Question about Panasonic PanaFax UF-490 All-In-One Laser Printer
Setup When i first plug in the printer the little screen starts a stepped setup, sometimes it goes quickly and the printer will work ok for a while, Other times it steps slowly and just locks up and will not do anything until I unplug the printer.
  • deadhead Nov 20, 2007
    This is a Panasonic uf-490 laser fax printer
  • deadhead Nov 24, 2007
    Sorry I didn't get back sooner, was out of town. The problem is strictly with the printer, as I can get this to happen without the computer even hooked up and used as only a copier fax machine.
  • 1,006 Answers
Just go start run then type msconfig STARTUP and desable all programs from startup ( just don't desable ANTIVIRUS )
Download registry repair and run it to fix registry problems
download also uninstaller 2006 to clean up HDD
Let me know if u got help and please if u got help rate this SOLUTION AS FIXYA.
Best Regards
Beni
Posted on Nov 20, 2007
  • Jason Jimenez Feb 01, 2011
    I have the same problem with mine, did anyone get back with you on how to fix this. I Press Clear, stop, start and copy at the same time before I plug it back in and that sometimes works for me. but not all the time.
How to stop orange wi fi light from blinking
The blinking WiFi light on your printer could indicate that it's trying to communicate with your wireless network or it's not connected to your wireless network anymore. A quick fix to this problem can be achieved by rebooting your system. Simply unplug and re-plug your printer and your wireless router into the power outlet and reboot your computer. Once everything turns back on, check the status of the WiFi light and try to print again to verify that the problem is fixed.
You can also do the following steps to reset the printer wireless network adapter:1. From the printer operator panel, press the Setup button.2. Select Network Setup.3. Select Reset Network Adapter.4. Hit the OK button.
The WiFi light will momentarily turn off and then on solid orange. You can then try to reconfigure the printer to connect to wireless network using the Lexmark Wireless Setup Utility application on your computer. Go to Start menu > Programs > Lexmark 4600 Series folder > Lexmark Wireless Setup Utility. Simply follow the instructions on your computer screen.
However, if you wish to have it connected directly to your computer. Simply connect the printer with the USB cable that came with it in the package.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Nov 20, 2011 | Lexmark X4650 All-In-One InkJet Printer
Appears on screen 83c00020 on a blue screen with the on/off sign how can i get it to start again
This indicates a hardware fault with the printer. Sometimes resetting the unit will solve the problem. Unplug all the cables (USB, phone and then power) to the printer. Wait at least 15 seconds. Reconnect the power cable. I usually pull the power cable from the printer and then the wall outlet and then reconnect the cord to the wall outlet and then the printer. Check if this solves the problem.
If it doesn't help, repeat the remove cables step and wait a while. When you are ready to plug the power cord back in, press and hold OK and On while you plug in the power cord. (A second person will help for this step.) Next with the printer on, unplug the power cord. When ready to reconnect the power, press and hold # and 6 as you plug in the printer. Release the keys when the screen goes blank and then follow the on-screen directions. (On some HP printers, it's Cancel and OK that you press at the first step. A few use OK and Help. There are other key codes that can get you into the reset mode as well: # 3 and # 9 for example.)
If none of the resets work, then the printer needs service. If it is out-of-warranty, decide if the cost is worth it for you.
I hope this helps.
Jul 18, 2011 | HP Photosmart C6180 All-In-One InkJet...
Brother HL-2170W laser printer goes into sleep mode quickly. How can I turn off the sleep mode.
I found this from Tony Benjamin
I have tested it on two different Brother Lasers and it worked.
To cancel DEEP SLEEP on Brother Printer
  1. Go to General Setup then OK
  2. Ecology then OK
  3. SLEEP TIME then OK
  4. While sleep time is display push Down Arrow and CANCEL at the same time!
  5. DEEP SLEEP on/off toggle by Arrow keys
  6. OK to SAVE Deep Sleep off.
It is a shame they don't have this in the web interface or manual they sent with the printer.
Nov 03, 2010 | Brother HL-2170W Laser Printer
Hp photosmart 7200 and hp laptop are not communicating. wierless signal strengh is excellent. cancelled , documents cancelled and error message appears.
Click on the link to resolve printing issue on wireless network -> Link
Click on the link to find out if the HP Printer is on wireless network on not -> Link
To Setup the printer on wireless network, follow the steps below
1. Press the SETUP Button printer front panel
2. Scroll to Network - Press OK
3. Scroll to Wireless Setup Wizard - Press Ok
The printer will start searching for wireless router.
Choose the SSID ( Network ) and enter SSID ( network key if setup ) and Press OK
You should get a message as Printer Wireless Setup complete.
Run the HP Printer Software Disk and Choose Add a printer and Choose Wireless Installation and follow the instructions on the screen to complete the setup
You are ready to Print and Scan
Oct 12, 2010 | HP Photosmart C4580 All-in-One InkJet...
Unable to connect to the laptop computers
dear Sure there is, but it's supposed to connect via a LAN switch. Since it worked at your old place, did you miss a step? Was the printer plugged into a router and the computer also plugged into the same router?
Start with the wired network setup section in the quick start guide. It might give you an idea on what to do http://www.brother-usa.com/ModelDocuments/Consumer/Quick%20Setup%20Guide/QSG_MFC_490CW_EN_1578.PDF
Thanks.
May 07, 2010 | Brother MFC 490cw Color Inkjet...
Is there any way i can connect my brother mfc-490cw all in one to my laptop with a wire? i recently moved and swear it was connected before through a wire but i cannot find any inputs other than those in...
Carl
May 01, 2010 | Brother MFC 490cw Color Inkjet...
How to instal printer on dilink dir-888
i 1 D-Link DIR-855 User Manual 0
Section 2 - Installation
If you are connecting the router to a cable/DSL/satellite modem, please follow the steps below:
1. Place the router in an open and central location. Do not plug the power adapter into the router.
2. Turn the power off on your modem. If there is no on/off switch, then unplug the modem’s power adapter. Shut down your computer.
3. Unplug the Ethernet cable (that connects your computer to your modem) from your computer and place it into the Internet port on the router.
4. Plug an Ethernet cable into one of the four LAN ports on the router. Plug the other end into the Ethernet port on your computer.
5. Turn on or plug in your modem. Wait for the modem to boot (about 30 seconds).
6. Plug the power adapter to the router and connect to an outlet or power strip. Wait about 30 seconds for the router to boot.
7. Turn on your computer.
These instruction are on the CD that came with the router
Here is the start:
D-Link DIR-855 User Manual 13
The DIR-855 includes a Quick Router Setup Wizard CD. Follow the simple steps below to run the Setup Wizard to
guide you quickly through the installation process.
Insert the Quick Router Setup Wizard CD in the CD-ROM drive. The step-by-step instructions that follow are shown
in Windows® XP. The steps and screens are similar for the other Windows operating systems.
If the CD Autorun function does not automatically start on your computer, go to Start > Run. In the run box type
“D:\DIR855.exe” (where D: represents the drive letter of your CD-ROM drive).
When the autorun screen appears, click Install Router.
Section 3 - Configuration
Configuration
This section will show you how to configure your new D-Link wireless router using the web-based configuration utility.
Web-based Configuration Utility
To access the configuration utility, open a web-browser such as Internet Explorer and enter the IP address of the router (192.168.0.1).
Select Admin from the drop-down menu and then enter your password. Leave the password blank by default.
If you get a Page Cannot be Displayed error, please refer to the Troubleshooting section for assistance
Click Launch Internet Connection Setup Wizard to begin.
If you want to enter your settings without running the wizard, click Manual Configuration and skip to page 19.
follow the prompts.
You also can go to D-Iink.com for setup instructions
Apr 20, 2010 | D-Link DIR-855 Wireless Router
HP Deskjet 6940 Connection Issues
i am not sure of the steps which you have follwed till now,
just try performing the steps below..:
click on start
click on run
type msconfig and click on OK
click on start up tab
uncheck the HP related options from the list...
also check the option " hide all microsoft services"
apply ok..
if the issue persists, write back..
Narendra Tirunahari
Jan 22, 2010 | HP Deskjet 6940 InkJet Printer
Got a new laptop and need to connect the hp laser jet p3005
Hi Terry_preyse !!
Thank you for writing to Fixya.com.
To setup a printer you'll require:
  • A Printer
  • An USB cabel or Wireless Card(if want to setup wireless printer)
  • Driver disc & it'll be shipped with the Printer
  • Last but not least, 15-20 minutes.
Unpack the printer carefully, plug the USB cabel in the printer. Don't connect it to the computer & turn on the Printer & here's what you need to do.
  1. Step 1 Set up your computer on your desk so that you are able to plug in your printer and other accessories in an orderly way. The PC is the center of your home office and all things should be setup in relation to this. Consider how you’ll run cables before selecting a location.
  2. Step 2 Assemble your printer. Few printers are ready to go out of the box. Open it up carefully and pull out the quick setup instructions. This usually entails affixing trays and installing toner and drums.
  3. Step 3 Decide on a method. Wired or wireless? Wireless will save you a lot of hassle but if you are on a tight budget wired does the job as well.
  4. Step 4 Install the drivers. Insert the CD that came with your printer into your computer and install the drivers before connecting your printer.
  5. Step 5 Connect with cables. Using a USB cable or a parallel cable, connect your printer to your computer. USB cables have a trapezoid shaped plug on the end that goes into the printer and a rectangle shaped plug that goes into the computer. Parallel cables will have holes on the computer end and pins on the printer end.
Hope this will help !
Regard's
Anurag Shukla
Sep 03, 2009 | HP Hewlett Packard LaserJet P3005 Printer
How to hook up to my computer a canon mp510 printer
i have provided you a link to a website which provides the following:
first, an "On-screen Manual for Windows", a file you need to download and install and as the title says it is the complete user's manual you can browse with using your computer
second, an "On-screen Manual for Macintosh", same as above but for Mac computers
third, the "Quick Start Guide", it is a smaller version of your user's manual just enough to start working...it is in PDF format if you don't have a reader click on this link...PDF Reader....download and install...
fourth, the "Easy Setup Instructions"..again this is in PDF format and this time it is a step by step procedure on how to setup and connect your printer to your computer.....with pictures..
Good Luck and have fun!
This is the link---->Guides and Manuals
Apr 28, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Panasonic PanaFax UF-490 All-In-One Laser Printer Logo
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
