Question about Sport & Outdoor - Others
My Shakespeare SKP 2000C won't reel in.
The problem I am having with my Shakespeare SKP 2000C is that when I try to reel in, 95% of the time it doesn't reel in. The handle turns but it seems to be that something inside the reel is not catching correctly.
You may need to tighten or fix your drag.
Posted on Nov 26, 2009
  • hxcxe May 12, 2011
    i was having the same problem for the longest time. i dont know if its exactly worth the headache of taking apart, cleaning, and rebuilding, but if youre a bit of a grease monkey, it might be a fun challenge. just look up the schematics. However, if you are mechanically inclined, your better off replacing with a nicer bait caster like an abu garcia (which is pretty much what this reel replicates)
I took mine apart, almost didn't get it back together,,, will try to drag washer , but its in the one way clutch I think,, if you tap on it it will. I took the plastic off the handle covering the nut.. a tap with metal on the nut end will get it going,, but it is not a fix. im calling the company, may send mine back.... sad never worked out of the box.
Posted on May 28, 2013
If you've had it apart. The common mistake is to match the two drag washers. They are sping washers and should face each other. If you don't do this it can lead to not enough drag and sometimes not reelin in. good luck
Posted on Nov 10, 2011
Shakespeare reel diagrams
You might want to check the numbers you provided. I found this site to have a lot of diagrams for the manufacture you provided. Mikes Reel Repair Schematics
Aug 19, 2014 | Shakespeare Agility Spinning Reel 6825
Where can i find reassembly instructions for a shakespeare easy cast 35 reel
The maintence section from the Shakespeare ez-cast reel owner's manual is below. I hope it helps!
You can find the complete owner's manual here: http://s7d5.scene7.com/is/content/purefishing/skp-ownerM-ezCast
Jun 06, 2012 | Sport & Outdoor - Others
My line won't rewind on my Shakespeare Encore reel. After casting, the bail snaps in place, but when I reel in, the line won't reel in. The spool turns with the bail, but doesn't retriev
Your line is on the wrong side of the bail. Rethread the line so its over the bail so that after the cast you flip it up it catches the line and retracts it.
May 05, 2012 | Sport & Outdoor - Others
How to thread a Shakespeare fishing rod and reel
feed the line down through the eyelets on your pole ,now open the bail on your reel tie the line on the spool,and start reeling(keep tension on the line,prevents line from tangling) when i resting mine I only go about two thirds on my spool.
Jun 05, 2010 | Shakespeare Agility Spinning Reel 6825
Shakespeare ?Tidewater? reel
late response here, but it is worth noting that these reels need quite a bit of lure weight to cast easily. two or three oz and it will do very well. i use these for cats and love em. good luck
May 20, 2010 | Shakespeare Agility Spinning Reels
Sport & Outdoor - Others Logo
1,184 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
