Wireing the wires back on to the speakers and the mike
What colours go to where what are the speaker wires and what are the mike wires.
You posted this on an IP phone system forum.
What phone do you have?
Posted on Jul 27, 2009
Have a 1988 Chevy Cheyene p?u with a Am radio in it now. Want to install a factory AM/FM radio. AM has a solid wire going to radio. How do I hook up AM/FM with clip?
Following are colour codes for your radio curtesy of;
Source(s): GM dealer tech over 30 years. HyperGforce
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
The solid wire (casing) would enclose a number of thinner wires that may or may not include these colour codes.
You have to match up the wires and their functions in your new radio with these colour coded wires, have fun..........
Oct 16, 2017 | Car Audio & Video
Speakers
Could you specify the model of the Sanyo speakers?
Jun 11, 2013 | Audio Players & Recorders
1985 toyota carolla csx need wiring colours for radio
1985 Toyota Corolla Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Blue/Yellow
Radio Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Green
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
Nov 04, 2012 | 1991 Toyota Corolla
Original wiring in car for stereo what goes where?
This are the colours 1993 Ford Thunderbird Car Radio Wiring Diagram Car Radio Battery Constant 12v+ Wire: Green/Yellow Car Radio Accessory Switched 12v+ Wire: Yellow/Black Car Radio Ground Wire: Black/Light Green Car Radio Illumination Wire: Blue/Red Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: Orange/Blue Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: 5′ x 7′ Car Audio Front Speakers Location: Doors Left Front Speaker Positive Wire (+): Orange/Green Left Front Speaker Negative Wire (-): Black/White Right Front Speaker Positive Wire (+): White/Green Right Front Speaker Negative Wire (-): Black/White Car Audio Rear Speakers Size: 5′ x 7′ Car Audio Rear Speakers Location: Side Panels Left Rear Speaker Positive Wire (+): Pink/Green Left Rear Speaker Negative Wire (-): Pink/Blue Right Rear Speaker Positive Wire (+): Pink/Blue Right Rear Speaker Negative Wire (-): Green/Orange
Jan 08, 2010 | Car Audio & Video
Wire colour coding for radio Holden Nova LF
Car Radio Constant 12v+ Wire: Blue/Yellow
Car Radio Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Antenna Trigger: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Negative Wire (-): Blue
Left Rear Speaker Positive Wire (+): Black
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Aug 30, 2009 | 1994 Toyota Corolla
Need help with speaker wire colours
if i read that right.. just leave the wires in place and run new wires through the door and into the dash behind the deck.
speakers only have 2 wires a (+) and ( - ) the positive and negative can be hooked up backwards at the speaker and you will still get sound just fine.
many audio installers i know dont even bother looking at what wire is what as long as 2 wires are running to the speakers
if you want to TEST a possibly bad wire use a Multi meter and check Continuity through the wire.
Mar 16, 2009 | Car Audio & Video
Info on what colour rear speaker wires are on 2005 pontiac g6
Here are the radio wire colors of the whole system, please rate this solution.
2007 Pontiac G6 Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red/White
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power or use the brown wire (+) at the ignition wire harness.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Pink
Jan 06, 2009 | 2007 Pontiac G6 GT Convertible
Car radio harness colour code
work it out with a meter ,,,,find perm 12v feed neg and pos ---yes could be any coloured wire depending on car maker,after finding perm 12v feed for memory look for pos from ign switch,now speaker wires are easy as both will be same colour for a speaker but one will have a band through it if not sure or colour blind like yours truelly then use pos and neg on speaker wire till you hear a thump from speaker then you know you have the right wires and location of speaker ,,ie.. front left back right ect ....Now you are a fully experianced radio fitter ??
Dec 20, 2008 | 1993 Nissan Maxima
Wires snapped
HI,
Sure They Can. just ensure Red To + Positive. And Black To Negative. Or If Colours are Different determine which is + Positive.
these can be resoldered on, using a standard 15-25 watt soldering iron.
Mike @ compurepair.
May 10, 2008 | Kicker S10L52 Car Speaker
Wiring diagram for Altec Lansing Vs4221 Right Speaker Wire
red-positive . blue-negative and if another colour mostly brown-Earth.
Jan 15, 2008 | Altec Lansing VS4121 2.1 Channel Powered...
Computers & Internet Logo
David Payne
David Payne
