Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
The lamps will flicker for a moment and then it will go off
Is there post to be liquid be hinde the lenses
  • 668 Answers
Yes. This Optical Grade Cooling Fluid that cools the face of the CRT and it also helps in focusing the picture. DO NOT take apart the LENS COUPLER and spill the fluid. It is a very nasty Glycol based fluid and could harm you if it is absorbed into you skin or ingested.
Posted on Jul 25, 2009
Can not get any image
1) Check if lamp is still ok. If no light even after POST replace the lamp.
2) If lamp is ok, check if all black or all white or flickering dots. If you see flickering spots chances are your dmd chip is faulty, replace it or send it to service center to replace the chip which will cost you a fortune as dmd chip are expensive.
3) if POST is ok, check your input signal if correct choice, check cable if ok, check setting if correct.
Oct 21, 2015 | Mitsubishi XD206U-G DLP Projector
First when I turn it on it's okay for a few minutes ,then it starts to flicker and shuts off.Three lights are on Standby/Temp/Lamp Temp and Lamp lights are blinking.
Try unplugging the TV. Remove the back panel and vacuum the dust out. Sounds like the unit may be overheating and the thermal shutoff is operating to prevent fire. Be careful not to move the projection lenses out of alignment. It is also a good time to clean those lenses carefully. It will improve your picture a lot.
Jun 10, 2015 | Samsung HL-S6186W 61-Inch DLP HDTV
HP5066 flickering
Return it to the dumpster. It is a lost cause.
May 03, 2017 | Televison & Video
Water in the jack compartment on my 1997 jeep grand cherokee
Hi,empty the boot,check for eney plugs or holes if none,
shut tailgate and get a hose-pipe and shower the car round the top part of the tailgate,quickly wipe off exess wateropen tailgate and see if there has been eney water getting in,if not open tailgate and carfuly so as not to let water go over into the boot turn the hose on to the lamp lenses where the sills are and see if water enter through them if not try be hind the petrol-flap,
my moneys on the tailgate sill.hope this helps
Oct 08, 2013 | 1997 Jeep Grand Cherokee
Change out original bulb now flickering picture, help.
You haven't specified here about have did a lamp time reset after lamp replacement. It should be done. If you wish to know more about how to reset lamp time, http://electronicshelponline.blogspot.com/ check this link. Pull up older posts there. You can get details. Do this, and check it again. If you want any more assistance, be free by commends.
May 27, 2013 | Mitsubishi WD60738
Screen flickers on and off
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jul 01, 2010 | Liquid Video L17LCD2 17" Flat Panel LCD...
Monitor does not want to start up. The screen flickers for a moment and goes black. Usually lights up after switching on and off anything between 10 and 50 times.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Apr 16, 2010 | Acer AL2016W 20" LCD Monitor
Picture keeps flickering after 15 min
if you hear chirping, too, replace the colorwheel. also check the lamp timer. if it's close to 2000hours (or the inside of the lamp is bulging or blackened), replace the lamp. if the lamp is new and the colorwheel doesn't chirp, replace the ballast/power supply.
Nov 17, 2009 | Optoma HD70 DLP Projector
Our Sharp projector Model PG-B10S is Flickering and blurred text? is this problem associated with bulb?
the flickering could be the lamp, but as for the bluring: if it's pixelated, it's resolution. make sure the computer and projector have the same. if it's not pixelated bluring, it's an optical problem. either the lenses are dirty or misaligned.
Jul 01, 2009 | Sharp Projector lamp Projector Lamp
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
71 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
