Question about Dell SE198WFP LCD Monitor
Se198wfp LCD shuts off after 2 seconds or a couple if cool..
I have changed every cable and tried different LCD's so its not my Video card or computer...when the LCD goes off so does teh blue light....when i can get the display to work for a 4 or 5 seconds i can see so brighter pixels throughout the display.
Any help would be helpful thanks.
  • 1 more comment
  • dhale359 Jul 22, 2009
    To clarify the monitor is a Dell 19in and it is just over a year old.
  • dhale359 Jul 23, 2009
    Where can i get a power supply for this monitor? Anyone?....btw byteguy thank you so much for that insightful solution to my problem.
  • Buddy Mcsparrin May 11, 2010
    Hello, How old is your monitor? Buddy Corporate Computer
  • Dell Master
  • 1,684 Answers
If you can solder you may be able to repair your power supply. We have some pictures and repair guides on our web site at:
www.ccl-la.com/badcaps.htm The pictures show what bad capacitors look like, you can take a look at your power board and see if there are any bad caps on it. If so if you replace the caps you should be back going. If you want to send us a few pictures of your boards in the monitor, taken as close and clear as possible I may be better able to spot the problem caps.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Posted on Jul 23, 2009
Monitor black out but still on blue light to standy by turning yellew hase to do with capasitor problems for the back lit of the LCD monitor ^^
Posted on Jul 29, 2010
  • 2,229 Answers
Well, if you are satisfied that your computer works just fine with another monitor, then you could rightfully assume that you need a new monitor.
You answered your own question.
  • Art Ellison
    Art Ellison Jul 23, 2009
    Hey--sometimes you try and try to solve a problem and suddenly you realize you solved it without knowing it. Happens to me all the time.
    You can get replacement power supplies, but I'm thinking that it might be far easier to just replace the monitor.
    You can try places like National Parts Depot at 800-524-4800 for a starter . There is also Spareparts Warehouse at 877-253-8898
  • Doug B Jul 25, 2011
    Ok, I've now had 2 different Dell SE198WFP monitors with the same problem and I had to read numerous posts on numerous blogs looking for a solution before I actually figured it out, everything that I’d read suggested bad capacitors on the inverter board (and I’m sure that’s an issue, but it wasn’t mine). After replacing all of the caps on the inverter I still had the same problem.
    Long story short, I found (on both of my SE198WFP monitor’s) that at least one of the four CCFL backlight tubes had a burnt wire on the end of it. Period.
    Now I’m not sure if this is a common problem with this monitor, but it was in fact the problem with both of mine and after fixing these wires both monitors now work just fine :-) It seems that all four CCFL’s have to pull the same amount of current or the monitor trips the overload and shuts itself down. I hope this helps!! And good hunting :-)
My asus vw193D-B shuts down
Check cable. It's not communicating with PC video card. It should pick up the input port, but make sure on monitor. You can try re-seating video card. Also test with VGA if you are using HD like HDMI.
Aug 29, 2012 | ASUS MNTR ASUS| LCD 19' 5MS VW193D RT...
Dell SE198WFPf backlights go off after 2 seconds after power on. You can turn it off, then back on again and get light for 2 more seconds, then back off again. Light stays blue. Not a problem with the PC....
Ok, I have now had 2 different Dell SE198WFP monitors with the same problem (shutting down after a couple of seconds) and I had to read numerous posts on numerous blogs looking for a solution to this "problem" before I actually figured it out. Everything that I'd read suggested bad capacitors on the inverter board (and I'm sure that this is an issue, but it wasn't mine.) After replacing all of the caps on the inverter I still had the same problem.
Long story short, I found (on both of my SE198WFP monitors) that at least one of the four CCFL backlight tubes had a burnt wire on the end of it. Period.
Now I'm not sure if this is a common problem with this monitor or not, but it was in fact the problem with both of mine, and after fixing these wires both monitors now work just fine :-) It seems that all four CCFL's have to pull the same amount of current or the inverter trips the overload and just shuts itself down. I hope this helps!! "And good hunting"
Nov 21, 2010 | Dell Televison & Video
I have a Dell SE198WFP Flat Panel Monitor, screen goes black?
The LCd panel may be damaged and will cause this problem.
Another thing is overheating of the GPU.
The LCD signal receiver can be goign on you.
The is also the possibility of a faulty inverter.
Only thing to do is service or replace. Test the unit on another computer, if you don't get the issue there then you know its a problem with the PC.
Jun 03, 2010 | Dell SE198WFP LCD Monitor
Monitor will not start up
possible causes
1) video card slipped out of the slot, after shut the system down try reseat the video card
2) video card faulty
3) video card cable faulty.
try with some other vid cable, if it doesnt work with above mentined 1 and 3, then card cud be faulty.
Apr 21, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Gateway monitor (FDP1965) Power/video problem
You have a problem with your lcd..get it fixed by technicians...
Aug 28, 2009 | Gateway FPD1975W 19" LCD Monitor
When plugged into power I get no green light at the pwr switch, All is black. Is there a fuse burned out or is the pwr. switch broken???
1. Try a different power cable.
2. Open the monitor up, see that the soldering to the cable connect, or the switch isn't broken.
Jun 22, 2009 | Dell SE198WFP LCD Monitor
MONITOR COMES ON FINE I GET A FLICKER AND THE SCREEN GOES BLACK
It’s very likely your monitor has failed. Most Dell monitors have a 3 year warranty, so if you got it before three years, you could get it replaced by calling Dell. If you got the monitor with the computer, you can check your warranty online from with your computer Service Tag from http://support.dell.com/support/topics/global.aspx/support/my_systems_info/details?c=us&l=en&s=gen . If you bought the monitor separately, you would need an Order Number or Customer Number for the purchase, or you could call Dell support and they could pull it out with your registered phone number. Dell would also need the serial number (starting with CN XXX..) from the back of the monitor.
Monitor User guide for SE198WFP available at http://support.dell.com/support/edocs/monitors/SE198WFP/en/preface.htm
Hope this helps. Please rate your feedback!
Thanks,
VJ
Mar 24, 2009 | Dell SE198WFP LCD Monitor
Signal for 10 seconds
hello nicky, double check your graphics card, some graphics card has shorted power causing to shutdown. try to replace or swap a new good condition graphics card. For you to examine well try use to swap it to another PC your Acer monitor. hope this could help you a lot. Good luck. agent1463
May 19, 2007 | Acer AL1711 17" LCD Monitor
Dell SE198WFP LCD Monitor Logo
1,078 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
