Question about LG LRSC-26922 Side by Side Refrigerator
Need to replace funnel assembly on LRSC26925TT . Can it be done without need for technician?
Found "how to" with diagram on another website
Posted on Jul 23, 2009
What is a miele cva 2650 descaling funnel
The descaling funnel is a small, dull red insert that replaces the capsule holder and is used during the descaling cycle. I purchased a used CVA2650 that came without the funnel. I called Miele concierge service for help. They stock the descaling funnel and sell it for $15.95. In my case, they simply mailed one at no charge without me even asking. Great customer service!
May 10, 2012 | Miele CVA2650 Stainless Steel Espresso...
Tip
Resolve Intermittent Drain in Dishwasher
<span>From the excellent description you give the most likely cause of this problem is the check ball and funnel in the soil collector.<span>It drains fine sometimes but sometimes it doesn't drain but the motor is turning. If the motor is turning in the drain cycle most likely the motor and timer are okay. The motor on this dishwasher runs one direction to wash and one direction to drain. You can listen for this but there is another more likely part causing this problem.</span><br /> <br /><br />The idea is that in the wash cycle the circulation of the water brings food particles into the chamber. In the drain cycle the circulation is reversed and the check ball is suppose to seal the funnel off so all of the food and soils go down the drain. If the check ball doesn't seal the funnel then the water will not drain but go back into the tub.<br /> <br /><br />Most likely your problem is with the check ball and/or funnel. There may be something in the chamber preventing the check ball from sealing the funnel all of the time. Sometimes it does but sometimes it doesn't.<br /> <br />The images below will give you an idea of where the soil settler is located. You can remove the toe panel but must likely you'll need to pull the dishwasher out to access it.<br /> <br /><span> </span><br />This is a job I'd recommend a technician do. The funnel , check ball and the soil settler/separator <a href="http://www.searspartsdirect.com/"> </a>. You will also need some RTV sealant but even technicians have difficulty with this repair and I suggest you let the technician get the headache.<br /> <br /><br />The check ball and funnel can definitely cause an intermittent drain problem.<br /> <br /><br />I hope this information is helpful resolving this problem.<br /></span>
on Jan 24, 2011 | Dishwashers
Tip
Resolve Intermittent Drain in Dishawasher
<span>The most likely cause of this problem is the check ball and funnel in the soil collector.<span>It drains fine sometimes but sometimes it doesn't drain but the motor is turning. If the motor is turning in the drain cycle most likely the motor and timer are okay. The motor on this dishwasher runs one direction to wash and one direction to drain. You can listen for this but there is another more likely part causing this problem.</span><br /><br /> <br />The idea is that in the wash cycle the circulation of the water brings food particles into the chamber. In the drain cycle the circulation is reversed and the check ball is suppose to seal the funnel off so all of the food and soils go down the drain. If the check ball doesn't seal the funnel then the water will not drain but go back into the tub.<br /> <br /><br />Most likely your problem is with the check ball and/or funnel. There may be something in the chamber preventing the check ball from sealing the funnel all of the time. Sometimes it does but sometimes it doesn't.<br /> <br />The images below will give you an idea of where the soil settler is located. You can remove the toe panel but must likely you'll need to pull the dishwasher out to access it.<br /> <br /><span> </span>This is a job I'd recommend a technician do. The funnel , check ball and the soil settler/separator <a href="http://www.searspartsdirect.com/"> </a>. You will also need some RTV sealant but even technicians have difficulty with this repair and I suggest you let the technician get the headache.<br /> <br /><br />The check ball and funnel can definitely cause an intermittent drain problem.<br /> <br /><br />I hope this information is helpful resolving this problem.<br /></span>
The coffee stream is weak and does not make as much ciffee as it should. I have descaled the coffee maker and it does not seem to have made a difference.
Clean the Kcup holder.
Cleaning the K-Cup Holder
  1. Remove the K-Cup assembly
    To remove the assembly from the brewer, open the cover by lifting the handle. Grasp the top of the K-Cup Holder with one hand while pushing up on the bottom of the assembly from underneath with the other until it releases. The K-Cup Holder is dishwasher safe.
  2. Clean the Funnel
    The Funnel can be removed from the K-Cup Holder by pulling on it until it snaps off. The Funnel is dishwasher safe. To replace it just snap it back onto the K-Cup Holder.
  3. Clean the exit needle
    The exit needle is located on the inside bottom of the K-Cup Holder. If coffee grounds or cocoa mix gets clogged in the exit needle, it can be cleaned using a paper clip or similar tool. Remove the Funnel from the K-Cup Holder, insert the paper clip into the tube and move it around to loosen the clog and remove any debris. Please note, you cannot poke all the way through the needle as the opening of the needle is located on the side and not the top.
  4. Install the K-Cup assembly into the brewer
    After cleaning, align the K-Cup Holder tabs with the opening placing the two front tabs on the bottom and the single tab on top and snap it into place by pushing down on the top rim.
May 31, 2011 | Keurig B50 Coffee Maker
How do i replace ps 652226 ice funnel ge ziss480drbs
carefully removed the trim from around the dispenser area by gently prying the trim off careful not to brake it. then freed the catches in the top of the electronic card. I leaned the card forward and disconnected the electrical connections, then removed the card. I removed the four screws holding the shield to the door and removed the shield. Then I removed the funnel from the shield and removed the spring from the old funnel and placed it on the new one. I removed the light and socket from the old shield and installed the in the new one, then installed the new funnel on the new shield, used the four screws to install the assembly on the door and replaced the trim piece. Here's a DIAGRAM to help.
Mar 05, 2011 | Refrigerators
The lever is stuck on my LG ice dispenser
You'll need to replace the whole ice maker system. Problem exist in the mechanical box connected to the lever which once opened is almost impossible to re-assemble. Cost around $95.00
Aug 06, 2009 | LG LRSC-26922 Side by Side Refrigerator
LG LRSC26925TT ice dispensing funnel broken
Yes. But LG came out with a new frame for the funnel. So you have to order the funnel and the frame which is installed through your front control panel. Good Luck I just did it.
Jul 08, 2009 | LG Refrigerators
Have a 2005 model#LRSC26925TT LG fridge with front ice&water disp. and digital panel. Ordered replacement funnel and frame since mine is outdated and need to replace. Can we replace on our own and...
When you order the new replacement, did you ask the supplyer whether it can be replace the old panel? Sometime the wireing inside is different, I do not suggest you touch it unless you got the panel is completely same size and same founction and you know how? Otherwise it is a headache.
The panel must be right one.
Jul 21, 2008 | LG Refrigerators
Lg refrigerator water dispenser would not shut off
so two things I have learned. First if the tabs on the funnel break dont buy a new one just crazy glue back in place. Also if you take the gasket out put vaseline on the nubbins and they will slide back in place without having to take the panel apart. Fix time 7 minutes. Booyah!!!
Apr 21, 2008 | LG LRSC-26922 Side by Side Refrigerator
Ice and Water Dispenser Funnel
This diagram may help some.. should be a molding thats goes around outside of dispenser.. should be able to pop off and get at screws u need to get at...to remove and get at what u need too
http://www.partselect.com/Schematics/GE/00116598i01.gif
Nov 01, 2007 | Refrigerators
LG LRSC-26922 Side by Side Refrigerator Logo
339 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
