Question about PC Laptops
USB port broken on old IBM Thinkpads
Hi, I have 2 old thinkpads where somehow the little black plastic square that is part of the USB port got pulled out by some cable in the past... there is now just this hole with all the little wires exposed... If I insert any USB cable in to the port it does not work, on one of the machines, inserting something into that port causes the computer to reboot (at first I did not realize the port was broken)... Here is how the port on the I Series looks:
and here is the A31 - notice the bottom port has the piece there and still works...
Is there any way to fix this?
thank you so much for your help!
  • 111 Answers
Re: USB port broken on old IBM Thinkpads
The advice given by poohawk is sound advice, a port replicator is your best bet.
if you really REALLY want to replace the plastic piece, it can be done, a tutorial on doing it is located here.
Posted on Nov 20, 2007
  • 324 Answers
Thanks for providing the pictures. You don't know how much that kind of input helps!
In looking at the pictures you've sent, the only way to repair this is to replace the connector. It can be fixed, however you need to be aware that the cost to obtain a part as old as this plus the labor involved will probably be much more than the unit is worth.
One thing that you might want to try is to buy a USB hub and plug it into the working port. A USB hub is a kind of extention cord that will give you several USB ports.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thanks you, and have a super day!
0 characters
3 Points
Lenovo USB port bent pins
The USB port/socket needs to be replaced it cannot be repaired.
It is not an easy DIY job, you need to take it to an IBM laptop repair center or a laptop repair shop.
Aug 25, 2012 | IBM Lenovo ThinkPad T400 (2767P6U) PC...
I don't know how enable infrared port in my pc - ibm thinkpad x 41
By default, currently available ThinkPads come with the external serial port disabled and Infrared enabled on COM1. To use the serial port on COM1 you must either disable infrared or change infrared so that it uses alternate resources. If you are not using infrared for printing or file sharing it is recommended that it be disabled. Here are the steps to follow to enable infrared :
1. Double-click your ThinkPad Features or ThinkPad Configuration icon located in the ThinkPad folder on your desktop.
2. Locate the Infrared button located on the left-hand side of this configuration screen and click it once. (Note: If you hold your mouse pointer over any of the icons in this configuration screen the button will be identified at the bottom in the status window.)
3. Change Infrared from "Disable" to "Enable" and click "OK".
4. Locate the serial port icon and click it once.
5. Select serial port "enable" and insure that the COM PORT setting is "COM 1" and click "OK".
6. Shut down and restart the computer.
Jan 19, 2010 | IBM ThinkPad X41 Notebook
Is IBM Thinkpad T22 equipped with WIFI & what's the USB port vers
IBM Thinkpad T22 doesn't have Wi-Fi adapter installed. you need a USB Wi-Fi adpater in other to have Wireless connection.
You can go for D-Link, 3COM,belkin USB Wi-Fi adapter. Make sure the USB Wi-Fi adapter support the Operating System you installed.
Good Luck.
Jan 08, 2010 | IBM ThinkPad T22 2647 Notebook
Just as i turn the power on it says date time error then goes to a black screen and asks for a password ibm r51e
HMM, your kind of screwed I have worked on the thinkpads in my shop b4 and there is no work around the bios password. Either you need to remember your password or get ahold of who you bought it from. IBM has a military contract and they are not allowed to set a backdoor on the thinkpads according to that contract. The only thing they can do is replace the motherboard its a crock but thats the way it is. I would just but buy a new laptop that motherboard is $249 plus labor.
Dec 29, 2009 | IBM ThinkPad R51 Notebook
IBM Thinkpad R51-USB not working
get a PCMCIA USB port, I have one with 2 ports, I have seen them with as many as 4, and I found mine on ebay, though most electronics stores would have them, you can also get them with firewire ports, too
Sep 23, 2009 | IBM ThinkPad R51 Notebook
We can't get our IBM T30 to connect with our Linksys router . The computer has a 3com wireless card
Has the Wireless card ever worked attached to another wireless router?
Is the card an internal miniPCI card, and is it an official IBM card for your region? Thinkpads check whether the card is for the correct region before configuring them in the Windows drivers.
Are you using the Thinkpad Assistant Wireless tool. I have found that it appears to be impossible to configure this software for 64 bit WEP or WPA PSK authentication.
Sep 11, 2009 | IBM ThinkPad T30 2366 Notebook
Where is the wireless switch on the IBM think pad?
Use Fn + F5 (most thinkpads) to enable your wireless.
If you are used to a menu, visit (the producer of IBM Thinkpads for ages) and download System Update (a program which will download a lot of updates and drivers for your Thinkpad)
Dec 03, 2008 | IBM ThinkPad T40 2373 Notebook
T40p usb 2.0 ports acting like usb 1.0
There is no hardware or software fix for this. Here is a thread on what might be your problem.
Sep 14, 2008 | IBM ThinkPad T40 2373 Notebook
Replace LCD screen
All modern thinkpads are similar, you start by taking apart keyboard and top cover, then you unscrew hinges and remove screen. Here is some movie:
Thinkpad LCD Removal
Removing Thinkpad 600 Series Display - Part 1
Replacing Thinkpad 600 Series Display - Part 2
IBM ThinkPad R40 -- Fixing the black-out LCD Screen
This is not an easy job, there is risk to cause further damage to your laptop if you do not have enough experience.
May 28, 2008 | IBM ThinkPad T60 Notebook
PC Laptops Logo
4,124 people viewed this question
Top PC Laptops Experts
Brian Sullivan
Brian Sullivan
Are you a PC Laptop Expert? Answer questions, earn points and help others
