Question about Kenmore Dryers
It makes 2 drum turns and then shuts off. Kenmore Soft Heat Serial M95130041 Model Stock # 87874100 Gas 22000 349573 42-98317 STD 398317 687759 7390796 78741 ALL the number we can find on the dryer and I cant figure it out or find a manual
  • 156 Answers
SOURCE: Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Posted on Mar 19, 2008
zeusfaber
  • 247 Answers
SOURCE: Kenmore clothes dryer model number
My instinct on this one is to look for a thermal cutout and to try to reset it.
Not familiar with the layout of the Kenmore 110's (they're not marketed in this part of the world), but a good place to start is probably inside the top of the machine.
Before fiddling, turn the power off and unplug the machine.
Look for a metal duct leading into the drum housing. This will probably have the blower mounted at one end, then the element embedded in it, then, before it leads into the drum housing, a collection of thermostats and safety cutouts (usually one or two of each) mounted on the outside of it.
Safety cutouts and thermostats are likely to look something like one of the pictures at http://www.tdspares.co.uk/products.asp?cat=68
Start by looking for cutouts with reset buttons - press the button on any you find and see if this fixes the problem. It's a good sign you've found the right one if it clicks when pressed.
If that doesn't work, use a multimeter to test across the contacts of each thermostat and cutout in turn. They should all have a very low resistance. reset or replace any that don't.
Once you've got the machine working again, you need to find out what made things trip and eliminate the underlying problem. This is usually a matter of cleaning all the accumulated lint out the machine.
Good luck.
A.
Posted on Sep 13, 2008
SOURCE: kenmore gas dryer after 5 to 10 min. later no more heat
Yup, shortly after I posted this question I was able to find that it was indeed the valve coils. Very easy to get to and replace. Cheap too! Got both of them for about $20 thru www.appliancepartspros.com. Same parts would have cost about $70 thru Sears direct.
Patrick, they are located on the burner unit under the drum in the front left. You can get a diagram of the burner unit by looking up Parts for your model # at Sears.com.
Only tricky thing is you may need to have someone help hold the tumbler in place when you put the belt back on the motor. Personally I found it easier to use two hands to manipulate the belt around the motor and tension bracket and have my wife hold the drum in place rather than to try and balance it myself.
Posted on Oct 27, 2008
onthejob5130
  • 640 Answers
SOURCE: Lady Kenmore Dryer Making Loud Screeching Noise When Drum Turns
defective rollers..replace
Posted on Jan 29, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Kenmore gas dryer not getting hot enough
Have you checked the lint trap and also the vent hose? If you have yet to do that try it. Also make sure that the vent line is not crushed. It needs to be wide open
Posted on Feb 10, 2009
I have a Kenmore gas dryer purchased in 1989 which shuts off half-way through the cycle. This is a heavy duty, soft heat unit, model #110 87874800 serial #MX0816640.
Your motor is overheating and shutting off on the limit switch. You should check the vent hose, it needs thorough cleaning. Also, you must take the front panel off and vacuum the inside of the dryer and around the motor. It may be too late for the motor but you have a chance. If you have an air compressor, it is best to blow high pressure air into the motor to get thorough cleaning.
keeping the vent and inside of the dryer clean can reduce drying time by more than 50% and operating cost by as much as $20.00 per month
Oct 13, 2015 | Kenmore Dryers
Kenmore 70 series model #97573200/stock # 75732. It's a gas dryer with an electric igniter. The problem is, dryer runs but there is no heat. I'm thinking there's a problem with the igniter? ...
if the ignitor is lighting up, the problem is going to be in the coils that are attached to the gas valve itself, heres what they look like http://www.applianceaid.com/images/2coilsgenaralgas.JPG
Jul 04, 2011 | Kenmore Dryers
Dryer isn't heating. It turns and blows air but
make sure lint screen and vents are clean. next shut off electric and check heat element for broken element. then get model # and serial # order and change thermocutoffs located on heater box and fanhousing ck these steps one by one
Dec 09, 2009 | Kenmore 75962 Gas Dryer
Kenmore dryer shuts off after five minutes
The vent box inside the dryer still has lint in it. You need to reach way inside to get at it. Turn power off.
Jul 22, 2009 | Dryers
Drum turns, no heat
either the heating element or the thermal fuse very worst case would be the timer but i have all parts in stock whirlpoolpartssurplus.com
Jun 24, 2009 | Kenmore 63942 Dryer
Kenmore dryer will not heat
only 2 things can be wrong, the heater element is toast or one of the safety thermostats is fried, most likely it is the heating element. make sure its well connected(while unplugged!!!)
Jun 14, 2009 | Kenmore 63942 Dryer
Feb 10, 2009 | Dryers
Kenmore gas dryer that turns but does not heat up
No heat at all? does the top of the machine heat up, but not the drum? could be your drum seal is damaged or slipped off.
If the firebox doesn't light up, could be your igniter, the unit's safety switch, thermocouple, or regulator; Your Gas Company may provide a service that would check it for you... some do.
Jan 02, 2009 | Kenmore 74602 Gas Dryer
Gas dryer will not heat
The dryer will not heat i check the vent to make sure no upstruction and open the back to make sure no wire was lose. where will the fuse be kenmore model 76722697 serial No. 0702383
Sep 13, 2007 | Kenmore 93042 Gas Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
