I have a bad lamp and can't figure out an easy way to remove it. PaulB
  • Paul Boyd Jul 22, 2009
    It is a Sony model KDF42We655
  • Paul Boyd Jul 23, 2009
    Downloaded manual and fixed problem. Thanx
    Paul Boyd
  • 13,433 Answers
Could you post the brand and model and I'll see if I can help you with it.
Posted on Jul 22, 2009
  • Ekse Jul 22, 2009
    You can download a copy of the service manual from here
    http://ekse.pp.fi/Fx/SRVM/
    Open the page, then right click on the model number and select Save File As, save it to your desktop, then you can open it on your computer. if you can't open the manual you need a pdf reader get one from herehttp://www.foxitsoftware.com/pdf/reader/ its the free download.
  • Ekse Jul 23, 2009
    Nice, alright I'm taking the service manual off from that internet page now so make sure that you have a copy for future. well you can drop me a email at nikoht@gmail.com and I'll send you another copy if ever needed.
How do you remove the headlight assembly on a '96 Suzuki Sidetrack Sport
1.8L sport. USA ?
1: gain access to the rear of HL.
2: twist the European style, HL , lamp holder, and it unlocks
3: replace lamp.
if you want to replace the the HEAD LIGHT SHELL that is different.
remove grill, remove shell, replace shell, align lamps.
its all here
http://www.scantool.net/software/alldata-diy-1-month-subscription.html
Feb 09, 2013 | 1996 Suzuki Sidekick
Brightness is not uniform across the LCD panel, but grades from being brighter in the lower half into being darker in the upper half. This suggests to me that one of the CCFL backlights is failing. I would...
Please see my pictures here: http://s807.photobucket.com/albums/yy352/budm/DELL/Dell%20F1908FPC/
Be REAL CAREFULL on the PCB where the front switches are attached to, do not rip the ribbon cable.
Look for bad caps, bad lamp will cause it to draw too much current which will shutdown the inverter circuits, more likely the power supply is not feeding enough voltage to the inverter circuits due to bad caps. Or you may have bad solder works at the lamp assemblies. Lamp asemblies are not easy to remove!
http://s807.photobucket.com/albums/yy352/budm/Bad%20backlight%20lamp/
Do not remove the front bezel completely, just enough on three side then lay the monitor face down then snap open the back otherwise you will damage the cables.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 12, 2011 | Dell UltraSharp 1908FP Monitor
I have a jvc hd52z585. while watching tv it turned off and the lamp light and the power light are blinking at the same time. i have unplugged the tv for a couple of hours. when i plugged it back in it does...
very easy.
there is 1 thumb screw behind left speaker grill.unscrew it to remove the grill.the lamp is behind that.after changing the lamp,go in to CUST.MENU,scroll down to reset lamp timer. Best price for lamp is pureglare.com. Inspect the lamp for internal glass particles for 100% verification of being bad. Also at the root of the glass stem in the middle look for bubbling of the glass. This is another sign of a bad lamp.
May 20, 2011 | JVC HD-52Z585 52" Rear Projection...
I need to replace a foglamp bulb right side.I have fairly easy access to & can see the rubber housing for the bulb,but cannot figure out how to remove it.Do I need to rermove the entire assembly in...
Typically the fog lamp is located in the front bumper assembly. It's usually fairly easy to access and replace these.
Place the car is park, secure parking brake. Use a creeper to scoot under the front end of the car, look up into the bumper. Located the backside of the fog lamp holder. You would usually grab and twist counter clockwise about an inch, then pull straight out. Push in on the bulb while turning counter clockwise until it pulls out of the lamp holder.
These fog lamps usually have a little bit of cushioning grease in the socket. Do not remove the grease or connectivity problems will result with the new fog lamp. Push the new bulb in, turn clockwise until bulb stops turning, release hand pressure.
Installation is the reverse of removal.
May 25, 2010 | 1999 Oldsmobile Eighty Eight
Sony KDS-60A2000 60 in. HDTV Television turns on green and then turns to 3 red blinks a pause and then three blinks again. No picture on screen.
Lamp door is not attached properly (all the way) or lamp door switch is bad (less probable case). Remove lamp door. Locate pin that pushes into lamp door switch. Figure out where it pushes, find switch lever over there. Check if it's broken. Than re-install lamp door carefully and secure with attached screw. Make sure also that lamp door is not melted/deformed in any way. If yes - it's got to be replaced with new one.
Regards.
Russ.
Apr 04, 2010 | Televison & Video
Replacing fog lamp
Not easy - you have to get the lamp off of its fixings under the car, its a laying in the dirt job, you also have to remove the slash covers. ...... good luck.
Apr 02, 2009 | 2000 Jaguar S-Type
Hi there - need to open up my Samsung M7145 microwave to change the oven lamp which has blown. Any idea on how to get access?
hello ,
remove lamp form inside microwave oven . put new lamp , this very easy to remove, oven stop cover open also very easy . this lamp easy to get any electrical shops.
Nov 04, 2008 | Microwave Ovens
Benq PB6200 projector lamp or other problem
Hi there
I replaced a Mainboard on a BenQ PB6210 just yesterday - had all the same symtoms.
No LED lights coming on but the rest of the buttons has light.
Tried every other component from the lamp to the colourwheel , but the Mainboard replacement fixed it in the end.
You'll be looking at about $95 for the part
Apr 07, 2008 | BenQ (200NSH-LAMP) Projector Lamp for...
Picture and sound gone
your fuses may have blown off.
open the back panel and check all the fuses. There are a bunch of fuses in there, my tv has 5 altogether.
I hope this is the problem.
Feb 24, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
