Question about PfaFF Sewing Machines
I can't get a bobbin to wind on a pfaff 1222E It appears that a gasket is suppose to be pushed up against a gear with small teeth, but it does not move. Can it be that the gasket needs to be replaced?
  • 632 Answers
You have to raise the presser bar lifter to the "A" position (highest position) to disengage the machine and set the machine to "bobbin winding" mode.
Posted on Jul 27, 2009
HOW DO YOU WIND A BOBBIN ON A PFAFF 2022 SEWING MACHINE
Bobbin winding
1. Place the thread spool on the spool pin in
against the spool.
back to front. Pull the thread clockwise around
the inside to the outside.
4. Place an empty bobbin on the bobbin spindle.
5. Push the bobbin lever to the right to wind.
A pop-up appears on the screen to inform
you that bobbin winding is on. Press the
foot control or the start/stop button to start
winding the bobbin.
When the bobbin is full, the bobbin winding
will slow down and stop automatically. The
pop-up closes. Remove the bobbin and cut the thread
Sep 14, 2016 | PfaFF Sewing Machines
How do I engage the bobbin winding gear for Pfaff 7570?
To disengage the needle while winding a bobbin do the following: the handwheel on the right end of the machine has an inner knob. hold the outer rim of the handwheel stationary as you rotate the inner knob counterclockwise. Also make sure the bobbin winding peg is pushed over to the right and the bobbin is seated on the peg.
Jul 27, 2014 | PfaFF Creative 7570
Can't wind bobbin even following instructions. HELP PFAFF 1222E.
Can you please tell us more? Is the bobbin winder not engaging? Do you have power to the machine? Is it that you don't understand the instructions? Lots of possibilities here...
May 18, 2014 | Sewing Machines
Have needle heating the house of the bobbin case on pfaff 1222e
Rabi. Do you mean Hitting on the bobbin case/shuttle? That is a timing issue.
Nov 29, 2012 | Sewing Machines
Where are the oil holes in a pfaff 1222e sewing machine
There are no oil holes in a 1222e. I apply a light oil to the inside of the bobbin case and where you clip the bobbin in the machine. I also take off the top and drop a light oil on the moving shaft. I was told no other lubrication was needed by the owner.
Jan 26, 2011 | PfaFF Sewing Machines
How do I time my Pfaff 1222E. The niddle hits the bobbin holder rather than the hole in the bobbin holder
I could write up the procedure but it would be too much for me to type in. Or you can purchase the 1222E Repair Manual and download it. It's pretty easy to work on as long as you have similar tools to clearances.
Apr 07, 2010 | PfaFF Creative 7570
Cannot turn the balance wheel - new machine to me. Pfaff 1222E
You have to lower the presser foot by one click to release it from bobbin winding mode. This mode is the same as needle down while presser foot is up so you can turn your work when it needs to go a different direction.
Nov 14, 2009 | PfaFF Sewing Machines
1222e has loose lower shaft that drives the feed
You can buy the service manual from eaby or you can download it from sewingwishlist.com in pdf format. Once in a while my 1222SE would act up. It's been really good having a service manual when you need it. As far as I know all the gears can be easily replaced by loosening it's flathead setscrew.
Oct 14, 2009 | PfaFF Sewing Machines
PFAFF 1222E Sewing Machine (~1977). Mechanically Locked-up
You might be in "Stopmatic" mode. Check if your pressure lifter bar is in the upper most position, if it is the machine is disengage and you are set to wind your bobbin. Lower it to the 3 o-clock position this will engage the machine and the needle will operate.
Aug 08, 2009 | PfaFF Sewing Machines
My bobbin mechanism has stopped turning on both a 332 and 1222E - thereby locking up the machine - is there an fix that I can do myself?
Is your presser bar lever all the way up to the 2 o'clock position? If so you are in "StopMatic" mode which is for bobbin winding. Place the presser bar at the 3 o'clock position to engage the machine for operation.
Jul 17, 2009 | PfaFF Creative 7570
Sewing Machines Logo
276 people viewed this question
Top PfaFF Sewing Machines Experts
SewTechWayne
SewTechWayne
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
