Question about Lite On Computers & Internet
Need to replace a Lite-on power supply witch came out of a Acer Aspire X1700 the power supply model # is PS-5221-06 need help finding replacement.
No really a solution. Could do we someone just saying where a Liteon PS-5221-06 power supply could be bought from. That would be the actual answer to the question!
Posted on Feb 10, 2010
  • Lite On Master
  • 5,660 Answers
Yes, I see what you mean since your computer is an SFF, (Small Form Factor), and uses an SFF power supply. Hard to get a power supply replacement, much less the power switch for the power supply.
Some things to note about working on a personal computer power supply,
1.They use Electrolytic Capacitors inside them. The aluminum case, cylindrical looking objects. These 'Caps' are designed to slowly build up a charge, then release it all at once. They can hold a charge after being disconnected from power, for weeks, sometimes Months!
There are typically two large ones used in the Input Stage. These hold a LARGE charge! Touching the terminals on the bottom of a capacitor, or touching a circuit that they are in, can result in a bad shock, or even Fatal one!
2.The particular power supply you have, has a Soft Power On function built in. There is no switch cable from the front panel of the computer, to the power supply. The power supply can be plugged into power constantly, and needs no On/Off switch on the back. This switch could be removed, and the wires to it soldered together, with heat shrink tubing over the connection.
http://en.wikipedia.org/wiki/Computer_power_supply
http://en.wikipedia.org/wiki/Switched-mode_power_supply
You DON'T need an On/Off switch on the power supply.
I have given you a solution in the form of information, but am NOT recommending you open your power supply, Nor work on it.
Posted on Jul 22, 2009
Replace or repair acer aspire x1700 Dual-Layer DVD+/-RW
What does "not working" mean. No read, no burn, other.....?
I have good luck with TDK, Acer, and almost any higher end products.
Aug 29, 2014 | Computers & Internet
Where is the CMOS battery on an acer aspire x1700 desk top computer
Most motherboards use a coin size 3 volt lithium battery type CR2032.
Ti help you.
Download the manual for your model computer from this WEB site.
http://www.manualowl.com/p/Acer%20Computers/Aspire-X1700/Manual/65650
Feb 03, 2013 | Acer Computers & Internet
Cd drive in my acer aspire x1700 doesn't open
You are going to need a paper clip. Look fo a small hole next to the switch. straighten the paper clip and put it in the hole in the center. carefully push to activate the mechansium to open the door. Then you can troubleshoot the door. Turn off the computer then pull the power cord from it. Open the computer case find the power cable to the cdrom/dvdcdrw and push it in to make sure you have good connection. If it still doesn't work after this then you can get a new drive for less than $30.00 (usd)
Hope this helps,
Terry
Nov 16, 2012 | Acer Aspire Pc Minitower X1700
My acer x1700 doesn't power up the power supply
Check your CMOS battery make sure its in tight and is not drained. also check the power switch cable from the power button to *********** board, that is the most common issue i see in my shop daily. and of course the power cord i would switch that out as well bad power cables are also very common.
May 30, 2011 | Acer Computers & Internet
I need replacement psu for acer aspire x1700 slimline tower
to be honest, the X1700 is a weak computer, you should NEVER buy slimline desktops, the power supply is going to cost more than the computer, being that it is a special type, you cant just buy it in a store, having to replace some myself, i can tell you that a decent used PC is around $150, and you can still put some of the hardware from the slimline into the used PC such as the hard drive, cd drive, and memory. Best of all, a full sized unit can be fixed relatively easily and for a lot less since most parts are interchangeable
May 06, 2011 | Computers & Internet
I have replaced the power supply on my Acer Aspire X1700 computer but the new power supply acts exactly like the old. When I plug it in and turn it on the "Power Supply On" voltage goes from 5 VDC to 0 VDC...
When you have this problem on this PC, do not replace the power supply or the motherboard until you have first tried pulling out the video card. When the video card fails it can cause the x1700 to not power up. Pull the video card and see if it will power up without it.
Mar 09, 2010 | Acer (56.04145.901) (5604145901) Power...
I have ACER Aspire One Model KAV60. Need to Identify Power supply
There are three adapter manufacturers, the Acer One runs on 30 watts and 19 volts. Below are the specs for the adapters.
10001081
DELTA
30W Adapter DELTA 30W 19V 1.7x5.5x11 Black ADP-30JH BA
LF
60003544
LITE-ON OPT
30W Adapter LITE-ON 30W 1.7x5.5x11 Black PA-1300-04AC LF
60002015
HIPRO
30W Adapter HIPRO 30W 19V 1.7x5.5x11 Black HP-A0301R3
Jan 24, 2010 | Acer Aspire One PC Notebook
My Acer Aspire X1700 power supply burnt out....
The manufacturer is Delta Electronics, Inc.
Their website is down.
However, I did find it :c) Took awhile...
http://codemicro.com/store/check_price.php?partid=13901387
Jun 27, 2009 | Sony VAIO PCV-RS724G PC Desktop
Ps2 on acer x1700 don't work
connect both the mouse &keyboard restart the machine.if then also it not works then there must be some hardware problem&your desktop does not support.try the usb mouse&keyboard.
Mar 08, 2009 | Acer Aspire™ T180 PC Desktop
Computers & Internet Logo
4,274 people viewed this question
Top Lite On Computers & Internet Experts
John Anderson
John Anderson
Michael Vanidestine
Michael Vanidestine
Level 1 Expert
Computer Links
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
