Question about Thermador SEC302 Electric Double Oven
Lower oven and broiler not working....could this be a self clean hi temp limiter issue?  I can't find a reset....is there one on this model?  Help!  Gotta cook Thanksgiving dinner for 20!!
    Problem Solver:
  • 9 Answers
Im going for my reset switch...its on the top - outside the oven - behind the panel...
Posted on Dec 11, 2009
  • goober123 Dec 11, 2009
    It worked.... Remove the small black panel..there's a reset switchin the center, on the right side - push down on the top center for a sec....when I turned it on...it worked fine...
Ge electric broiler inoperative
Link to manual
check page 22 for self cleaning oven
(door is latched )
make sure clock and timer are operative
Dec 20, 2007 | Ovens
My Frigidaire FEFL77ABF gets way too hot. When set at 350, temp soars to over 450. Have cleaned oven and tried resetting procedure, but neither worked. High temps are not consistent, so I can't...
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 02, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I have a 30 inch Frigidaire self cleaning oven. The oven will no longer heat up in a normal amount of time using the bake function. Sometimes I can smell gas when using bake. It cant reach the desired...
Sorry to read about your problem, I hope this helps you out.
Bad gas control valve or oven temp control
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Oven does not work after self clean
Sorry to hear you`ve had an ongoing issue like this. Can you tell me what the model number is of your oven ? Can you also maybe touch on what step`s have been taken in the past when this occur`s ?
Depending on the model and vintage of your oven, it likely has tripped the hi-limit thermostat. The good new`s is it is typically easy to reset as it is a manual reset type hi-limit as opposed to one time non-reset. Also this hi-limit is either located on side, back, or behind the grill between the oven door and control panel/fascia. Let`s hope for the later.
**Always shut off power to the unit before performing any service/repairs**
If it is indeed just a tripped hi-limit as I suspect, ( it is common after self clean cycles on many ranges/ovens, not just Thermador ) I have a few tip`s and suggestion`s after you`re up and running, but we`ll cross that bridge when we get there.
I`ll watch for your reply. Good luck.
macmarkus :)
Mar 24, 2010 | Thermador Ovens
Temp control
No adjustment. Could be bad temp control unit or bad oven temp sensor. You would have to purchase a repair manual and test the current flow to and from the circuit. And then testing the oven temp unit with multi-tester.
Jul 23, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Oven will not work - Hi/Lo broiler works fine
you have a bad bake ignitor. it is mounted to the long tube in the very back wall of the tube. usually held on by 2 1/4 inch bolts. usually if you replace the ignitor you have to cut the old one off and hard wire the new one in depending on what the new connection on you ignitor look like.
Jan 26, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Heat elements in oven/broiler do not heat up
I would say to go and reset your curciut breaker first if this is a electric oven. needs 220 volts for both element to work
Jan 03, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
My Dacor wont heat, broil or convection after self cleaning. No heat but everything else works The bake, broil, and convection elements on my Dacor CPS130 electric wall oven will not heat.  The oven has...
like another person stated-from the front behind the door, take off the 6 screws and the cover by the latch. there is an "oven hi temp limit switch" It is crome with 2 heavy black wires connected to it. On the back side of this is a small red button which will reset the limit switch. I had the same issue (everything worked except the any of the heating elements) and quickly resolved.
Jan 07, 2008 | Ovens
Thermador SEC302 Electric Double Oven Logo
335 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
