Cooktops Logo
j
john paul Posted on Feb 15, 2017
My bosch induction hob gives these error codes 9p3 it wont switch on although there is power?
1helpful
Bosch induction not working
Very specialised high tech tops need engineers to fix. It is likely to be the power board.
https://www.google.com/search?q=Schott+Ceran+stove+top+with+5+induction+hobs+no+power
2answers
My Hotpoint induction hob is flashing error F14. What do I do too rectify this please?
Error F14 on a Hotpoint induction hob typically indicates a problem with the touch control panel. Here are a few things you can try to fix this error:
  1. Disconnect the power supply to the hob for a few minutes, then reconnect it and see if the error persists.
  2. Try cleaning the touch control panel with a soft, dry cloth to remove any dirt or grime that may be causing the error.
  3. If the problem persists, you may need to reset the touch control panel. To do this, you will need to locate the reset button, which is usually located underneath the hob or inside the control panel. Press and hold the reset button for a few seconds, then release it and see if the error persists.
If these steps don't fix the problem, it's possible that the touch control panel is faulty and will need to be replaced. You may need to contact a professional for this repair.
I hope this helps! Let me know if you have any other questions.
Jan 06, 2023 • Cooktops
2helpful
Belling Induction hob flashing E6
An E6 error code on a Belling induction hob typically indicates an issue with the power supply or the circuit board that controls the back two rings. Here are a few steps you can take to troubleshoot the issue:
  1. Reset the hob: Try turning off the power to the hob for a few minutes and then turning it back on. This can sometimes reset the circuit board and clear the error code.
  2. Check the power supply: Make sure the hob is receiving a stable and adequate power supply. Check the circuit breaker or fuse for the hob to ensure it is not tripped or blown.
  3. Check the wiring: Inspect the wiring and connections for the back two rings to ensure they are not loose or damaged. Tighten any loose connections or replace any damaged wiring.
  4. Contact a professional: If the issue persists, it may be a problem with the circuit board or control module. In this case, it's best to contact a professional technician or the manufacturer for assistance with repairs or replacement parts.
I hope this helps you resolve the issue with your Belling induction
What does the error code E6 on St George 5536440 induction hob indicate?
Could be a power fault. But only the service manual gives the Rea reason. You also need the manual if you want to solve the problem
Aug 02, 2018 • Cooktops
I have a Bosch Schott Ceran Induction Hob model number ********** and need the manual. Where do I get one please
Try to do a search on the Internet, something like: Manual Bosch + your model number. I have usually had good luck finding a free download. Sometimes there are downloads also available directly on the manufacturer's website as well.
Hotpoint induction hob wont turn on
Check power supply at socket or meter box. Make sure that the circuit breaker hasn't tripped. Also, induction cooktops wont heat without induction cookware. They must be steel. Glass cookware wont work on an induction cooktop.
Jan 03, 2015 • Cooktops
7helpful
3answers
Miele KM5753 Induction Cooktop - Error 30
I have a KM5753 with FE31 and it remains after a breaker 1 minute re-set as per instruction booklet - anyone seen that one?
Mar 01, 2008 • Cooktops
Top Bosch Cooktops Experts
Paul Carew
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a Bosch Cooktop Expert? Answer questions, earn points and help others
