Question about GE Energy Star SDL20KCSBS Bottom Freezer Refrigerator
Slow compressor fan
Compressor fan barely turning and compressor turned on for 15seconds then back off again repeatedly. Fridge was warm inside. Replaced control board. Fan turning now, but compressor does same thing. Still warm in fridge and freezer.Pfs22sisbss GE. Control board replaced with wr55x10656
  • charles farrow May 11, 2010
    compressor or starter/relay
  • GE Master
  • 4,654 Answers
You need to remove the fan and test it somewhere different. The compressor is in need of the condenser fan. Everything will overheat without that fan working. You should also test the power at that pin plug. Let me know what you find. Sea Breeze
Posted on Jul 22, 2009
Fridge and freezer not cold. Ice melting.
Need to replace circulation fan in freezer,
Remove plastic bump out in the back of the freezer, to access fan...
Mar 02, 2015 | Kenmore Refrigerators
Subzero r601 compressor not turning on
Check the relay on the compressor. Pull it off and shake it. If it rattles, it is bad.
Dec 07, 2012 | Refrigerators
Model# gsh22kgmcbb. everything thawing out.coil was covered in dust, cleaned as best i could. fan motor running kind of slow,i think.
Are you talking about the Condenser Fan at the back of the fridge next to Motor/Compressor.
If that is running slow it means the fan motor bearings and lubricant inside the fan motor has turned into a sludge which is a common problem. Need to replace the condenser fan motor. You can put a normal household fan behind the fridge to cool the compressor in the meantime.
Ash
Sep 06, 2011 | GE Monogram ZISS420NRSS 42" Built-In...
I have a national NR-302TE-X fridge for the past 4 months the fan in the freezer gets frozen and stops due to this the fridge does not cool and a lot of water is defrosed and there is water inside the...
dear
there is a temp, sensor in side the fridge that turn on a heater rod and stops compressor that melts the ice at back of freezer and fan.
or toy can open rear panel in side freezer and pure hot water (not boiling ) on frozen ice on condenser coils, this will help you for on week and then you have to repeat it again
you need a good tech person to solve that problem
hope toy under stand
?Adnan : eng-adnanpaul@hotmail.com
Nov 13, 2010 | Refrigerators
My side by side fridge has stopped chilling down, the power is Ok, and moter seems to be working, but no cold inside. A few months ago the freezer side stopped, but as i did not use it , i just left well...
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jun 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge and freezer same temp.
First of all, there is only one thing that cools in a fridge and that is the freezer. The fresh food section is cooled by air forced into it from the freezer.
  • You ice maker will not work if the temp inside the freezer is above 5 degrees. It has a thermostat inside it that enables it.
  • The knob that turns the fridge off and on is the thermostat for the freezer.
  • The other knob opens and closes a damper between the freezer and fresh food section.
  • There is a fan that should be running that pulls air from the freezer into the fresh food section.
(The factory does make the discription of the knobs confussing)
Now. turn one of the knobs all the way one way and then the next. If it turns the compressor off, it's the thermostat. If it does not, try the other knob. Once you find the thermostat, set it in the middle of the scale. Now place the other knob the same. Check and see if you can either feel or hear the inside fan running. If so lets go to the back. This is where your compressor is. It is under the fridge and also has a fan that blows on it. You will need to remove the back bottom panel. See if you can tell if the fan is running. Also notice if the fan is blowing into a set if coils. You should also be able to fill the compressor, if it's hot, it's running. If these two are running, and you didn't see a coil at the fan. Take the front kick panel off the fridge and clean the coil that's under the fridge. If it's dirty, give the fridge a couple hours and see if it cools down. If so, this was your problem. If both knobs are set mid scale, both fans are running, the compressor is also running and the coils are clean. You most likely have a bad timer, compressor or thermostat. This is all that's left.
Please rate solution
Sep 16, 2009 | Amana ASD2326HE Side by Side Refrigerator
Not Cole -- fan inside are blowing room temperature air
If after freeing the fan blade it still will not turn, you have a bad fan motor. (almost certainly due to it being restricted.)
That will cetrtainly cause it not to cool properly.
If the fan will not turn after freeing it, it will need to be replaced. If it does turn properly, unplug the fridge for about an hour to let the compressor cool down. Make sure all the coils vents etc are free of dust and dirt. Plug it back in, and if the fan is still operating properly, you should be back down to temp in a few hours max.
Aug 31, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The refrigerator is prety warm and the ice maker
Sounds like a defrost problem. Is there any frost is the freezer? Do you hear a fan in the freezer? Does the fan and compressor run on the bottom? If the fan doesnt run then the compressor will go out on overload.
Aug 14, 2009 | Refrigerators
Whirpool Refrigarator Compressor Very Hot Will Burn You and Is not Cooling Properly It is letting freezer melt and not barely cold inside
hey
you either have 3 things an over heated compresser, this wouldnt allow the compressor to cool anything beacuse it has an overload which kicks out once the compressor is too hot, and the compressor doesnt work without the overload. solution: get some paper towels, UNPLUG THE FRIDGE, and run some cold water on the towels and use them to cool the compressor, i like to get like 4 or 5 towels wet them and put them on top of the compressor and get another 4 5 towels wet them put the un the bottom front of the compressor. than use another 4 5 towels and cool the front by just rubbing the middle front. keep repeating this until your compressor is not hot anymore like luke warm or better than buy a 3 in 1 its like 20 dollars and install that ( if you need help i will be more than willing to walk you trough it over this or you can call me too)
and the second thing that it can be is overheated compressor due to the condesner fan not working, and thats simple fix just see when you turn on your fridge and turn the dials all the way up to 9 or w.e option you have. see if the fan by the compressor is working if not replace it its also like 20 bucks
or 3 the worst case scenerio free-on leak it has no freeon and the compressor keeps keeeps working to cool the fridge but it cant without freeon so due to the excessive working lol the compressor overheats and shuts off  if thats the case buy a new fridge
if you want to email me with a response  please do so at manison88@aol.com
Jun 06, 2009 | Whirlpool GD2SHGX Refrigerator
Refrigerator/freezer gets warm intermittently
sounds like your thermostat is faulty
the thermostat reads the temperature of the cabinet and controls the temperature
the 1 thing to check on the uprights is the evaporator is in the freezer and that makes the cool then there is a fan that blows the air around the fridge and freezer to freeze things
now there is a cycle that hapens to cycle usualy every 12 hours and that is the defrost cycle
this cycle turns off the compressor and fan turns on an defrost element on the evaporator and heats up the coils to get rid of the ice
the ice turns to water and runs through a drain to a evaporator tray and when the cycle is finished the fridge stars up again and goes into the cooling state again
when the thermostat decides that the fridge is cold enough it turns of the compressor and so on it goes through the cycles as required
if the drai is blocked or the defrost system is not working the evaporator will get choked with ice and the fan will not beable to let air through to cool things off
Jan 25, 2008 | Refrigerators
GE Energy Star SDL20KCSBS Bottom Freezer Refrigerator Logo
318 people viewed this question
Top Refrigerators Experts
KJ4QOB
Jim Akins
rodney bartholomew
Level 1 Expert
