Question about Garden
I need to adjust the clutch control on an Allen Model T.S. motor scythe. Can you help me with how to do it please?
  • 3,037 Answers
Hi, yes I can help, first I would like to supply you with a manual which should help with this and any further help that you need. Just click on the following website link
http://itisthis.com/Allen_Scythe_pages/Allen_Manual.pdf
Please see page 12 of the above manual for the servo clutch settings. If you could be more specific with further questions as to how you want to adjust the clutch that would help me better to help you, otherwise let me know how this turns out.
Benjamin
Posted on Jul 22, 2009
I have an older meade LX2000 EMC 10
The main problems encountered with the mechanics of the telescope centre around the mechanical swarf, grease compound, the liberal use of grease and the quality of machining of the main DEC and RA gears.
1. Remove the motors from the telescope. Be careful when removing either motor as there is a compression spring between the motor mounting frame and the worm shaft assembly.
The RA motor is located under the telescope body, removing the 4 screws and 2 Allen bolts will allow the bottom cover to be removed, thereby allowing access the the 2 Allen bolts holding the motor in place. Unplug the motor from the main PCB before removal.
The DEC motor is in the the fork arm containing the clutch and fine DEC adjustment control. (Never to be used with power applied to the scope). Remove the 3 small Allen screws holding the plastic cover plate in place and the DEC clutch knob to allow access to the motor. Remove the RJ45 connector located inside the telescope fork arm. Then remove the motor by unscrewing the 2 Allen bolts holding the motor in place.
2. Remove all grease from the motor worms, especially around the RA motor's magnetic pulse detector and the permanent magnet built into the worm shaft.
3. Remove all grease from the main DEC and RA gears, making sure to clean into the gear teeth.
4. Lightly re-grease with a Molybdenum Disulphide based grease (Castrol MS3 is great for this application if you can get it)
5. Assemble in reverse order. But before doing so, carry out the electrical adjustment above then, (a) relocate the the RA and DEC control PCB's in the vertical plane thereby gaining access to their respective backlash Allen screws. Adjust for 20thou max clearance when in final position. Note:- the DEC adjustment screw has to be replaced for a longer unit complete with a thin bolthead as this adjustment has to be carried out with a spanner....there is no room for an Allen key adjustment here.
6. A drop of Loctite must be applied after adjustment.
7. The final part of the process is to run in the gearing. Apply 12 volts to the motor wires, either at their respective plugs or to the motor direct. Allow to run for 2 to 3 hours in each direction by reversing the battery polarity to bed the teeth engagement. Remember to release the clutches.
Dec 28, 2011 | Optics
How to adjust a clutch on a2005hd fatboy?
Take all the play off clutch lever using adjusting nuts under rubber boot on clutch cable remove derby cover on primary cover use allen wrench to hold push rod while loosing lock nut turn allen wrench clock wise on push rod until it just stops do not apply pressure you will bend push rod.then turn counter clock wise about half turn hold with allen wrench tighten lock nut . Adjust nuts on cable until; 1/8 inch play on clutch lever should be good to go .
Mar 23, 2011 | 2005 Harley Davidson FLSTF - FLSTFI Fat...
I need to adjust my clutch cable on a 1994 1200 sportster harley,wont fully engage and hold bike while it is in gear
That is not a difficult task. There is an adjustment on the cable at the front of the frame. This adjustment should be loosened up and the derby cover removed. After removing the derby cover (that is on the Primary on left side of bike) there is an adjustment screw on the clutch. It takes a allen wrench (dont remmember size) and an 11/16 wrench. Loosen the lock nut with the wrench and screw in the allen in about three turns. Then pull clutch lever all the way in and leave it there. Take the allen wrench and turn out the screw while watching the clutch lever when the lever comes all the way out and the screw tightens then turn it back in 1/2 of a turn and hold it with the allen wrench in that position while tightening the lock nut with the wrench. Then go to the cluctch lever and hold the cable tight looking at the gap between the end of the cable and the clutch lever housing there should only be 1/16 to 1/8 inch play there if there is more or less then adjust the cable at the cable adjustment on the front of frame of bike till you get that spec. A quick way to check the cable is use a nickel if it fits tight it is right. I hope this helps you.
Dec 06, 2010 | Harley Davidson XL 1200 C Sportster Custom...
Clutch on 08 HD seems to be slipping around 3000 - 3500 rpm
This is part of 5000 mile service.To adjust follow the cable down till you find a boot (rubber) and slide it up,loosen the jam nut 9/16 and turn adjuster towards the jam nut 1/2.Then remove the derby cover (replace o-ring) loosen jam nut 11/16 and turn in the allen screw until it lightly seats and back off 1/2 to a full turn tighten down jam nut 6-10 ft.lbs. put cover on,go to cable mid-control and adjust till you have a 1/16 to1/8 freeplay at clutch lever (use a nickel) squeeze handle in at least three times to make sure ball and ramp seat Good Luck
Mar 20, 2010 | 2005 Harley Davidson FLHTCUI Electra Glide...
Autohelm 4000 ST fails to drive
CHECK INSIDE
BELT CONDITION
RUNNER BROKEN OFF
CHECK OUTSIDE
CLUTCH LEVER PIN BROKEN ,CLUCH LEVER OUT OF POSITION
BELT TENSION ADJUSTMENT WRONG (REMOVE SMALL COVER PLATE (+- 10mm Dia)ON REAR OF BACKPLATE ,LOOSE SPECIAL NUT ADJUST WITH ALLEN ,TORQUE NUT,PUT COVER BACK
Feb 19, 2010 | Raymarine St 4000 Wheel Drive E12093
Tyres for an Oxford Allen Scythe
Easy, they are 21"x 2/3/4" the solution is to look for motorcycle tyres on ebay you want the modern equivelent which is 80/100 x21" look for motorcross tyres they are perfect for the allen scythe.
Regards
Dec 01, 2009 | Garden
Snapper won't go forward but will back
You're in luck, if your Snapper is of the type with a record player2.gif drive. Let me explain myself. Look under the motor. You should see that the shaft connects to a disc that has a rubber coated drive disc (or tire) under it. Works like this: when you are in the forward speeds, the tire is on one side of the disc. When in reverse, the tire moves to the other side. This means to me that it is neither your clutch or axle. Snapper dealers sell a tool that allows you to adjust the friction of the record (disc) against the drive wheel (tire). You loosen two allen screws on the disc where it mounts to the motor shaft, and the special tool screws into the center of the disc. With the tool installed, you screw down the jack screw to tighten the disc against the drive wheel. You then tighten the allen screws back up and you're done. Sounds too easy, 'eh? There are other variables you'll need to consider, mostly the condition of your drive wheel. The rubber on it will wear over time, so look at it carefully. If it is cracked or damaged, it should be replaced. It's easy to do. What about costs? Good question.... It's been a while, but best I remember, the speciality tool is ~$20. You'll need a long allen wrench to fit (~$2), and maybe the drive tire (~$15). The best news is that the speciality tool lasts virtually forever, and you'll use it again if you keep your Snapper
Hope that you have found this to have been helpful.
Best regards, --W/D-- Please feel free to rate this solution!
Jul 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Wheels off an Allen Scythe?
The wheels are held in place by an allen screw in the centre hub, the square pin which is usually sticking out also needs to be removed. If the centre hub is stuck fast, use a plastic hammer to strike the inside of the wheel to drive it off the axle until you have a gap to get a puller in. The centre hub should be a nice loose fit when you reassemble it and use a decent grease on it.
Apr 25, 2009 | Garden
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
