Question about Canon FAXPHONE L80 Laser
Not receiving messages. "Load paper" and "rec'd in memory." I take out paper, reload, and push stop/reset. Still get same messages.
  • 149 Answers
The machine thinks that there is no paper so it stores the documents in memory. Remove the paper, turn off the machine and unplug from the power for 5 seconds, then turn the machine back on and wait for a few seconds - now try and load the paper. The machine should try to reset the paper tray but if your problem persists then it sounds as though the paper sensor is faulty or has fallen out of it's position.
Posted on Jul 25, 2009
We have messages in the memory but keep getting message to 'load Paper' there is paper in the machine . I hvae tried putting fresh paper in , but it comes up with the same load paper message?
first thing is you have to insert new A4 sheet in to the rec/paper tray.then press the STOP key.after machine try to feed the paper in to the printer unit and you can get print.( if the machine cant feet the paper,the machine have some paper feeding problem and you have to get technical support to solve this problem)
Mar 07, 2011 | Canon L220 Plain Paper Laser Fax
Paper sensor faulty - printer doesn't recognise when paper is loaded
Cannot print from the glass top. The top load area keeps running and then the message says to reload the original. Push OK and go in circles. Maybe the paper sensor is missing?
May 15, 2010 | HP Officejet Pro L7680 All-In-One Printer
Flashing on panel "message in memory, receive to memory"
try doing an all job clear
function-7-Push monitor 4 times- then * . then 6 then up arrow. should say all job clear. then hit start should say initialize now.
wait for the time and date to reset and your done.
Jan 13, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Paper loading message says load paper even tho there's paper there
It sounds like the loader assembly motor has failed/is failiing in the printer. Considering the printer can be bought for $50 and the motor costs $25 and $45 labor to replace, you're better off just replacing it.
Oct 15, 2008 | Samsung ML 2010 Laser Printer
BARRIE@NORTONBARRIE.CO.UK
RECEIVED IN MEMORY
If the machine receives a fax under one of the following conditions, the machine will not be able to print the received fax and will store it in its memory.
When the problem is resolved as described, the fax stored in memory is printed automatically.
bullet_s.gif Ink is low or has run out while receiving a fax: replace the FINE Cartridge.
bullet_s.gif Paper size/type setting is incorrect: correct the paper size/type setting.
bullet_s.gif Paper has run out while receiving a fax: load the paper and press the OK button.
bullet_s.gif Output Tray is closed: open it.
bullet_s.gif OFF is selected for AUTO PRINT RX: select ON.
bullet_s.gif You pressed the Stop/Reset button to cancel printing of a fax: press the FAX button.
Jul 18, 2008 | Canon PIXMA MX310 All-In-One Printer
Error message - "check Rec. Paper"
Check rec. paper means that the paper may not be routed properly thro' the cutter mechanism and out thro' the machine....if it is; then the sensors that detect the paper may be dirty or faulty.
Mar 31, 2008 | Muratec M1250 Fax
Printing same page
try this make sure that receive reduction is switched on. You could load the paper tray up and just let it print as may have been a communication problem from RTI memory. Being Richo machine you should be able to reset the memory but this will get rid of all your stored numbers. But it will reset the machine so if you have a corrupted memory issue this will get rid of it.
Hope this helps you
Thanks J
Sep 11, 2007 | Ricoh 3310LE Plain Paper Laser Fax
Problems receiving faxes in memory
Just had the same trouble. I loaded paper. Tried more paper, tried less paper. No luck. Finally in deparation and trying "everything" I could think of, I pressed "stop/reset" before pressing "start/copy" and now it's working. Very frustrating!
Aug 30, 2007 | Canon FAXPHONE L80 Laser
Canon FAXPHONE L80 Laser Logo
156 people viewed this question
old marine
old marine
