Question about Sportsart Exercise & Fitness
Treadmill made by sportsart model 3106hr is showing error code e1
SOURCE: I have a horizon fitness, Quantum II treadmill.
im having this problem too if some one could email me how to fix it @ djbense@hotmail.com
cheers
Posted on Feb 26, 2010
SOURCE: my Lifespan treadmill is showing an E1 error code.
my lifespan treadmill has an error code e1
Posted on Mar 21, 2010
  • 6 Answers
SOURCE: Treadmill incline error
Try this, it fixed it for me, if it doesn't work let me know
http://www.youtube.com/watch?v=MIIxoPtvhy8
I bought a used Precor 9.4 treadmill, but the incline adjustment was not working.
So, I did the following.
1. Turn off, unplug the treadmill and wait for an hour (this is for safety
2. Remove the black motor cover
3. Observe the transformer to the right of the motor and towards the belt ( I point to it in the video)
This transformer converts DC electricity to AC electricity and the AC current goes directly to the Incline motor which is in the black box towards the front of the machine.
4. On mine the wires had come loose from the transformer, they were soldered on very poorly, the wires are stiff and you should be able to see 4 wires coming from the top of the circuit board and plugging into the transformer, I had three of the 4 wires loose.
5. If you are not comfortable working with electronics or soldering DO NOT DO THIS REPAIR, you could get shocked very badly if you just go poking around in there with metal objects, get a friend who knows how to solder or hire someone.
6. It took about 5 minutes I just heated up my $10 soldering gun from radio shack and soldered all the loose wires that were about a millimeter away from the tabs on the back of the transformer, and VOILA! The incline now works!
Posted on Mar 25, 2010
maxtreadmill
  • 832 Answers
SOURCE: my tunturi treadmill 661f is showing E1 on the
E1 error code : Unplug unit remove motor shroud and check the distance between the speed sensor and the flywheel and ensure that the speed sensor is properly attached to the motor frame. Check also speed sensor connections.
Unplug the electrical cord from the wall outlet and from the treadmill, wait 1 minute and turn the power switch on again. If treadmill recovers to normal operation, you may continue to use the treadmill.
Check the motor brushes either they worn or not sitting properly
Posted on May 17, 2010
Testimonial: "very helpful thanks saved me lots of money "
  • 33 Answers
SOURCE: E1 error code
Your problem might be that the sensor magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Posted on Oct 09, 2010
Error code AC-6
ERROR CODES: ADDITIONAL ERROR CODES:
www.gympart.com/TSB/.../Treadmills/.../Sportsart%20Error%20Codes.p...
ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION ...ERROR 1-2: AC SERVO ERROR - MOTOR IS OVERHEATING (SPEED RESTRICTED ... error codes listed by category: treadmills, bikes, elliptical trainers.
[PDF]Precor Error Codes
Jan 19, 2016 | Exercise & Fitness
What is E-1 error in Sportsart Tradmills
ERR1 Definition: The display board CPU didn't receive the optic sensor signal. • Explanation: After processing by the drive board, the optic sensor signal travels the 16-pin cable to the display board CPU, which determines motor speed. Components involved include the optic sensor, optic sensor wheel, 16-pin cable, drive board, display board, and connections. http://www.sportsmith.net/images/product_support/sportsart/Repair%20Manuals/General%20Treadmill%20Svc%20Manual.pdf
Jun 23, 2014 | Sportsart Treadmill Doctor Walking Belt...
How to fix error 1 on pec4555?
E1 usually refers to the speed sensor located near the motor that turns the belt. Try cleaning it. They can get dust built up on it and cause faulty readings.
Apr 25, 2014 | Sportsart 6300 Treadmill
Sportart 1050 series 1000 ,power on ready to go push start the Tred mill starts then stops emmediately showing error 1 ?
This may be helpful: http://www.treadmillsrepair.co.uk/2014/04/speed-sensor-for-treadmill-error-e1.html
Feb 18, 2012 | Sportsart Exercise & Fitness
Hello. My sportsart give's error 7 ? I don't now what the problem is. Can you discribe the problem en the solution for this? Thanks Gert Jonker
When I turn on the machine it beeps and reads Error 7 on the screen. Do you have a support phone number for Australia
Feb 12, 2011 | Sportsart 6300 Treadmill
Sportart 6310 treadmill - check speed sensor
Unplug unit and check the motor brushes they maybe worn and need to be replaced call Sports Art Fitness customer service @ 1-866-709-1750 they will sell you the brushes
Mar 13, 2010 | Sportsart 6300 Treadmill
My sportsart 6150 treadmill gives an error code 1 when the speed button is pushed. motor moves slightly but then gives error code 1. thanks.
I would say that it could possibly be a speed densor fault as error one means loss of speed signal!! If the mat moves first then error one shows i would change sensor before changing anything else, if the mat does not move it could be a lower control board fault.
Jan 23, 2010 | Exercise & Fitness
E1 error code
Good luck.
Jun 20, 2009 | Exercise & Fitness
Exercise & Fitness Logo
93 people viewed this question
Top Sportsart Exercise & Fitness Experts
Steven's...
Steven's...
L Pfaff
L Pfaff
Tom Chichester
Are you a Sportsart Exercise and Fitnes Expert? Answer questions, earn points and help others
