How do you remove a evaparatore core in a 1992
How do you remove a evaparatore core in a 1992 Chevy 1500
  • Michael Pippins Jul 22, 2009
    I'm am starting from ground zero but it looks like the evaparator core in right behind the heater core
    Thanks for the solution Really appreciated it.
    Top Expert:
  • Heating & Co... Master
  • 76,649 Answers
You must already know that in order to replace this part u must remove the entire dash assmeby, but this is a common problem and there is a repair kit for the evaporator core made by a company called FOUR SEASONS THE PART NUMBER IS 1649, PRICE AROUND $30.00 GO TO LINK BELOW TO LOOK AT KIT.
http://www.diypartscatalog.com/ShopByVehicle.epc?q=1993-CHEVROLET-Pickup--C1500--Ss454--4x---V8--454ci--7.4l--F/i--Vin--N-Heating/ac&yearid=1993%40%401993&makeid=16%40%40CHEVROLET%40%40B&modelid=3068%40%40PICKUP+C1500+SS454+4x2&engineid=12837%40%40V8%2D454ci+7%2E4L+F%2FI+Vin+N%40%4012837&catid=6%40%40Heating%2FAC&subcatid=97@@Condensers+and+Evaporators&mode=PA
Posted on Jul 22, 2009
  • 3,037 Answers
Basically this part is located under your dash a little more towards the passenger side of the truck. You should have the A/C discharged before starting work on this truck. You need to remove most of the dash, starting with the plastic parts on the front/bottom. Most plastic parts will be held on with clips at the top and bolts at the bottom of the panels. The metal components will be held on with bolts. All bolts should be metric and I recommend pulling out the front seats to give yourself some extra room to work with. I also recommend that you pull things off and keep them in order with their screws and bolts (possibly lay a tarp out and mark anything that you think may be helpful to remember when putting it back together and/or take pictures). This is a lengthy process and the evaporator core is all the way in next to the firewall in its own housing with the blower motor that you will need to take out.
Before taking the housing out, you will need to unbolt the evaporator core from the a/c lines under the hood which should be center/passenger side of the truck right next to the firewall (make sure you replace the o-rings, new ones will come with the new evaporator core which I assume you are replacing). There is no easy way to replace it, just make sure you disconnect the negative battery terminal before starting work on it and start making your way towards the core one part at a time marking any wiring as you go (masking tape and a marker works wonders). You may not have to remove the whole dash and the steering wheel, but it will make your life easier. If at any time you get stuck, please post a picture of the problem and I can advise. (If the picture won't post, try making it smaller first, which can be done in Paint). Let me know how this turns out.
Benjamin
  • Benjamin Patri
    Benjamin Patri Jul 22, 2009
    yes the evaporator core will be right next to the heater core and they will both be by the blower motor and all will be under the dash. Where is the problem in my solution? Do you need clarification somewhere?
Can't locate fuse in fuse box for a 1992 Chevy 1500 pick up
What are you trying to find? Fuse or fuse box?
Dec 20, 2012 | Cars & Trucks
I need to change the heater core on a 1995 Chevy 1500. Just wondering if I have to go thru the glove box or thru the duct under the dash?
The heater core is located in the bottom half of the duct work. If you remove the screws from the bottom of the duct you will see the heater core the core on the right by the door is the ac or evap. core for the air conditioner.
Jul 23, 2012 | 1995-1997 Chevy 1500 Truck Ignition...
Will a computer off of a 1992 chevy 1500 with a 305 work on a 1992 chevy s10 with a 4.3l
No it will not. One is for 8 cylinders and the other has 6 cylinders.
Apr 23, 2012 | Cars & Trucks
92 chevy 1500 silverado Changed thermostat,heater core, core hose not hot. No heat
It sounds like your heater core is stopped up. try flushing it out, you can use a water hose. and if you cant get it to clean out then you will need to change the heater core.
Oct 17, 2011 | 1992 Chevrolet K1500
1500 CHEVY PICKUP 1992 HOW TO INSTALL A/C EVAPORATOR COLE.
any 10 mm bolt on firewall remove, any bolt coming from inside must b removed,,now take battery loose,,remove hoses from heater core,,,,,,remover dryer lines and remove all lines from evaporator,,,drop steering wheel as low as u can,,remove kick plates on both sides and there is a 13 mm bolt on each side of corner of dash behind kick plate,,,,take 5 7mm bolts from dash and roll dash over and take passenger side off it slider and pull backas far as u can gently,,,,,not try to move box and take firewall bolts out till u can move it and flip it over to remove evaporator,,,,,,,,it is not that hard to do,,,,now reverse way of doing ,,,says it takes 9 hours,,,it will take 8 to 10 or maybe 12 to us that dont do it regular,,,,,,what i found and i have to undo my dash again is the door is stuck and io dont know how to fix it,,but i want to learn and will
Apr 12, 2011 | 1992 Chevrolet K1500
I have 1999 chevy truck 2wd 1500 need to replace the heater core need help
If i remember correctly you will have to remove the dashboard to get to the a/c box on these trucks. Then you need to disconnect the heater hoses and remove the a/c box. Then take the A/C box apart and replace the heater core.
Jan 20, 2011 | 1999 Chevrolet Silverado 1500
How do i change the heater core on my 1999 chevy silverado 1500?
Inspect/Replace If it is necessary to remove the heater assembly, the cooling system must be drained before removing the heater core.
When a heater core leaks, a new heater core is installed or the old one repaired.
Heater Housing
  • The heater housing is usually under the dash and must be removed to gain access to the heater core.
  • Procedures for replacing the heater core vary with the year, make, and model of car. It threfore necessary to consult the manufacturer's repair manuals for the proper procedure for replacement.
f74-01.gif The heater housing is disassembled to get to the heater core. Heater Core
  • Remove the access panels(s) or the split heater/air conditioning case to gain acess to the heater core.
  • Remove the heater coolant hoses.
  • Remove the cable and/or vacuum control lines (if equipped).
  • Remove the heater core securing brackets and/or clamps.
  • Lift the core from the case. Do not use force. Take care not to damage the fins of the heater core when removing.
  • To reinstall the heater core, reverse the removal steps.
When the heater core leaks and must be repaired or replaced, it is a very difficult and time-consuming job primarily because of the core's location deep within the firewall of the car. For this reason always leak test a replacement heater core before installation.
Dec 11, 2010 | 1999 Chevrolet Silverado 1500
How to change heater core in 92 chevy pick up
unfortunately the fastest easiest way is usualy to remove the entire dash and its about a 2 day job
Feb 11, 2010 | 1992 Chevrolet Caprice
How to replace a heater core in a 1994 chevy 1500
As with all vehicles it seems the first part that they build around is the heater core. It is under the dash above the floor housed in a black plastic sealed box. Sealed with goop. Locate that box and start removing everything around it that is peventing taking the cover off. Of course disconnect the heater hoses under the hood a thefirewall.
Warning it is never as easy as it sounds.
Nov 29, 2009 | 1999 Chevrolet Silverado 1500
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
