Question about RTO PasLode 900420 Impulse Framing Nailer
Angle brader firing problem
I have a paslode angle brader Q when gun warms up firing pin dosent come back far enough to pick up next nail .can anyone advise thx owen
  • 142 Answers
Not real familiar with the gun in question, but when i have that problem with my Senco guns I usually make sure the nose is clean of gunk and spray some WD40 up the nose
Posted on Jul 23, 2009
Senco fram pro 602 nail gun firers but no nail just a hole from firing pin
First, check that you are using the proper nails. The FP602 needs Full Round Head nails with plastic collation. If you are using Clipped Head nails with the paper tape collation the angle of the nails not let the driver catch the next nail and drive it into your work.
If you have the correct nails, check the magazine to make sure the nails are feeding all the way up to the driver. If there is anything blocking the way or if the spring on the feeder isn't taught enough to pull the clip all the way up the driver won't be able to catch the next nail and drive it in.
May 05, 2012 | Senco Tools & Hardware - Others
Paslode impulse cordless nail gun,doesn't pull the piston back far enough to catch the next nail, so when I fire it no nail is picked up by the firing pin. batteries are good(new), cylinder is new, any...
This is an easy fix luckily usually it means that the chamber is dirty and all you have to do is open the top front of the gun so that you can see the piston then take a q-tip and clean the area really well sometimes it requires a degreaser and then when you think that you have it clean make sure to lubricate the chamber really well with the paslode lubricant that came with the gun or they sell it right next to where you get the nails. Then the gun should work fine with no problem if this does not work then this means that the piston might be bent and that could turn into a big problem but is still fixable just harder.
Hope that this works for you
Nov 25, 2009 | Tools & Hardware - Others
Nail comes out another hole
are you using the right nails and are they inserted properly if this is an angle gun? Also look for a jammed nail that might be causing this. look at the magazine bolts to make sure they are tight. You can go to Paslode.com for the owners manual and troubleshooting guide.
Sep 10, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode 350 wont fire
Probably needs cleaning. You`ll need two new o`rings.
Aug 19, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode air framer not sinking some nails
Your air pressure is dropping everytime you fire. It sound like your compressor is not cutting back in untill it to low. Not giving your tool enough continuess pressure. Your compressor cut in pressure should be around 90-100psi no less. and your max. pressure no more then 120psi. (Make sure your regulator is set at 110psi)
good luck...!
Aug 11, 2009 | RTO Paslode #650027 2500CT Placement Nail
When I fire my im250 the firing pin often does not retract fully, so not letting the next nail to progress. I regularly clean and lub the gun and it fires all the time so the problem is not at that end of...
Using a wire "toothbrush" size brush, clean the track in front of the gun where the pin slides - where the nail groove is. **** particles from the nails and the plating from the nails sluffs off fouling the path and causes the pin to stick. After several cleanings of my gun, I noticed that this brushing of the track the firing pin follows keeps it operating for several days without the problem recurring!
Jul 30, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Firing pin not retracting far enough to allow nails forward
Yes,this is a common "mis fire" by Pasilode. I own the 16p Framer and the Angle nailer and I never get it from the Framer but I do get it seldom from Trim Gun,nothing you can do ,its just a misfire.
Please rate jj505
Mar 20, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Paslode im350
Stuart - this sounds like an air problem - you should perform the following test. With the air nailer close to the compressor you must monitor the airpressure after the gun fires. it sounds like the air is not gettting through diapram fast enough or there is a blockage in line. Blockage in line is not suspected for the following reason . It sounds like the air hose is holding enough air to fire 2-4 nails and then you must wait for the line to fill up again and then it fires ok. The pressure regulator out to the line controls this and they do fail. try this test and report back to me - I know I can solve this for you as I have extensive background in compressor and the like.
Oct 22, 2008 | Itw Devilbiss Itw Paslode Cnp 65Y Coil...
RTO PasLode 900420 Impulse Framing Nailer  Logo
278 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
