Question about HP w2207 Monitor
Is this broken and how too fix?
MY SON WAS TURNING OFF MONITOR AND PUT HIS RIGHT HAND TO TURN OFF THE MONITOR AND PUT HIS THUMP ON THE SCREEN IN THE BROWSER AREA AND NOW WE HAVE COLOR STRIPS GOING DOWN AND WHITE OUT AREAS OF 4 TO 5 INCHES, IS THERE ANY WAY TO FIX THIS. hE SAID HE PUT PRESSER WITH HIS THUMP, HES 15 AND WAS ANGRY BECAUSE HIS GAME WAS SLOW.
    Brigadier General:
  • 4,090 Answers
Anger management course is needed, possibly for your reaction to the account he has created for you by losing his temper. He has damaged the delicate plasma envelope which renders the monitor unusable. A new monitor may be cheaper than a repair. Perhaps he can work of the debt he has caused by doing chores around the house until he learns to stop spending your money.
Posted on Jul 22, 2009
How to turn off monitor
1. Go to the desktop
2. Right Click
3. On that list, you should click personalize
4. In the lower right hand corner, click Screen saver (It's in blue letters)
5. In the bottom left hand corner of the window that just popped up, click "Change power settings"
6. In the left side of the new window, (It's in the light gray area) click on "Change when the computer sleeps"
7. Then from here you can set when you want to turn off the display and or put the computer to sleep after how long you have been inactive.
8. Remember to click the "Save changes" button to save what you've done.
May 25, 2014 | Total Gym Cyclo Trainer
Blank Screen Sonly VAIO Tap 20
Is there a flashing cursor in the top left hand side of your monitor?
Aug 12, 2013 | Sony Vaio Tap 20
My washer mad three loud thumps and then would not spin at all. It will pump the water out but will not spin. Do you think it is the belt. Thanks helyn
The belt might have slipped off the pulley. But when you mention that you heard loud thumps before it stopped spinning is a sign that something else might have gone wrong with your machine. With the washer turned off, turn the wash drum by hand and listen for any noises. It should turn quietly without any kind of thumping noises. Also look how the drum turns. It should turn smoothly and not wobble as it turns. If it wobbles or makes thumpiing noises, it means that the support arms are broken.
Reparing the support arms is an expensive repair, unless it is still under warranty, it not worth fixing. Get a few estimates before deciding to repair or replace it.
Feb 08, 2011 | Frigidaire ATF6000ES Front Load Washer
My son just hit his rattle into the screen of my flat panel tv. when turned off it looks fine but when its on you can barely see the picture in the top right hand corner but the spot that he hit it it...
Ur tv have a broken LCD screen panel.Not worth fixing,because the LCD screen panels are limited produced,will cost the same as a new tv,if replaced.Only can buy the LCD screen panels from the tv corporations.Sorry,worth as a whole tv any more.Now ur tv,only worth as salvage for eclectronic boards.
Aug 15, 2010 | Televison & Video
During the spin cycle there is a very loud knocking noise,
Could be the spider arms are broken. You can confirm this by turning the tub by hand, if you hear any kind of thumping sound as you turn the tub, then the spider is broken. The spider is the support arms that hold the wash tub to the drive shaft. It's very expensive to repair.
If there is no thumping sound when you turn the drum, it could be that one of the supports or spring is broken. Hope this helps.
Jul 23, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
Screen has turned sideways
Right click on an empty spot on the desktop and scroll down to either the Nvidia or ATI control panel. Once you are in the control panel, look in the left hand pane and look for something that says, screen orientation or screen rotation. When you select that it may give you the orientation in degrees of a compass or rosary. Make sure you place the monitor orientation at "0" degrees. This will bring the screen back to normal.
May 16, 2010 | Tatung LD23HL Monitor
I see a black screen when I turn thw computer on
The first thing to do is to check the lead from the monitor to the computer is correctly plugged in at both ends.
If this is OK then perhaps you try another monitor, if an other monitor works OK then yours may be broken.
If another monitor does not work then you will need to check your computer hardware and software.
Oct 30, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Pontiac Grand Am Popping sound when the wheel is turned
sounds like a half shaft to me try turning in a tight circle and see which side it clicks on left or right
make circles in both directions
Apr 15, 2009 | Pontiac Grand Am Cars & Trucks
Screen problem
bad panel if it's cracked
Apr 27, 2008 | Vizio L32 32 in. LCD HDTV
Screen split into 2 colours - vertical split
I think it is degaussing problem if any thing is lying which has magnet please remove it. &then put of monitor for 15 minutes & then put on again.do not move when it is on. please let me if it gets ok good luck
Sep 09, 2007 | Philips 170B4MG 17" LCD Monitor
HP w2207 Monitor Logo
97 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
