Question about Microwave Ovens
I have a St George TO70x oven that started displaying garbled data on its LED screen when, during the Pyrolitic Cleaning cycle, the power was disrupted. I believe it needs resetting. Manual says I need an engineer to do it. Is it something I can do? Paul
  • 3,037 Answers
The temperature limiter relay will not automatically reset after the temperature goes below the set point value which is why you have this problem when the power went out; the operator must manually then either push the ‘reset’ key or a remote reset switch which this oven I don't believe has. If there is a reset button on this limiter depending on which kind it is, then yes you should be able to reset it yourself by removing the back panel and accessing it yourself. Let me know how this turns out.
Benjamin
Posted on Jul 22, 2009
The St george oven buzzing is loudly continuously
I think it would be a good idea to have the unit looked at (or opened and listened to see where it is coming from--the buzz) before this turns from a possible minor issue to a major one.
Dec 17, 2012 | Microwave Ovens
How do you start the self cleaning oven process on a kenmore stove purchased from Sears in 2009?
  1. Empty the Oven
    • Take everything out of the oven. Remove the racks and clean them with soap and water in the kitchen sink. Look for any loose debris such as foil or charred food and remove that as well.
    Oven Cleaning
    • To operate the self cleaning mode, find the switch on the range marked "Clean." The oven door will lock once the cleaning operation has started. Do not open the door until after the self-cleaning process has completed. It will take between two and three hours.
      During the cleaning process, you may see and smell smoke. This is normal because the oven is operating at a higher temperature than when it is cooking. The high temperature is reducing all the organic matter in your oven to ash. You will also sometimes hear popping sounds from the oven that is caused by the expansion of metal under extreme heat. This is normal for a self-cleaning operation.
      After the oven has completed the cleaning cycle, allow it to cool for a couple of hours. Once cool, take a damp dish cloth and remove the ash from the bottom of the oven. Wipe down the interior of the oven door and around the seal. Be careful around the seal so you do not damage it. Replace the racks back in your oven, and the cleaning operation is complete.
    Other Considerations
    • Clean your oven at least once every three months. If your oven gets heavy use, consider cleaning it once a month. Always run the self-cleaning cycle when you are home. Because it uses intense heat, it is best to perform this operation later in the evening or early in the morning.
Aug 10, 2011 | Microwave Ovens
I have a Kenmore over-the-stove microwave oven that is not heating food. Everything else works. I received a message of PF on the keypad. Is there anything I can do before I have to call a repair...
PF - Power Failure - PF error code indicates a power failure during the cycle.
Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 13, 2010 | Kenmore 62702 Microwave Oven
Microwave starts running on it's own
There is a short in the cntrol board. I have seen problems arise like this from mice, spiders and other insects. Power fluctuations can also trick the control into activating. ERIC
Aug 15, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave Toaster Combe
The button may be stuck... try cleaning the display really well.
Oct 26, 2008 | Microwave Ovens
Microwave resets when started
Could you explain what you mean by "resets similar to power cycle after 2 seconds of running"? Do the characters on the display get garbled, or is it like someone just unplugged the oven and plugged it back in? GE had a rash of "underperforming" magnetrons on several models. They would sometimes end up with stirrer damage, bad diodes, waveguide damage, and/or interference which "scrambles the brains" of the unit and makes them reset like they had been unplugged. The usual fix is to replace the magnetron, stirrer and high-voltage diode as a kit, and they used to cover this, but may not any more. Sometimes the unit gets run too long in a failing state and the waveguide and chassis of the oven get damaged. In that case, the oven would have to be replaced. To get the details and see if yours is affected, see this bulletin: http://www.microwavedisplay.com/ge_mw_mag_kit_bulletin.pdf Even if your exact unit is not on the list, you may have this problem. You can contact GE Customer Relations at 1-800-386-1215 and tell them your problem and they will put you in touch with a local authorized servicer. Feel free to post back if you need more info. I appreciate your thoughtful rating of my answer.
Oct 05, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
No power Dacor DCM24SS
I do a lot of work on Dacors / Sharps. Can you describe what you mean by "shutting off"? When it was shutting off before, was it completely dead with no display and no beeps? Was iut shutting off during a cook cycle or just while setting there or what? When it would come back on or start working again, how long did it take to come back, or how did you make it come back on?
Apr 28, 2007 | Dacor DCM24SS Convection Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
