Cant find a unlock code to make my pc's mashita dvd-ram sw-9571. able to play dvd's from any region want to make it region 0
    Problem Solver:
  • 15 Answers
Posted on Jul 22, 2009
Unlock telefunken tel9800 dvd/vcr combo region
open tray
enter 0520, then press up, down, left, right (these are the keys around the ok/enter button)
a message will appear on the screen showing current region
press 0 and enter
it should now play any region
hope this helps
Angel
Dec 16, 2009 | Televison & Video
DR 389 DVD player
Try one of these:
1) Press 'setup' on remote control
2) Move down to the 'lock' picture
3) Press '0000000'
4) Select region code as '0'
Or
1) Power on player with no disc in tray
2) Press PAUSE
3) Key in 314159
5) For multi-region, select 0
6) Press PAUSE again
7) Power off player
8) Wait a minute turn it on.
Apr 22, 2009 | Televison & Video
Panasonic SW-9571-CYY Ejects DVD RAM Cartridge.
Hi, I don't know if you ever solved this problem - but I had the same thing on my SW9571CYY. The solution is to replace the small drive belt inside the drive ( It is very thin and doesn't seem up to the job it has to do). Just remove the two screws on the rear, then the seven screws holding the plastic cover with the springs on it (don't worry - everything stays in place). Lift the disk tray out and the little belt is towards the front. I used an old belt from a broken LG GSA-5163D that was lying around. I think it would be difficult to find the correct spare so some people have even used a "O" ring with a slightly smaller diameter than the original belt.
Hope this helps Dwane4444
Jan 30, 2009 | Panasonic DVD BurnerII MULTI Drive...
I need to unlock my LG DZ9811P DVD so i can play all region dvd's
power on
open disc tray
press 0 0 0 on your remote
select region 0
press pause button
press power button to switch off
leave off 30 seconds
should then play all regions
Jan 19, 2009 | LG DR-4912 DVD Recorder
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Need code for durabrand portable dvd player
  3. Press Stop.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
Unlocking Region Codes for NEC NDT 44A
TO UNLOCK NEC NDT-44A
1. Press EJECT
2. Enter 0, 0, 0
3. Enter the region you want (0 = multi-region)
4. Press PAUSE
(I feel like I just won the lottery!)
May 16, 2008 | Televison & Video
Hi I need to unlock my Sanyo DVD player HV-DX350A
HI this works as i have unlocked my own Sanyo HV-DX350A player with it Hope it works for you
Unlock region code for Sanyo HV-DX350A DVD/Video player.
1. Turn on unit
2. Select DVD
3. Open tray
4. Press 0520 then in sequence press arrow up, down, left and right.
5. The region management screen is displayed on your monitor ( Code is displayed on the unit LCD display).
6. Note - Your current EEPROM region code setting is displayed on the screen.
7. Enter desired Region Code ( 0 for multi region).
8. Press PAUSE to exit.
9. Turn power off and turn on again.
If you repeat steps 1 to 4, you can view your new setting.
Feb 29, 2008 | Televison & Video
UNLOCK REGION CODE FOR PHILIPS DVP3140 DVD PLAYER
Hi guys,
I cant play any dvd or cd with my philips 3140 player...it simply says ERROR.
Can someone please help?
thank you,
H.
Jan 05, 2008 | Philips DVP3140
DVD unlock code/regional unlock code
icon_minipost.gifRegion code hack posted by knightlanguages, January 23 2008:
(1)Power on
(2)Press open on the DVD player to open drive cover
(3)On the remote control
(a)press SETUP button
(b)press right arrow key 3 times,
(the preference page will show up)
(c)press 9653
(d)Use the up and down key to select Region
(Select Region 0 for all regions)
(e)press SETUP again to save choices and exit
Your Audiovox D1917 is now region free!
Also works for Proline DVDP 920W
Nov 30, 2007 | Televison & Video
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
