Question about Orange SPV M600 Smartphone
M600 does not power up after being left in drawer for a month
My M600 doesnot power up after l leave it in a drawer for a month or so. When I plug the charger the LED glow briefly then nothing happens. Anyone knows the cause or has solutions? thanks
  • vinh_dang Jul 23, 2009
    I tried to charge it over night but it did not turn on, even when battery is removed. Anybody experiences similar problems? Please help.
  • 108 Answers
In your case battery might have gone deep discharge first charge your battery properly to full charge then switch on the phone. If you battery doesnot hold the charge then replace the battery.
Posted on Jul 23, 2009
How do you get mildew out of the inside lip of the frigidaire affinity?
Good Afternoon Friend,
I understand you are trying to get mildew out of the inside lip of your Frigidaire Affinity washer, model# ATF6000ES. I suggest following the cleaning suggestions I've listed below.
Clean the Dispenser Drawer Area. Detergent and fabric softener may build up in the dispenser drawer. Residue should be removed once or twice a month.
    1)Remove the drawer by pulling the drawer out until it stops.
    2)Reach back into the left rear corner of the drawer cavity and press down firmly on the lock tab (left rear portion of the drawer). Pull out the drawer.
    3)Remove the insert from the bleach and fabric softener compartments.
    4)Rinse the drawer and inserts with hot tap water to remove traces of accumulated powders and liquids. Large amounts of fabric softener residue may indicate improper dilution or more frequent cleaning is required.
    5)To clean the drawer opening, use a small brush to clean the recess. Remove all residues from the upper and lower parts of the recess.
    6)Replace the insert pressing the "X" to lock it in place. Return the dispenser drawer.
    Clean Inside the Drum
      1)Remove items from your washer as soon as the cycle ends. Excess wrinkling, color transfer, and odors may develop in items left in your washer.
      2) Before cleaning your washer interior, unplug the electrical power cord to avoid electrical shock hazards.
      3)Dry around your washer door opening, flexible gasket, and door glass. These areas should always be clean to ensure a water tight seal.
      4)When extremely soiled items have been washed, a dirty residue may remain on the drum. Remove this by wiping the drum with a nonabrasive household cleanser. Rinse thoroughly with water.
      5)Periodically, wipe dry the bottom of the flexible gasket to remove lint and other debris.
      6)The plastic drum vanes may become stained from fabric dye. Clean these parts with a nonabrasive household cleanser. This prevents dye transfer to future loads.
      Another thing you may do after a thorough cleaning is run a Heavy Duty cycle, and change the temperatures to the hottest temperatures. Also, change the soil level to Heavy Soil. You will want to run a full cycle with no clothes in it and add bleach and your detergent. Once the cycle has completed, Wipe down the inside of the tub as well as the inside lip of your washer. Leave the door open so any other water that might be inside of your appliance can evaporate. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
      -Best Regards-
      WP
May 27, 2014 | Frigidaire ATF6000ES Front Load Washer
Tip
Make your Lithium Laptop Battery last longer.
Hello folks,
Although I usually offer advice on backing up files or recovering them, I have been asked a lot lately how my 3 year old laptop still runs 1:45mins on a standard battery when many peoples 1-2 year old laptops can barely last an hour.
Simply put, most people do one of two things wrong. Both are common misconceptions and easy to remedy. First I've heard countless people tell me they pop the battery out of their laptop and toss it in the desk drawer until needed, often months. Second I have been told by more people than I can count that they leave their laptop plugged in 24/7 for most of the year.
Bottom line, although popping it out and leaving it in the drawer is less harmful to it's lifespan, both ideas are wrong.
The shelf life of most unused lithium batteries is shorter when unused than ones being used properly. The lifespan of a battery that is constantly being trickle charged is even shorter.
Most batteries in modern laptops are 4-6 cells, designed to give about 2 hours of charge and should last 3-5 years with charge life starting to degrade in the third year.
A "stored battery" has only 3 years of shelf life due to extended times sitting discharged and one that is trickle charged 24/7 may burn out in as little as a year.
Many laptop manufacturers have taken measures to improve this but ultimately the best thing for your battery is to use it. If you currently run you laptop plugged in 24/7, unplug it every night after you shut it off, then when you start it in the morning, let it run an hour before plugging it back in. This will give the battery both down time and exercise.
If your battery is in a drawer somewhere for safe keeping, put it back in the laptop, run it down then charge it over night and run it down then recharge it one more time. Store it back in the drawer charged and repeat the cycle at least once a month.
These tips will help drastically improve you batteries performance over time. My 3 year old laptop only ever got 2 hours of battery life and still gets 1:45 with no power saving measures, give it a try.
Crankstart
on Mar 20, 2010 | Computers & Internet
Konica 7075 paper drawers wont open
The 7075 uses a solenoid interlock on all the drawers. The machine must be powered up and not have a jam indicated between the drawer and machine main body. It also will only allow one drawer to be open at a time. There is a manual release lever on the left side of each drawer. The lever is accessible by opening the long, skinny left front door.
Apr 04, 2014 | Konica 7075 All-In-One Laser Printer
Was awakened in the middle of the night by the F&P dish drawers (top drawer) playing the "Star-Spangled Banner" alternately with "Brahms Lulliby", lights flashing, lots of beeping! .....the lights...
Not funny Cindy - Any chance you can access the power breaker in the panel for the dishwasher? Sometimes with even short power bumps or outages, electronic controls get out of whack - Leave the breaker off for a minute and then turn it back on - As for the water level, I would question if the hookup was done entirely correctly - The idea is for the drain to connect to the most clear point of the sink drain - if you drain came with a pre-made Dishwasher drain connection, did the installer make sure that the plug was fully removed before connecting - Even in my mobile dishwasher I might get an inch of water, but not what you are experiencing - Good Luck
Feb 09, 2014 | Fisher and Paykel 24 in. DD603H W Built-in...
Drawer off track
if it is the drawer dishwasher, then first you need to take the front cover off carefully. Turn the mains power off and take the power plug out from socket if accessible. With a plier pull out the pins on each side of the drawer holding the front cover. Carefully pull out the front cover and leave it aside. Find where the drawer has come off the rails. Extend the rail arms on each side and try to replace the drawer on the guide rail and latch it back in. Make sure the controller and top display panel do not fall off when handling the drawer. Once the drawer is back on rail, put the top cover back and secure the pins from the sides. Put the mains power back.
May 14, 2013 | Fisher and Paykel Dishwashers
Kenmore 79558813900 refrigerator has no power - no lights, fan, etc. Outlet is fine.
The cable that powers the top drawer might be severed. The cable runs inside left panel to drawer on left side as well. That happened to our unit. We had the same problem. In which case you need to replace the power cable.
Dec 29, 2012 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Wrong region message
power on.
open the drawer & LEAVE IT OPEN
press on the remote control
1 3 7 9
four small stars appear in the top left of the screen whilst you enter the code chose whatever region you want 0 is region free
once the code is entered simply enter the region number you require, close the drawer & press play
Mar 31, 2011 | Daewoo DVG-8500N DVD Player
NAD 502 CD player problem
Does it have a failing drawer belt? My 522 was fixed after that.
Jun 18, 2008 | NAD C521 CD Player
Dead Pixel in Toshiba Porteg? M600 laptop
Without rplacing the main part of the lcd, I'm afraid you're stuck.
Nice laptop. Toshiba service has always been reasonable in my experience.
Sorry I couldn't offer better advice.
Good luck
Nov 25, 2007 | Toshiba Portege M200 Notebook
Orange SPV M600 Smartphone Logo
227 people viewed this question
Top Orange Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
Andrew Taylor
Andrew Taylor
Are you an Orange Computer and Internet Expert? Answer questions, earn points and help others
