Question about Pride Mobility Products Used Jazzy 1120/2000 Electric Wheelchair
Wheel chair just stopped as if the switch shut off
I have a shoprider electric wheel chair and it was working well it just
stopped as if you shut the switch off now if i turn the switch on i
cannot shut it off and nothing happening when i move the lever to go ahead or reverse my my batterys are ok where can the problem be.
if i had a wiring diagram i could check the circuit
maybe you came across this before
thnks
  • 175 Answers
Most of the Shopriders use a PG Drives VSI joystick/contoller which incorporates the controller into the same case as the joystick. It will have a large wire about 7/8" diameter coming out of the joystick if it is this type. You probably didn't blow the circuit breaker as there wouldn't be any lights, and all of the fuses should be okay too for same reason, but go ahead and check them. If They are all good, then you most likely fried the VSI joystick/controller. Here's a link to PG Drives site.
http://www.pgdt.com/ Good luck.
Posted on Jul 24, 2009
Where to purchase a new reset switch for my jazzy
Posted on Jul 23, 2011
I have a shoprider steamer. It wants to turn right when I push the stick forward or backwards. When it does go forward, there is a kind of jerking to it. If goes left fine. On and off problem.
The free wheel levers have got to be in drive mode. if one is in drive and the other side is not then the chair will try to go in circles. So if the right side free wheel lever is not in drive position then the chair will try to drive to the right because the right motor is not turning the wheel. The wiring to the right motor may have become disconnected.
Oct 10, 2016 | Shoprider Health & Beauty
My shoprider fpc is flashing 6flash 2sec. off 6 again DL5.2i controller can anyone tell me how to find the codes or tell me what this one means.
A 6 blink means the motors are in free wheel position. Turn chair off put freewheel levers in the locked position. You should not be able to push the chair when the motors are engaged. Leave the levers locked then turn the chair on again. If that does not work the motor/s could be unplugged.
Aug 12, 2015 | Shoprider Health & Beauty
My shop rider wheel chair is fully charged but won't but won't start
I HAVE A SHOP RIDER ELECTRIC SCOOTER.IF ITS THE SAME,
IS IT IN GEAR,ON MOST SCOOTERS THE LEVER IS UNDER THE REAR BUMPER AREA
Aug 01, 2015 | Shoprider Health & Beauty
Free wehee lever repair
The free-wheel lever actually disengages the automatic electric brake so that the chair can be pushed. The brake is what holds the lever in either neutral or drive. Could be that your electric brake is shot.
Apr 07, 2014 | Shoprider Wizz Power Chair 888WNL by
Constant beeping when turned
The freewheel lever isn't re-engaged properly. Try moving the lever to "free" then back to "drive" again. The lever moves a small micro-switch.
Apr 02, 2014 | Electric Mobility Health & Beauty
Shoprider power chair won't move and 8 Battery LED Lights are flashing
Code 8: Controller problem. Also, check to see if your gearbox levers are engaged - if you can roll the chair by hand the gearbox is not engaging the motors.
Mar 20, 2013 | Pride Mobility Products New Pride Mobility...
I need a user manual for a shoprider venice powerchair
Hello Patricia,visit:Shoprider.com,scroll down to [contact us] im sure they will be able to help you.Hope this has helped you,have a nice day.Colin.
Nov 02, 2011 | Health & Beauty
Shoprider nippy powerchair when i switch it on lights on control flash and it keeps beeping
Here are some ideas :- Is the charger disconnected from the chair, are the brake levers in the drive possition. do the batteries need charging. Failling that it could be a controler fauld so you will need to consult an engineer.
Apr 30, 2010 | Electric Mobility Shoprider Electric Power...
Shows full charge,goes ok for a little while but then stops turn off then on goes very slow for seconds then stops again.
Hi Susan, I repair power wheel chairs, Its possible that your chair has a bad battery on it , all p/chairs have 2 batteries.And even though you show a full charge one battery may have a bad cell in it you need to get both batteries load tested . I think you my find one of them bad. take them out of chair and have them tested.You can get replacement batteries , and have yours tested at a store that sells batteries only, look in yellow pages for a battery store . Good luck, Erik
Mar 01, 2010 | Electric Mobility Shoprider Electric Power...
Pride Mobility Products Used Jazzy 1120/2000 Electric Wheelchair Logo
525 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
