Question about Ruud UAKA042 Air Conditioner
Compressor size What determines if you need a 3 ton compressor vs. a 5 ton compressor. In other words, what is the difference for cooling a home. Is bigger always better?
  • 3,600 Answers
Square footage is how you determine what size of an AC you need, say two bedroom house with 1500 square feet would require a 3 ton unit but I would go to a 4 or 5 ton depending on brand and what you may do in the future, Like adding a bedroom or bathroom and how many people will be living in the house, a heat pump normally last longer the bigger it is and is more efficient than a smaller size. Just think like this, a 3 ton will run 30 minutes to an hour longer to cool the same space as a 5 ton so if the five ton does it 30 minutes faster it will not run as long. And when it has to pull down the temperature again it will do it much faster. So less run time means faster heat or cooling and less energy is used. I have found that the bigger units are made better and last longer as a general rule. And to understand the 3-ton and 5 ton let me say that it means how long it takes 3 tons of ice to bring the temperature down 10 degrees, the old BTU’s British thermal units. However the bigger the unit the more well built it is normally and the less maintenance required. 5 tons of ice would get it cooler faster. But one thing to keep in mind a heat pump is only good for 20 degrees temperature range, for instance if the high range is 80 then the low side would be 60 in order for it to be efficient so if you have it set in the house at 72 degrees on the high side and low side would be 52 degrees. But the larger the unit the less time it would take it to recover from the heat differential.
Posted on Jul 22, 2009
What is the size of the gas line piping on the out door unit of a elite elegance split unit
You need size of pipe , length of run , input of btu.s you need all this before you can size pipe
Jan 18, 2017 | Heating & Cooling
How to measure air conditioning tonnage to square feet of hom
Read size of air conditioner you need , each ton of air conditioning will keep cool 400 square.so higher ton yo pick you feel cool.please read below square feet to ton chart.
1 ton on 400 sq. ft.
2 ton on 800 sq. ft.
3 ton on 2000 sq. ft.
5 ton on 2570 sq. ft.
May 28, 2014 | Computers & Internet
Does not seem to be sufficient cool for a 1600 sq ft manufactured home coming from the Coleman unit installed. Some vents more air, others less air. Unit runs without stopping ever. Can you give us some...
Hi John, depending on the size, I would need the model number from the outdoor unit if it is a split system, you should have 400 cfm per ton of cooling. If you have a 1600 SQ' home, and a 3 ton unit, 3 x 400 cfm is 1200. It would be to small. There are 12,000 B. T. U.'s of cooling per ton. 2 tons would be 24,000 b t u's. 3 tons would be 36, 000 b.t.u.'s. Also, most contractors put lever dampers in the duct work that can be adjusted. They will put a red flag where the lever is and we can adjust the flow to balance out the house. I don't know where your ducts are, under or above, but with a good light find the crawl space and check it out. Get the model number and call it in to get the tonnage or send it to me and I will tell you. It will have a 024, 030, 036, 042, or, 060 in the number, MODEL number and figure like I told you above, 12,000 per ton. 060 would be a 5 ton. This will let you know if the unit is the right size or not. Please rate me on this and I know you will be kind. Thank you John.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
PS CFM is cubic feet per Minute.
Aug 05, 2010 | Coleman Heating & Cooling
Over Tonnage A/C
A better solution than undersizing the fan (which would decrease your airflow and probably not satisfy the household as well) would be to change the deadband in your thermostat. (Disclaimer: best solution is always to have a properly sized unit!).
Most programmable thermostats have a "deadband" that can be programmed in. This deadband is a certain number of degrees, in heating and/or cooling, where the thermostat will not call the system even though you have reached a threshold temperature. I.e. System is set to call for cooling at 76 degrees. there is a 3 degree deadband. When the Tstat reads 76 it will add the deadband (3) and not call for cooling until the room temperature is 79. This will prevent the compressor from cycling quite so much.
Adjust your setpoint temperatures (i.e.76) with the deadband in mind and you can arrive at a range that is comfortable and reduces compressor cycling.
Good Luck!
Jun 01, 2010 | Heating & Cooling
Need new one
Air conditioner equipment power in the U.S. is often described in terms of "tons of refrigeration." A "ton of refrigeration" is defined as the cooling power of one short ton (2000 pounds or 907 kilograms) of ice melting in a 24-hour period. This is equal to 12,000 BTU per hour, or 3517 watts.[13] Residential central air systems are usually from 1 to 5 tons (3 to 20 kilowatts (kW)) in capacity. To determine the correct size keep in mind that 12,000 BTU's equals 1-ton. Use the table below to determine the size AC that you need. Hope this helps. Area To Be Cooled (square feet) Capacity Needed (BTUs per hour) 100 to 150 5,000 150 to 250 6,000 250 to 300 7,000 300 to 350 8,000 350 to 400 9,000 400 to 450 10,000 450 to 550 12,000 550 to 700 14,000 700 to 1,000 18,000 1,000 to 1,200 21,000 1,200 to 1,400 23,000 1,400 to 1,500 24,000 1,500 to 2,000 30,000 2,000 to 2,500 34,000
Jan 08, 2010 | Intertherm P3RA-048K Air Conditioner
Need info for RUDD upflow oil furnaces
Contact your nearest Ruud DISTRIBUTOR, usually The Noland Company, and ask them if they could go into the historical documents and print out or send you the files for the wiring, spec's and parts breakdown. From the model number, that unit is rated for 3 tons of a/c. You can find a 3 ton coil that will fit in the space and get a straight cool condenser of 3 tons cooling and swap thermostats so it brings on the furnace and fan in heat and the condenser and fan in cooling. Or just add a simple White - Rogers model 444 for the cooling. Ron
May 06, 2009 | Ruud UBHC Air Conditioner
Is the Model #25HBA360A300 a 5 ton unit?
36k-car-ms Key Features AC Type: Split System Additional Features: Ductless Cooling Capacity: 36000 BTU/hr Electrical Requirements Voltage: 220It is a 3 ton aprox 550 sq feet per ton is required
May 01, 2009 | Carrier 36KCARMS Air Conditioner
Air conditon units
the higher the seer the more efficent it is no matter the tonage of the unit
make sure that the tonage is correctly sized for the home rule of thumb is if the home is insulsted properly 600 sq feeet per ton
oversizing creates shot cycles real cool then warm real cool then warm, under size unit runs all the time
May 19, 2008 | Heating & Cooling
Ruud UAKA042 Air Conditioner Logo
295 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
