Neither of my Motorola talkabout fr60 will receive. Both appear to transmit, but I cannot receive a signal, other than a click, on either. I can receive a signal from each on another 2-way radio. i have new batteries in both, and I have the frequencies exactly the same on both.
Hi again,
It would seem that you posted twice. Here is the link to your other post with my response.
Cheers.
SOURCE: fixing my radio
It is possible that your Motorola FR60 though on the same channel/frequency have different CTCSS settings. CTSS is also known as Interference Eliminator Code or Coded squelch, Private-Line, PL, Quiet Call, Channel, Guard, etc. What needs to be done is to set both to the same code setting on the settings/menu. Turning the code/CTCSS OFF would also serve the same but allow other radios (without CTCSS) to be likewise received/heard.
If they are already on the same code setting and still no receive audio, it is possible a fault on the squelch, receive/audio circuitry or even the speaker itself which of course would require hands-on/in-shop service.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
same exact problem not transmitting
thank you
can't receive signal on either radio
