Question about Whirlpool Duet GHW9150P Front Load Washer
What does code F LD mean? - Whirlpool Duet GHW9150P Front Load Washer
  • 6,784 Answers
Door lock error
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Replace failed component.(usually the door lock mechanism will need to be replaced).
Posted on Jul 22, 2009
  • Whirlpool Master
  • 3,361 Answers
Long Drain. Remove the drain pump filter and clean it out.
2 Suggested Answers
  • 299 Answers
SOURCE: What does the code LD mean?
Ld flashes when the water level does not change after the drain pump is on. ? Is the drain hose or the drain pump clogged? ? Is the drain hose height greater than 96′?
Posted on Apr 27, 2010
Again and again got a error of sc329 .......how to fix
this error code came from the LD unit which means the seconder LD is not synchronized on the machine but try to clean the mirror if it came agin the replace the LD board
Aug 14, 2015 | Gestetner DSm745 Black and White Copier
The machine stopped at 13 minutes to go then showed an LD code. What does this mean?
Is this a machine made by Kenmore?
An LD code n a Kenmore machine means Long Drain.
Check the water inlet hoses for kinks or clogs.
check the filter for coins or other junks.
Make sure the drain hose isn't blocked, restricted or kinked.
Hope this helps.. Good luck! :)
Jun 09, 2011 | Washing Machines
What does Code LD mean? When it is supposed to spin out, It stops and I get a code LD.
LD is a long drain code usually mean something is in the drain line or pump area. Check thes areas first. If nothing blocking them then the pump is going out.
Dec 28, 2010 | Kenmore Oasis HE 27082 Top Load Washer
What does the code Ld mean???
Apr 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Message LD on washer
L D code meanning long drain. lint causing the problem . and restricting the pump inlet .. remove pump and clean out .. ****
Dec 04, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
What does LD mean?
LD means long drain. There is a problem with the draining part of the cycle. You might be over sudsing or the drain hose is too low. Let me know if this helps.
Oct 13, 2009 | Kenmore Elite 45986 Front Load Washer
We have a Kenmore Elite Calypso, it is not washing
"Ld" (Long Drain) flashes
Is the drain hose kinked or clogged?
Press STOP/CANCEL to clear the display.
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
Here is a manual:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0102048.pdf
See page 17.
Sep 15, 2009 | Washing Machines
What does LD and OB mean on my washer
I'm not sure what the codes mean but here is a site that may help with your problem..not sure but do try it if you like..
http://www.repairclinic.com/RepairHelp/RepairHelp.aspx
Apr 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Ld and ob codes
LD code means your pump is cloged with lint or small piece of clothing such as a sock. I had the same code on my washer and sure enough i found my pump cloged with lint from a blanket my wife washed. hope this helps. sorry I cant help on the other code.
Jan 03, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
HELP? ob & ld codes
Ld means long drain you probally have a bad water pump.Those models have a seperate motor for pump, the shaft on the motor is a star type and has probally stripped out the pump.Replace your water pump
Whirlpool Duet GHW9150P Front Load Washer Logo
228 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
