Question about HP LaserJet 4345mfp Printer
Cold Start How do you do a cold start on a HP Laserjet M4345. My IT people told me to turn off, hold down the reset button, turn on till it says cold start. This does not work. Plese help
    Novelist:
  • 125 Answers
Hi patricia_kin:
Hope this helps.
Cold reset
A cold reset unlocks menus that have been previously locked and resets all control-panel menu
items to the factory defaults. A cold reset does not clear the values in the service menu, such as the
serial number and the page counts.
NOTE Before performing a cold reset, print a menu map and a configuration page. See
Information pages. Use the information on these pages to reset customer-specific settings.
CAUTION All HP Jetdirect settings are also reset. Be sure to print a configuration page
before performing a cold reset. Make note of the IP address that is listed on the Jetdirect
configuration page. You will need to restore the IP address after performing a cold reset. See
Configuring and verifying an IP address.
To perform a cold reset
Turn the MFP off and then on.
2 When the memory count appears on the control-panel display, press and hold 6 until all three
LEDs flash once and then stay on. This might take up to 20 seconds.
3 Press 3 four times until COLD RESET appears on the control-panel display.
4 Press 6 one time. The MFP continues its initialization sequence.
Posted on Jul 23, 2009
    President:
  • 3,085 Answers
Turn machine off.
Hold down CHECK MARK key while turning printer on.
Select COLD RESET
2 Suggested Answers
  • 313 Answers
SOURCE: LaserJet M4345 MFP Printer: how to cold reset in HP LaserJet M4345 MFP...
walid_sayed@hotmail.com
1 Turn the MFP off and then on.
Posted on May 07, 2010
Cold reset hp 3600n
To Perform a Cold Reset on HP Color LaserJet 3600n Printer
Step 1 - Turn the printer on.
Step 2 - Watch the control panel.
Step 3 - When the memory starts counting, press and hold the green (Select) button. Continue to hold Select button until all three Control Panel LED's are illuminated and on solid.
Step 4 - Release the (Select) button.
Step 5 - The control panel will display SELECT LANGUAGE.
Step 6 - Press (Down Arrow) button once. The control panel will display COLD RESET.
Step 7 - Press (Select). The printer will perform a cold reset and then continue its power-on sequence.
Jan 24, 2017 | HP Office Equipment & Supplies
How to cold reset in HP LaserJet 1536 dnf mfp
Resetting the HP LaserJet Pro M1536dnf accomplishes the following:
  • Clears all data from the printer's memory (including unprinted data, downloaded fonts, and macros).
  • Stops any printing that is taking place and ejects the page.
  • Removes some error conditions.
  • Resets the printer to its factory default settings.
Reset Procedure:
  • Turn off the printer
  • Press and hold the Left arrow & Cancel while you turn on the printer
  • Once you see Permanent Storage Init you can release the buttons.
  • The printer should now start resetting.
Thanks,
HP Printer Support
Jun 10, 2014 | HP LaserJet M4345 MultiFunction Printer
Password in motherboard m5035
Cold reset requires no password. Go to the machine and turn it off. Power it on and when the memory count starts, hold down the 6 button on the keypad. Hold until all three leds turn on and stay on. Release the 6 button, press the 3 button until display reads "cold reset", press 6 once more and printer will restart.
Apr 16, 2014 | HP LaserJet M5035 MFP Printer
Cold reset
when powered off the printer, press 3 and 6 and hold, power on, make your choice at menu, (cold reset) and press ok. printer will restart itself.
Jun 25, 2013 | HP LaserJet M4345 MultiFunction Printer
Incorrect Pin Error message coming on HP LaserJet M4345 MFP printer..
The pin for this specific machine should be 11434506.
If that doesn't work you must cold reset the machine.
Turn it off the machine.
Turn machine on hold 6 down until the memory count is done and all 3 lights are on release 6 and use 3 to arrow up to cold reset and press 6 "acts as the enter button"
FYI
3 works as arrow up
9 works as arrow down
6 works as the Enter button
Oct 15, 2010 | HP LaserJet M4345 MultiFunction Printer
How do i cold reset a HP CM6040F MFP COLOR LASER PRINTER It doesnt complete the initilization process... keeps hanging on step 6
restart the printer hold down 6 when backlight illuminateshold till all three lights turn on,relese 6 keythen press 3 or 9 to scrool
press 6 to select the optionu want then enter cold reset starts......
Jul 14, 2010 | HP LaserJet 4730 MFP Printer
May 07, 2010 | HP LaserJet M4345 MultiFunction Printer
How do i get this error cleared 49ff95 on hp laserjet m4345mfp
Hi, Well this problem could be due to a lot of things. If this won't with a power cycle then make sure there is nothing in the print queue, a corupt file could cause this. If nothing there then try a cold reset. I believe turn off then on when you see the memory start counting hold the number 6 down until the three lights turn on and stay on. (Something should be seen on the screen like disk intialize or something) push 9 until you see cold reset then hit 6 again.
Regards, polysandy
Apr 21, 2010 | HP LaserJet M4345 MultiFunction Printer
My hp laserjet m4345 mfp has all three lights flashing and wont work
Try performing a cold reset. press and hold "6" while booting and counting RAM. Release when all 3 led's are lit. Use "3" and "9" and navigate to "Cold Reset". Press 6 to enter.
Dec 16, 2009 | HP LaserJet M4345 MultiFunction Printer
HP LaserJet 3055. All of a sudden it stopped working. after powering up, it does "nothing" HP appears in the menu window, but that's it. none of the keys works, no way to even test it. All cables are...
Perform a cold reset
  1. Turn the printer on.
  2. Watch the control panel.
  3. When the memory starts counting, press and hold the green c00007906.gif (Select) button. Continue to hold Select button until all three Control Panel LED's are illuminated and on solid.
  4. Release the c00007906.gif (Select) button.
  5. The control panel will display SELECT LANGUAGE .
  6. Press c00235041.gif (Down Arrow) button until control panel displays COLD RESET .
  7. Press c00007906.gif (Select). The printer will perform a cold reset and then continue its power-on sequence.
Dec 14, 2009 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 4345mfp Printer Logo
5,081 people viewed this question
Seeker5211
Seeker5211
