Question about LG Vu Cellular Phone
Cant set up voicemail - LG Vu Cellular Phone
Cant check voicemail,tap and hold it asks for name and centre no? also voicemail icon at top of screen cant get rid of.
name and centre no,./ this phone # is provided by your cell phone provider, call and ask for your voicemail box #. they will help you set up. call from land line so you can enter info as provided once this is programmed when you press it it will call your voicemail
Jan 01, 2011 | Samsung Wave S8500 Smartphone
I cant seem to set up my voicemail. I dial 1 to enter voicemail and I get two options enter # if you have a voicemail generated enter 10 digit number of person you are trying to call
You will need to contact your service provider to have the voicemail retrieval number programmed into your phone. They can also reset the voicemail feature since it has not been set up yet.
Mar 04, 2010 | Samsung SGH-A877 Impression Cell Phone
Voicemail cant set it up on LGShine KE970
you need to contact your serve provider o2.
Jan 03, 2009 | LG Shine KE970 Cellular Phone
Cant set voicemail up
Call customer service something odd is happening you don't need to re-set up voicemail moving your SIM from one phone to another. If the phone is one not from your carrier it might not be programmed for your carrier's number when you press and hold 1 to dial voicemail
you need to check and see if your keypad in settings is set to continuous if not set it to that.
Aug 11, 2008 | Motorola Mobility RAZR V3
Turning off the voicemail message
Well for samsung phones you can go to call settings, then call diverting then go to cancel all, the voicemail will turn off then.
Jun 08, 2008 | Samsung SGH-ZV40 Cellular Phone
Voicemail
It is usually under message menu. try under setting of this menu. Alternatively you can use one more method that will sound funny but works. Press and hold the No. 1 key and see which number it is dialing. If the voicemail is already set it will be shown to you, edit this from the phonebook to your desired number. If the Voicemail has not already been set you will be prompted to enter you the voicemail number. Fill in the desired number there.
Feb 06, 2008 | Sony Ericsson K510i Cellular Phone
Razr v3 setting up voice mail
Which mobile service carrier do you use? Are you trying to setup voicemail to play your messages on your phone, or are you trying to setup greetings and what not inside of the voicemail?
Your voicemail settings depend on where you live, and there are hundreds of different access numbers. If you are trying to setup the phone to connect to voicemail and are on Cingular/AT&T, call them at 800-331-0500 from a different phone and they can walk you through the setup easily since they have access to the appropriate voicemail access number for your location.
Dec 17, 2007 | Motorola Mobility RAZR V3
I want to change the # to access my voicemail
Go to Main menu, then "Messaging". Within Messaging go down to "Message Settings". #3 is voicemail. click voicemail and you will be able to edit the number.
Oct 25, 2007 | LG Shine KE970 Cellular Phone
LG Vu  Cellular Phone Logo
112 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
