Question about Hardware & Accessories
Water in timer keeps running out the hole
When I set the timer it makes a sound like the tube is opening up to allow the water to flow but when I placed the unit on the faucet and turned the water on to wait for the timer to work the water was already on. When the timer reached the time that I set it made the noise like it was opening for the water to flow and that is all. The water stayed flowing out the hole all the time.
  • 3,600 Answers
The water valve has some deposits in it or the shut off valve is bad.
Posted on Jul 22, 2009
CWTF15 WILL NOT STOP WATER FLOW WHEN POT IS MADE.
The coffee dispensing valve is stuck open. It may be due to Calcium deposits.
Descale the machine or manually clean the dispensing valve and the diffuser disc that unscrews to be removed. This diffuser is visible just above the coffee pot.
Oct 16, 2014 | Bunn CWTF15
Whirlpool washer won't wash or spin or dump water
usually a broken lid switch if it fills with water and then nothing,set the timer on spin and pull out the timer,open the lid and stick a screw driver into the hole where the plastic acuator on the lid goes into the hole and push down easily and see if washer will run this is where the lid switch is and it's only a safety switch so when the lid is open the washer won't run,if not push up and down on the switch and listen for a clicking sound,no click switch is bad part number 285671,watch video
http://www.youtube.com/watch?v=Ag1eT5PrMnE
Apr 06, 2013 | Whirlpool Washing Machines
Water leak on back wall of my freezer and a hell of noise from my icemaker when on
Water leak and noise are due to wrong temp setting or malfunction of defrost cycking.Keep temp setting between 3 and 5 degree centigrade. Due to over frosting, the freezer fan fan hits over the ice and working to cool fridge compartment.And also check defrost timer, and heaterworking properly to defrost in time. And if your ice maker is making sound, due to:
  • You will hear a buzzing sound when the water valve opens to fill the water reservoir for each cycle.
  • Rattling noises may come from the flow of the refrigerant or water line. Items stored on top of the ice maker can also make noises.
  • The high-efficiency compressor may make a pulsating or high-pitched sound.
  • Water running over the evaporator plate may make a splashing sound.
  • Water running from the evaporator plate to the water reservoir may make a splashing sound.
  • As each cycle ends, you may hear a gurgling sound due to the refrigerant flowing in your ice maker.
  • You may hear air being forced over the condenser by the condenser fan.
  • During the harvest cycle, you may hear a "thud" when the ice sheet slides from the evaporator onto the cutter grid.
  • When you first start the ice maker, you may hear water running continuously. The ice maker is programmed to run a rinse cycle before it begins to make ice.
Hope, it's helpful>
Feb 05, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
How to drain radiator
hello. on the drivers side of radiator is a drain. here is a picture and the instructions for draining the coolant out.
  • Install a tube on the radiator drain. Place the end of the tube in the drain pan.
  • After the engine cools down, remove the radiator cap.
  • Completely open the radiator drain ****.
  • Allow the coolant to drain from the system until the flow stops.
  • Place a drain pan under the block drain hole plug.
  • Remove the drain hole plug from the engine block.
  • Allow the coolant to drain from the block until the flow stops. There may be more drainage from the radiator at this time.
  • Install the block drain hole plug.
  • Close the radiator drain ****.
    Jul 04, 2010 | 1997 GMC Suburban
    It is not allowing the water to go through when it says "ready" and I push the button. I have a new coffee in there and the water is filled but it drips slowly out as if it is having trouble (usually a...
    Hey, We had a similar problem. Water just dribbles out if at all. Here is a trick that worked for us. In the K-Cup holder there is a tube that punctures the bottom of the KCup. They give you instructions on keeping that clean. But they dont tell you there is an equally important puncture tube at the top. THis tube usually has 3 or so holes or openings that flow water after the cup is punctured on top. I took a paper clip and pushed in (not too far) on these holes only to find coffee had lodged up there and blocked the hole. I ran a couple times after with just hot water and it works like new.
    May 16, 2010 | Keurig B60 Coffee Maker
    Cold water does not stop at set levels. Too much flow.
    Blockage in pressure bottle or small hole in pressure bottle tube.
    Feb 25, 2010 | Washing Machines
    When running a cycle the water doesnt shut off causing it to over flow, but the pump is working
    If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
    If it overflows and don't start the cycle-
    Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tube. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
    Oct 14, 2009 | Washing Machines
    My washer keeps filling no matter the size I have
    This sounds like a faulty water level switch. It's a diaphragm-like device with a small plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level increases, so does the pressure on the air in the plastic tube and when it reaches a certain level it activates the switch to shut off the water and signals the timer to start appropriate cycle. Make sure there is no damage to or obstructions in the plastic tube. The switch can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty switch. Sorry for your trouble and I hope this helped. Best wishes.
    Sep 04, 2009 | GE WSXH208A Front Load Washer
    The water won't automatically stop flowing through
    If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It need replacing.
    Sep 03, 2009 | Whirlpool LSB6200KQ Top Load Washer
    Kenmore Top Mount Refrigerator - leaking water from the Cold Control Defrost Timer/Automatic Defrost Control Housing
    It freezes up for a few reasons. First the water is not running down fast enough. That is why the wire was added to add heat from the heater to the drain hole. The metal pan under the evaporator coil may not be lined up with the drain hole well enough and holding water there. If that looks ok the drain tube that runs down the inside back of the unit might be slightly restricted. Not much you can do about that. I would make sure that the aluminum wire goes in the hole about 2 inches and that the unit is tilted slightly back to help water flow.
    Apr 18, 2008 | Refrigerators
    Hardware & Accessories Logo
    Top Hardware & Accessories Experts
    Gene Haynes
    Craig Butler
    Craig Butler
    Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
