Question about Kenmore Dishwashers
MY KENMORE QUIET GUARD WONT SPRAY WATER -I HAVE TAKEN EVERYTHING THAT I CAN EASILY REMOVE OUT OF THE INSIDE AND DID NOT FIND A CLOG THERE- WHEN I TURN THE DISHWASHER ON IT DRAINS FIRST AND THEN FILLS A LIITLE AND THEN IT DOES NOTHING BUT MAKE A LOUD NOISE
IFIXALL
  • 868 Answers
SOURCE: water sitting in bottom of dishwasher
Are you in Canada, I can't find the info you need if you are. Although I'll try with Whirlpool in the morning for you.
Posted on Jul 15, 2008
SOURCE: Kenmore ultra wash quiet guard 3 dishwasher problem
The sequence of "Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses)" worked for us. Many thanks!
Posted on Oct 14, 2008
SOURCE: Where is the filter on a Kenmore Quiet Guard 2 dishwasher?
not a dumb question,
is the bottom dishes coming out clean? there is a chopper that breaks and will trap food and not clean the top rack.it is not easy to replace.but not impossible.
Posted on Oct 31, 2008
  • 9 Answers
I have a Quiet Guard 4. Same problem so will describe my solution.
1. Remove bottom basket. Remove top basket.
2. Remove bottom washing arm. Unscrew (Gently but firmly) the centre post. Lift arm assembly up and out.
3. Remove overhead conduit. One screw at back, one at top (Philips #2 bit). Rotate whole assembly 45 deg right (Clockwise) and lift off of centre post.
4. Remove centre post (Pull straight up). Remove 4 screws (Star T-20 bit). Lift whole assembly out. Pop off screen and clean.
5. Remove cap over cutter/chopper. There is a single screw at front left (under assembly removed in 4). Remove screw (Star T-15 bit) and cap (Needs some wiggling to free it up). Remove cutter and filter. It is on a spring loaded pin. Pull the cutter blade foreward and then the filter disc straight up. Clean thoroughly as it may be the cause of your problems.
Reassimble. Good luck!
Posted on Jan 02, 2009
SOURCE: Kenmore Ultrawash Quiet Guard 5 making buzzing/grinding noise
I have a very similar dishwasher, with a very similar problem. I fixed it by removing debris from the water evacuator pump located towards the front of the bottom of the machine (the last motor before the drain hose. In my case, grape stems had clogged it up. Once emptied, it purrs once again. NOTE: don't disassemble the motor, just flush it out, there is an o-ring gasket that is a bear to re-install.
Posted on Sep 04, 2009
Kenmore top arm not spinning
sprayers might be plugged. do u have hard water?
Jan 29, 2015 | Kenmore Dishwashers
Kenmore dishwasher top arm not spinning (tried everything I know)
Your problem may be scale. Over time dishwashers are particularly susceptible to accumulated scale as a consequence of their use of high temperatures to clean which causes some water to evaporation (steam) leaving behind the minerals in the water. The scale builds up over time diminishing the size of water pathways and outlets and reducing the flow of water and it can build up in the connections and reduce the ability of spinning elements to turn freely. Treatment with a descaler can clear the problem but it may take several treatments. If the scale is thick it will actually come off in flakes and repeated disassembly and cleanout of the rotating arms & spray heads will be required. Commercially available descalers work well, a common 'home recipe' is vinegar or vinegar & baking soda
Why Isn Your Dishwasher Cleaning Like it Used to
My kenmore quiet guard My partially fills and therefore does not clean. any suggestions
Possibly low water pressure; possibly a clogged inlet screen on the inlet valve; possibly a bad inlet valve (replace it).
Nov 14, 2014 | Kenmore Dishwasher With Ultra Wash And...
Kenmore ultra wash quiet guard standard. Very little pressure coming out of the jets. Doesn't clean the dishes.
sounds like hard water is the problem and may have clogged the jets. clean it out really well and get the dishwasher filtration system from www.dishwasherfilter.com. that will remove the hard minerals and leave your dishes and dishwasher spotless. awesome product and the results are guaranteed.
Jul 08, 2013 | Dishwashers
I have a Kenmore Quiet Guard and it has stopped draining. The drain line is not clogged.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Aug 30, 2010 | Kenmore Dishwashers
My Kenmore quiet guard standard model 587-15152400 is not getting the dishes clean AT ALL. It has hot water, water is draining, have not changed soap. Don't know why?
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
http://www.fixya.com/support/r4817172-dishwasher_spray_arms_not_spinning
heatman101
Aug 22, 2010 | Kenmore Dishwashers
Jun 22, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Spray Arms dont work, dishes dirty after cleaning cycle
Do the spray bars rotate easily? If not, you need to remove the spray bars and clean the insides out (do this even if the spray bars do turn easily.). Also check that where they mount is clean and free of debris.
Check the nozzles and make sure they are not plugged.
Also check that the inlet screen to the pump is not clogged (around the bottom of the unit).
Let me know what you find, and tell me if you can hear water spraying inside the unit during a wash cycle (and do the dishes get wet.).
Feb 01, 2009 | KitchenAid KUDR01TJ Dishwasher
I have the Kenmore Plus Quiet Guard, just wondering about filters as the water is not draining?? Anyone know?
It sounds more like a failed pump.
Does it circulate the water while washing dishes?
You might check the junction where the dishwasher connects to your drain under the sink. Often, they empty into the garbage disposal.  The inside of that junction has a tendency to clog with food (especially grease) and the pump of the dishwasher doesn't produce much pressure, it is more designed for volume.
Jan 08, 2009 | Kenmore 24 in. 17602 / 17604 / 17609...
Top rack not cleaning
Some dishwashers have a telescoping nozzle in the center on the bottom. If this is blocked by a large pot in the middle of the bottom tray, the nozzle will only extend up into the pot, and not be able to spray the entire top rack.
Also, some models have an arm mounted in the top. Check and see if it can spin freely, and if it's nozzles are clogged.
De-clog by soaking the part in vinegar.
Sep 17, 2008 | Kenmore 24 in. 16539 Built-in Dishwasher
Dishwashers Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
