Question about Sharp Office Equipment & Supplies
SHARP AR-BC260. GIVES ME ERROR CODE OF F9-00. WHAT IS THAT ERROR CODE AND HOW DO I CLEAR OR CURE?
    Brigadier General:
  • 8,619 Answers
Hi
Error code F9-00 means printer board problem/printer out of service. This error occurs due to a fault in the main circuit board of the machine. Try a reset first by pressing P then * then C then * then 14 then Start and then CA.
If that doesn't work check that the SCSI cable is connected to the correct port, and that the port is enabled in simulation 24-44, A & B, set the port used to #1, the one not used to #0.
If that doesn't help, you will need to replace the printer board.
Please revert for further assistance.
Thanks
Rylee
Posted on Jul 22, 2009
H5-01 without technician assistance
H5-01 means repeated paper jams on the Sharp photocopiers. Once the paper jam is cleared properly, you need to clear the error condition. Put it in 'Copy' mode. Press on the keypad: Related Groups. Printers, Copiers, Scanners &
Jul 14, 2014 | Sharp AR-BC260 Color Copier
Sharp m165 error h4-00 give solution
Heat roller abnormally low temperature
Check blinking of the heater lamp
with SIM 5-2.
When the lamp blinks normally:
Check the thermistor and the
harness.
Check the MCU PWB thermistor
input circuit.
When the lamp does not light:
Check for heater lamp
disconnection or thermostat
disconnection.
Check the interlock switch.
Check the power supply PWB
and MCU PWB lamp control
circuit.
Clear the trouble with SIM 14.
May 12, 2014 | Sharp AR-BC260 Color Copier
How to fix Sharp Copier AR-5731 Error code
good day, my Sharp AR 5731 showing the message Call for Service . Code : H4-00 can you help me to fixed my problem. thanks and God Bless
Mar 11, 2013 | Sharp AR-BC260 Color Copier
Sharp AR-BC260 shows the network error CE-02
You need the Sharpdesk Software CD and you will have to install it in order for the scanning function to work.
Feb 03, 2010 | Sharp AR-BC260 Color Copier
Printer constantly paused during printing
Is Post Script Key in the Mahcine? (PS must be intalled on the machine)
Do you have the Correct Driver
www.sharpusa.com
Aug 08, 2008 | Sharp AR-BC260 Color Copier
Sharp AR-BC260
I would inspect the fuser unit for abraising on the roller or missing and/or broken pauls.
Jun 06, 2008 | Sharp AR-BC260 Color Copier
Error code h5-01
Yes H5-01 is when it jams in the fuser 5 times in a row, check the fuser section for a jam, the paper jams up in there and does't trigger any sensors, once you have confirmed that its clear reset with sim code 14
May 31, 2008 | Sharp AR-BC260 Color Copier
Sharp ar-bc260
change the transfer belt, and drums, suggest a whole Preventive Maint.. , part broken in tray 1, that is not enough detail..
May 16, 2008 | Sharp AR-BC260 Color Copier
64 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
