Question about Garden
11 HP Honda engine won't start.
I have an 11 HP Honda engine on a tow cart. It has only been used about a dozen times. I've changed out the battery. Engine will not start with the starter or the pull cord - just turns over like no spark - suggestions? Thanks WM
    Brigadier General:
  • 4,090 Answers
Ypu could try a canned spray called AERO START which is a chloriform based accelerant. Spray into air intake and start engine. If it doesnt start with this solution then there is a serious problem.
Ensure the spark plug is actually sparking .
Remove it from the socket and place near an earthpoint while still connected and turn motor over. If it sparks then tick that box.
Ensure the spark is strong rub sand paper over the element of the plug to make it bright and shiny
check the lead is in good condition replace if nescessary. A bad lead especially carbon fibre crack inside and become leaky causing poor spark or no spark. If this appears OK then tick that box!
Place a spray of Aerostart inside cylinder and replace plug start engine again. if it fails to respond it will need to be seen by a mechanic
Posted on Jul 22, 2009
My 2005 Honda VTX 1800 doesn't start, changed battery no help. Neutral light goes out as soon as I hit the start button
Hi, Pat and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
http://www.vtxoa.com/forums/6-vtx-1800-tech-board/201598-2002-vtx-1800c-won-t-start-switch.html
VTX 1800 wont start need Help
What Do Check When My Motorcycle Won Start
Honda VTX1300S Service Manual
Honda VTX1800C Owner Manual
Nov 01, 2016 | 2005 Honda VTX 1800
Charger wont kick off after fully charged.
Charger won't shut off - Buggies Gone Wild Golf Cart Forum
www.buggiesgonewild.com > ... > Electric Club Car
Sep 27, 2010 - 7 posts - ‎2 authors
But the cart still wouldn't fully charge. After charging the cart, I checked the voltage on the entire battery pack using my meter and then each ... 36 volt powerwise ez go charger not working
Sep 5, 2011
Club car 96 battery charger not turning off
Aug 30, 2011
2001 Club Car Charger Won't kick off
May 31, 2011
48v club car charger wont shut off
Apr 11, 2009
More results from www.buggiesgonewild.com
About Golf Cart Battery Chargers - Golf Cart TalkGolf Cart Talk
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Jan 24, 2016 | Golf
2000 Honda Odyssey. My problem is when I do not
With vehicle operating, take it to local auto parts store and have them wheel their diagnostic cart out to vehicle. They will check it complimentary and likely find your issue.
Oct 25, 2013 | Honda Cars & Trucks
My 83 Honda accord battery won't charge I've
Get each and every part separately bench tested and get the voltage test of each part.The battery,alternator and Voltage regular.For step by step troubleshooting,click the link below:
http://alltypesofpartsreplacing.blogspot.com/2012/11/car-battery-warning-light-battery.html
This will help.
Thanks.
Feb 15, 2013 | Cars & Trucks
My 2004 Honda Pilot ran fine then a hour later won't start. At first thought battery so we charged up usig one of those chargers you plug in. Lights flicker, and clicking sounds but won't turn
Check batry terminals are secure & free from corosion, check security of earth strap to engine & main power wire on starter, if ok have the batry load tested to ensure it can perform under load as the starter needs a lot of current. Have you tried a jump start?
Sep 24, 2012 | 2004 Honda Pilot
1986 honda goldwing won't crank
Hi, Anonymous before testing any electrical component in the Starting System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
8. Faulty kickstand, clutch, neutral safety switch.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter have failed or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. The electric starter is working but starter clutch has failed.
14. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1985 GL1200 Won crank start or turnover
tried starting 84 with low battery won start now GL1200 Information...
Honda GoldWing GL1100 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda Gold Wing GL1100 Owner Manual
Aug 09, 2012 | Honda GL 1100 Innerstate Gold Wing...
"The yellow 'Alarm' light will not go off after changing cartridges.
Try removing and reinserting the cart. Or try a new cart. It sounds like it's not recognizing that a new cart has been inserted. It could be a faulty/sticky switch where the cart is detected.
Jun 21, 2012 | Canon Office Equipment & Supplies
Garden Logo
811 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
