Question about Brother HL-2070N Printer
Paper jammed in my 2070N printer & I don't know how to remove it
I have opened the front and looked at the drum. I can see the paper curling up when I open the back, but I cannot remove the paper. There are no release buttons or rollers that I can see. The paper appears to be jammed between the red roller and the brown roller. I've taken the paper tray out and turned the printer over, but no access. HELP!!
  • vsmith584 Jul 22, 2009
    never mind! I've figured it out.
    President:
  • 2,306 Answers
That machine doesn't have a release lever, you need to pull the paper out, as straight as possible trying not to tear it. There probably is a problem with your fuser, and it will need to be replaced. Even getting the paper out, it will probably jam again on the next print.
Posted on Jul 22, 2009
Paper jams and burn
Lets try the following
  1. If there is no paper, load a new stack of paper into the paper tray.
  2. If there is paper in the paper tray, make sure it is straight. If the paper is curled, you should straighten it. Sometimes it is helpful to remove the paper, turn the stack over and put it back into the paper tray.
  3. Reduce the amount of paper in the paper tray, and then try again.
  4. Check that the MP tray mode is not chosen in the printer driver.
  5. If the LCD shows Paper Jam message and you still have a problem
Or try
  1. Pull the paper tray completely out of the machine.
  2. Use both hands to slowly pull out the jammed paper.
  3. Press the cover release lever to open the front cover
  4. Slowly take out the drum unit and toner cartridge assembly. The jammed paper may be pulled out with the toner cartridge and drum unit assembly, or this may release the paper so you can pull it out of the paper tray opening.
  5. Put the drum unit and toner cartridge assembly back in the machine.
  6. Close the front cover.
  7. Put the paper tray firmly back in the
Or leave a Voice mail we'll check what we can do
Jul 26, 2014 | Canon Genuine Oce Imagistics Fx3000...
Paper red light blinking. paper is full. What could be wrong? Will not print
Paper light flashing could mean several things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Jun 12, 2010 | Brother HL-2070N Laser Printer
Red paper light is on even though there is paper in the tray. brother 2040 model.
This is a paper jam. Remove paper try as well as the toner/drum unit. Take vacuum and clean out inside the printer. Separate the toner & drum units and vacuum-blow out the drum unit to get it clean. Run the drum wire cleaner tab (purple/blue tab at front of the drum unit) back & forth a number of times. Sounds like you've got a piece of paper stuck inside somewhere. In the back of the printer, there is a door that will open out and down...check here for a speck of paper that is causing the paper light to come on...it "sees" something is in the way) since this is where the paper curls up and out the top. Reassemble toner/drum unit. Before you put the paper tray back in, take a piece of paper and feed from the front (use light card stock or heavy weight paper since this will help push out anything inside that's in the way) and print a few pages this way. Then, make sure your paper is dry (hasn't been in humid area) and is lying flat (not curled at edges). That should do it
Dec 21, 2009 | Brother HL-2040 Laser Printer
Paper jam
take out cartridge and force paper to take out sometimes it is needed to tear paper to take it off but no problem, main sensitive for this type of printers is cartridge, also find if any "jam lock" is presented to ypur printer and unlock.
Aug 01, 2009 | Brother HL-2070N Laser Printer
Paper jam
Please open the front cover and remove the drum to check the jam. If not in the drum, then check the back cover, open it to remove any jammed.
May 12, 2009 | Brother HL-2070N Printer
How do I remove paper from paper jam?
To remove paper pull the paper with both hands being careful not to tear the paper . If you're unable to pull it you may need to manually rotate the gears that feed the paper through the printer
Now reset the printer by pressing the power button in on state to turn it off and restart
again thats all just take care that you remove the tray carefully
Thanks and Regards
Brother HL-2070N red "paper" light flashes after a paper jam
http://welcome.solutions.brother.com
Try this
[LED Indication]
The Paper LED is flashing.
Meaning of LED Indication
Front cover is open:
Close the front cover of the printer.
Back cover is open:
Close the back cover of the printer.
Paper jam:
Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
No paper fed manual feed slot:
Put the paper back in the manual feed slot.
Memory full:
The printer memory is full and the printer cannot print full pages of a document.
Print overrun:
A print overrun occurred and the printer cannot print full pages of a document.
Clean drum unit:
The corona wire needs to be cleaned.
Oleg Andrukh IT Specialist
PhillyCopiers.com 215 364 3774
Jan 23, 2009 | Brother HL-2070N Laser Printer
HL-2070N paper LEd flashing
most likely a sensor is tripped, eiher it's stuck or there is something blocking it. the most likely place is in the fuser, back door where paper exits and geta hot. look closely you should see a black lever towards the middle of the fuser, it should be up
Oct 18, 2008 | Brother HL-2070N Laser Printer
Paper curl
When a paper jam occurs, the printer will stop printing and the Continue (1) and Paper Jam (2) lights on the operator panel will come on. See the illustration below.
pattlnk_1052005_1635-enus20238_oppaneljamlights_e230_en_us.gif When you experience a paper jam, it is recommended that you check and clear the entire paper path. To clear a paper jam, do the following:
  1. If you are feeding paper from a paper tray, first remove the tray. Look for and remove any jammed or damaged paper you find.
  2. Open the front cover and remove the print cartridge assembly.
    IMPORTANT!
    Do not leave the print cartridge assembly exposed to direct light, especially sunlight, for an extended period of time. Extended exposure to light will damage the green photoconductor roller and cause print quality problems.
  3. Remove any paper you find jammed in the area behind the print cartridge assembly.
  4. Also lift the flap at the front of the printer and remove any paper you find jammed beneath the flap.
  5. Open the rear exit door/cover of the printer and remove any jammed paper you find there.
  6. Once you have confirmed that the entire paper path is clear, reinstall the print cartridge assembly. Close all the printer covers/doors. Reinstall any paper trays you removed.
  7. Press the Continue button to resume printing. NOTE: The printer should reprint the page(s) that caused the paper jam.
  8. If the paper continues to jam, press the Continue button twice quickly while the Continue and Paper Jam lights are on. This will cause the operator panel to display the secondary error paper jam light sequence. The secondary error code will tell you where the printer thinks the problem has arisen. For more information, see the 'Secondary Error Codes' section on page 69 of the User's Guide.
Sep 04, 2008 | Lexmark E232 Laser Printer
Toner light doesnt go away in our printer and the printer doesnt print. We changed the cartridge please help us
The HL-2070N gets jammed in a toner end-of-life error condition. Perform the following to clear (I have 120 in the field so I know it works!):
With paper loaded, new toner in,
  1. Open front door
  2. Turn off printer
  3. While holding down the GO button, turn printer back on
  4. When all four LEDs light up release GO button. All LEDs will turn off
  5. Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
  6. Press the GO button 5 times
  7. Paper light will be blinking
  8. At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
Mar 11, 2008 | Brother HL-2070N Laser Printer
Brother HL-2070N Printer Logo
148 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
