SOURCE: Bobbin Case
I'm having a similar problem today. I took out the bobbin case and when I went to put it back in, the whole system locks up. I've tired cleaning, changing needle taking the metal plate and piece that holds bobbin case out and put it all back in after cleaning. Nothing. My symptom is I can't get a complete stitch, the needle goes down, the whole deal acts like it will work and as soon as the arm of the bobbin case gets to 8 o' clock on the gears, It jams and won't hardly move. I cannot pull the bobbin case out easily after this. Perhaps there is someone out there that can help us!
SOURCE: bobbin case case keeps jamming
I am having somewhat the same problem with the exception that my needle did not break. I've cleaned and oil, but the bobbin case and projection positioned spring is not communicating to allow sewing to continue. The thread keeps jamming and the bobbin raises up the plate. So, what else am I to do?
SOURCE: Anna had this problem with her Pfaff 332 sewing machine, I do too
I believe that the bobbin case holder has become unlatched, for lack of better terminology. I have one of these machines, and my first experience with one was exactly as you are describing. A friends grandmother brought it to me because it kept breaking needles and wouldn't complete a stitch.Put the bed table in the lowered position, leaving the free arm exposed. Remove your needle, presser foot, and bobbin case, leaving the bobbin door open. Next remove the two screws that hold in the feed plate, and remove the feed plate. Looking down into the bobbin area, manually turn the bobbin case holder. There is a small slot in the top of the bobbin case holder, look for it as you turn. A small latch protruding from the bed plate is supposed to be clipped into that slot, and if the latch is still there, you likely will not be able to rotate the holder into place: This is good news, it means nothing is broken. Loosen the three screws (two silver on the top of the bed plate and one black in the area where the feed plate goes) which hold the bed plate in place, but do not remove them. You should be able to lift the bed enough to get the holder into place, and then set the bed back down and tighten the screws. Reassemble everything, throw in a new needle and see how it goes!
SOURCE: bobbin case futura singer sewing machine came out
The opening fits on the right side, toward back. There is the silver ring with the slot in it for the bobbin. That slot is facing the sewer.
SOURCE: Pfaff 2024 bobbin case basket is jammed-even after clean & oil
the jam that happened may have caused the machine to jump time & it would have to be serviced
