You can try it, but watch for crashes and stabilty issues, if it has issues, remove it.
Posted on Mar 31, 2008
I have the same MB, and I'm running the two Kingston /1G sticks with no problems at 800 Mhz. I have heard though, that WinXP will only recognize up to 4 GB, even though the board allows for 8 GB at 667 Mhz or whatever. My thought is, can I load 8 GB at 800 Mhz? why can only 4 GB at 800 Mhz, work, and the additional 4 GB require a slower speed? has anyone run 8 GB at 800 Mhz on the DG965wh?
Posted on Jun 01, 2010
    Problem Solver:
  • 15 Answers
No it is not possble for a motherboard desighned to handle a certain amount of data simultaneosly at the same time , you see the thing is your ram is 800mhz and your motherboard is so much less , if it were possible for your pc to even boot up there would be so many error in the system registry that ur system would crash did this answer your question if yes pls return the favour by confirming
Posted on Nov 21, 2007
Upgrade the motherboaard. cost is less then all the head akes
Posted on Nov 22, 2007
I have motherboard Mercury PVM7P, i installed 2 GB DDR2 RAM 800 MHS but its showing only 448 MB what is the solution for that anybody can solve it, how much maximum RAM can support this motherboard
Hello you can find info here:
http://www.mercury-pc.com/product-detail.php?link=p-mainboards&subtitle=Mainboard&productid=677
The mainboard supports:
2 x 240-pin DDR2 DIMM socket support up to 2 GB DDR2 533
Maximum: 2GB
533 mhz is probably limited speed by the CPU and the FSB settings.
So you have to try with another type of ram module, the 533 module, because 800 mhz is probably to fast for this mainboard.
Good luck
Aug 22, 2013 | Mercury Computers & Internet
I am using D102GGC2 Desktop board with Intel Pentium D Processor 2.8GHz and using 512MB DDR2 PC-533 RAM. Nw I want to upgrade to 2GB and decided to purchase 2 * 1GB DDR2 PC-667 RAM. Will it be compati
Hello here is the homepage:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Third-Party+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D102GGC2
You can only add 1gb per slot Because the mb does not supports a bigger module.
This ram type does come as 1 gb module.
The 667 mhz and 800 mhz is the Mhz speed for the ram module.
Your mainboard supports this but it will only run the current front side bus speed as the mainboard supports.
This means that the new ram will only run 533/400 mhz as the mb supports.
Hope this was helpfull
Nov 23, 2012 | Intel D102GGC2 Motherboard
Hello Sir, I had 512 MB 533 MHz DDR2 RAM(Dynet). Now I have bought 1 GB 667 MHz DDR2 RAM(Dynet). My system has 2 slots. In one slot, I have 512 MB RAM and in another slot, I installed 1 GB RAM that I have...
The Intel D102GGC2 uses a Dual Channel Memory Architecture meaning that both slots need to be running at the same speeds. I would suggest getting another 667 MHz RAM card and installing it along side your current one, just as I reminder this motherboard only supports 2GB RAM Max so don't get one that is above 1GB.
Mar 28, 2011 | Intel D102GGC2 Motherboard
What is the max dual channel ram i can put iin my msi 865pe neo2 motherboard.
Hi merlin_65,
Regardin your question:
• Supports four unbuffered DIMM of 2.5V DDR DRAM.
• Supports up to 4GB memory size without ECC.
• Supports Dual channel DDR266/333/400/433/466/500/533 MHz and up. (DDR433/466/500/533 are overclocking spec).
Hope this helps.
Feb 22, 2011 | MSI : 865PE Neo2 (Platinum Edition)...
I want to upgrade my from 512 to 2GB RAM. Pls let me know which brand RAM and speed will suport to upgrade the same. my motherboard is P5RD2-VM, with intel pentium D 820 processor. pls guide me on the...
Your Motherboard will support:
2 x 240-pin DIMM's (4GB Max)
Unbuffered
non-ECC
667/533/400 MHz DDR2
You should be pretty safe with any main brand name of memory from your local computer shop.
Below is a list of ASUS TESTED and Qualifed Vendor RAM.
Jan 02, 2011 | ASUS P5RD2-VM Motherboard
Which type of ram is supported by msi k9mm-v motherboard
• Supports Dual DDR2 533/667/800
- 2 DDR2 DIMMs (240pin / 1.8V)
- Supports a maximum memory size up to 2GB.
Oct 28, 2010 | MSI K9MM-V Motherboard
DDR2 RAM ENQUIRY
Dear Sir
*********** Board is :Foxconn P4M800P7MA-RS2
Max Supported RAM : 2GB DDR2
Supported RAM speed: 533 MHz • 400 MHz • 333 MHz • 266 MHz. I think it deffinately solves your problem.If you have any problem post your comment with more information.
Good luck
thank you for choosing Fixya
MPN P4M800P7MA-RS2
Supported RAM speeds 533 MHz • 400 MHz • 333 MHz • 266 MHz
Aug 20, 2009 | Foxconn P4M800P7MA-RS2 Motherboard
Asus P5VDC-MX question about ram .
Hi
You can add one more 1GB ram module.
Max Supported RAM 2 GB Memory Type DDR2Supported RAM Speeds 400 MHz · 266 MHz · 533 MHz · 333 MHz
Jul 06, 2009 | ASUS P5VDC-MX Motherboard
Hello! can i use two 1GB DDR2-800 ram in my motherboard INTEL D102GGC2
Your motherboard takes 533 or 400 DDR2 SDRAM Non-ECC DIMMs.
If your memory is DDR2 Non-ECC it will fit but only work at 533.
Jun 17, 2009 | Intel D102GGC2 Motherboard
RAM capacity & Soundcard Driver can not be installed
this is the ram specs.
Max Supported RAM2 GB
Memory TypeDDR2 SDRAM Supported RAM Speeds400 MHz · 533 MHz what sound card do you have ?
Apr 01, 2009 | ASUS P5GC-MX/1333 Motherboard
Intel DG965WH Motherboard Logo
134 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
