Question about Frigidaire FEF366 Electric Kitchen Range
Sometimes oven will trip circuit breaker
Oven sometimes trips circuit
    Top Expert:
  • Frigidaire Master
  • 76,848 Answers
HAVE THE CIRCUIT BREAKER TESTED, ALSO HAVE THE WIRING CHECKED IN THE BREAKER BOX, U COULD HAVE A POOR CONNECTION AND THIS COULD RESULT IN A HOUSE FIRE.
Posted on Jul 22, 2009
2 Suggested Answers
SOURCE: I have a Frigidaire self cleaning electric oven.
I have the same problem. It's happen two times. The first time, it was an unprotected power lug connected to a heating element that makes contact with the metal cover (just under the glass). The breaker tripped and after a careful isolation maintenance it was ok. Last night another f*** spark occurred. This time, the breaker did not trip and the heating element’s warm light are always ON. It’s the same problem on a different position. But it was a thermostatic contact lug shorting whit the f*** metal cover. The main issue is that the glass top is used to maintain isolation gap between power lugs and the casing (grounded). In fact, heating elements are spring loaded to reduce the spacing between glass and elements. If a pressure is made by the counter-top the glass is forced to un-bond (my case) and elements can move, make short-circuit and burn down my house.
Regards,
Dave
Posted on Nov 10, 2009
Flavel milano e50. Why does everything except the oven work?
Check the circuit breaker for the oven. 220 volts are necessary for the heating element. 110 volts for the light and clock controls. The 220 volt breaker looks like two side by side breakers with their trip levers joined. Sometimes one will trip without tripping the other. Try resetting the breaker or better yet replace it.
Feb 02, 2016 | Ovens
Main oven wont come on or the light but the fan does
Hi, I hope I can help you. If you're referring to the overhead fan above the oven, that fac is usually on a separate circuit. The oven itself is connected to a separate circuit breaker, hence, that is why the oven and light won't come on.
Check your circuit breaker box, and see what circuit has tripped. Check to see if there are any burn marks around the breaker before resetting it.
The reason the breakers may trip, is the breaker is old, may have the incorrect rating, or may be linked to other circuits, such that when too many items are all drawing power at once, it will trip the breaker.
Keeps tripping circuit breaker
There must be a fairly major issue with your microwave to trip a 20 amp breaker. I would recommend taking it to your local repair shop or replacing it.
Mar 19, 2014 | Oster OGB81101 1.1-Cubic Foot Microwave...
Oven not heating properly
most common problems:
1. calrod unit not working(heating element) easy replacement
2. breaker tripped.(sometimes a double breaker will only trip one of the circuit breakers so you end up with half power)
good luck
Jul 19, 2013 | Whirlpool Ovens
Broil trips circuit breaker every time
I would start by replacing the breaker. They do become weak over time.
Dec 05, 2012 | GE JRP28 Electric Double Oven
Oven heats up but wont get above 160 degrees
I assume you mean it trips the circuit breaker. If the circuit breaker is good, that means the heating coil is bad, and pulling too much electrical current. Sometimes circuit breakers fail, and trip at say 5 amps when rated at 15 amps. Have you electrician switch that breaker with another one and see if there is a difference. If not, it is a bad heating coil.
Oct 19, 2012 | Bosch HBN5046AUC Electric Single Oven
Lg microwave oven trips circuit breaker
The magnetron probably has a partial short pulling more current than normal as it runs, the other two items that give trouble is the high voltage diode, "sometimes cracks" to the high voltage capacitor, "usually shorts"
Mar 29, 2012 | LG Microwave Ovens
Gas oven - electric igniter - trips electric
you have cleaner inside the glow coil marrets and it is probably causing a short circuit and tripping breaker
Feb 06, 2010 | Ovens
My microwave oven keeps tripping the circuit breaker.i replaced the outlet that it plugs into but it still trips it. is there an internal fuse in the oven that may be bad?
If a fuse inside had blown, that would definitely reduce the current flow rather than trip the breaker.
I have replaced several breakers over the years; they no longer last forever.
Try your Amana on a different circuit, not in the kitchen; if that other circuit likes the oven, the breaker is bad. If the alternate circuit breaker also trips, then you have not a blown fuse in the Amana but rather a shorted component inside and repairing the oven will likely cost about the same as replacing it.
Nov 22, 2009 | Amana Radarange Microwave Oven
Oven won't heat up until circuit breaker is tripped.
This is a very serious hazard if the circuit breaker trips just when the oven begins to heat up. The circuit breaker could have become weakened and needs to be replaced ASAP. Have an electrician check and replace.
The oven could have been placed on too small a circuit breaker OR the total number of appliances on that line has pushed the circuit breaker over it's limit. The Oven draws a huge current and may be the straw that broke the camels back.
Check to see what other appliances are shut down when the breaker trips. See if you can place some or all of these on another line.
Leaving the Oven on the one circuit breaker. This will hopefully prevent the overload situation that is occurring now.
If it still trips... get an electrician in there fast!
Hope this helps!
Oct 04, 2009 | GE JBS55 Electric Kitchen Range
Frigidaire FEF366 Electric Kitchen Range Logo
644 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
