Question about Garmin GPSMAP 60CSx GPS Receiver
60 csx WHEN STANDING IT KEEP GOING
IN THREE MINUTES, STANDING, IT MOVES 100 METERS ON TRIP ODOMETRES AND CONTINUE...
DO ANYBODY KNOW WHAT HAPPEN?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 67 Answers
Change the Record method in the 'tracks' menu
Posted on Sep 22, 2009
I got a 2001 gsx750f it wont start by switch it does start if i use a screwdriver to the solanoid but nothing on the switch i took grip off and looked at the switch and it seems ok i used a...
I will assume that you have checked all fuses and the starter circuit breaker. Circuit breaker has a red post that extends when it is tripped. To reset, push the red post down. If it is not tripped, there are a couple interlocks on the start circuit. First is the clutch switch, kick stand switch and then the gear position indicator. I would troubleshoot the circuit using a multi-meter. With the key off or battery disconnected, trace the wires for these switches back to a connection point. Use the multi-meter on the ohms scale and touch both sides of the connectors. Have someone push the start button, and see if the meter shows continuity. Meaning that when the button is pushed, the meter should go to 0.00 ohms. If it does, move to the clutch lever switch and then on to the kick stand switch. If they all work by continuity, turn the key on and verify voltage at these connections. Hope it helps!
Oct 19, 2014 | Cars & Trucks
The machine is not turning on at all, what do i do?
first check electrical recpt make sure it hot and not tripped.
second if electrical recpt is hot check cord for continuity with meter.
if cord is fine check switch for continuity. usually one of these three things that cause a vacuum not to turn on.
Jan 08, 2013 | Bissell 6594 PowerForce Bagless Upright...
Can anybody tell me where i can find the relay for trip meter/fuel gauge on 03 frontera
On most car the relays are located in the fuse box in the engine compartment,
Nov 03, 2012 | Cars & Trucks
I didn't wear my Michele CSX 36 w/ diamond watch for a few days..When I went to put it on the time was wrong. So I tried to correct it and now it has not kept accurate time w/in a 24 hr period. Fo
I am pretty 100 percent sure that Michele CSX 36 diamonds only comes with a swiss quartz movement not an automatic movement.
So the problem seems to be that the battery is dying and need to be replaced. Stopping and going is usually a sign of a battery dying in a swiss quartz movement.
So it should be nothing major and just a battery.
Jan 23, 2012 | Michele CSX Diamond watch
I cannot figure out how to switch the odometre reading from Trip back to Odometre. Where do I find the Trip odometre button on a 2002 Chrysler Town and Country?
Hi, The button should be in the odometer it self (little black button) Push till odo changes trip and repeat to get it back. Good luck
Aug 03, 2011 | 2002 Chrysler Town & Country
My Belling E641 keeps tripping out. Now the trip
You evidently have an earth fault on the cooker i.e one of the heating elements has failed and the trip switch is operating to prevent you getting a shock.
Most likely it is one of the radiant rings that is at fault but it could also be an oven element.
There is no easy way to tell without checking with a multi-meter for earth continuity between each element and the cooker frame, you can do this with the power off and the meter set to resistance or continuity test.
There should be no reading between healthy elements and earth but a faulty element will normally show a reading when the probe touches the cooker frame.
Dec 30, 2009 | Belling Ovens
On my Garmin GPS maps 60 csx there are no
This happens to about 1% of the units I've sold. Sometimes the GPS antenna software reverts to version 0.00 which of course is nothing. Check in the GPS by going: Menu > Menu > Setup > System > Menu to see the versions installed.
Use Garmin WebUpdater (free from Garmin web site) to reload the software and update if necessary - they bring out updates a few times a year - it's all free and very easy to do using WebUpdater.
Nov 03, 2009 | Garmin GPSMAP 60CSx
Hotpoint FDW60 Flashing lights 3 and 5
Is it possible that water has gotten inside the controls that could have caused the flashing lights? Kind of like spilling water on a calculator, everything seems to go haywire.
Jan 11, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Philips 42PF5520D
The capacitors in the power supply are probably bad. The best way to check them in circuit it with a ESR Meter. Or you can do what us old technicians call shotgun it and replace all the caps on the power supply module. Let me know it this helps.
Oct 15, 2008 | Philips 42PF9630A 42 in. Plasma Television
ODOmetre
the problem is inside the speedometer/odometer unit but before you take it apart just push in all the wires that are plugged into the meter this willsolve the problem if it is loose other that that the speedo head assembly has to be taken down and checked for internal repairs.
Sep 23, 2008 | 1997 Nissan Pathfinder
Garmin GPSMAP 60CSx GPS Receiver Logo
123 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
