Question about Vacuums
Same problem my vacuum cleaner is Hoover Dimension 1000
The vacuum cord is all tangled up so I can no pull out the retractable cord.
How do I take it apart?
  • dseto200 Jul 23, 2009
    Hoover Dimension 1000 it's a cannister type.
    Problem Solver:
  • 7 Answers
Witch model due you have ?
Posted on Jul 23, 2009
I opened the vacuum,i checked the cord and it is in the correct form,not tangle etc..still doesn't work after pluging it the wall out let..help
Possibly a broken wire. It is common for the flexible cable to break at the 3 pin plug end from constantly pulling the cord / plug out of the socket or if its a retractible cord, they get broken where the cord enters the machine rewinder. this happens when the cord is pulled out to its maximum length all the time and eventually cuts through the cord. I would try a new 3 pin plug first.
Apr 13, 2015 | Vacuums
Retractable cord stuck
I wonder if there is a tangle in the cord. It could have also come off the wheel inside. Open the vacuum to see if you can untangle the wire and put it back on the wheel.
Nov 29, 2013 | Hoover Vacuums
I have a Hoover Legacy model S3592 and the cord will not retract, it is fully extended. How can I fix this problem? Patty Lester
You may have to dis-assemble the machine to the point where you can gain access to the mechanism that retracts the cord. Then see if it can be fixed or needs replacement. Just don't lose any parts when dis-assembly, and make sure everything is put back together correctly.
Oct 14, 2013 | Hoover Elite & Legacy Vacuum Cleaner Belt...
Hoover dimension 1000
There are a few screws on the bottom of your hoover, remove them using a suitable unarmed and then pulling firmly upward.
Jul 04, 2013 | Hoover S1361 Bagged Canister Vacuum
Our tractable cord is half-way stuck and will not retract and its all tangled inside and you cant pull it to use it
The only thing you can do is you must open it by removing the screws and take it apart your self, once open it should be apparent what to do, or take it in for the repair.
Jul 04, 2011 | Hoover U5753-900 WindTunnel Bagless...
Hoover UH70120 WindTunnel TSeries problems with the cord. im a tech savy guy and have been trying to fix a cord after it was pulled to far out and now wont auto retract, but just cant find a way to pull...
You will probably have to replace the cord winding mechanism. I have never had any luck trying to repair one. Cord retracters are great when they work but it seems like they always go bad before too long. On many units you can't even replace the cord if you get a bad spot in it, you have to buy a new cord reel which can get expensive.
Jul 21, 2010 | Hoover UH70120 WindTunnel TSeries Rewind...
Hoover s3639 vacuum...cord does not rewind
I had the same problem with my Hoover s3639. The cord rewinder started squeaking, and retracted less and less of the cord each time, until it finally stopped retracting the cord at all. Here is what I did. I hope it will work for you as well. Open the covered tool storage and remove the tools. You should see three screws. Unscrew the screws. Remove the cover. You should see the motor for the vacuum and the cord rewinder. Between the vacuum motor and the white wheel where the cord is, you should see two brass wheels that turn into each other in order to operate the cord rewinder. Spray a small amount WD-40 between the two brass wheels. This should solve your problem.
Dec 29, 2008 | Hoover S3639 WindTunnel Bagged Canister...
I need to replace the belt on the power nozzle of my Hoover Dimension 1000 Model S3491. Unfortunately, I have no written instructions on how to do so. I purchased the vacuum cleaner in the mid-80s. Are the...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=566792
Generic problem for all Vacuums
posted by Deb in Iowa on May 03, 2008
I need to replace the belt on the power nozzle of my Hoover Dimension 1000 Model S3491. Unfortunately, I have no written instructions on how to do so. I purchased the vacuum cleaner in the mid-80s. Are the instructions still available? Thanks in advance.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I believe so, but you would have to contact the Hoover Factory and they would have to send out either the owner’s manual or a copy of the owner’s manual from the fische. I remember this vacuum cleaner well. In order to change the belt you need to remove the 4 screws in the bottom of the power nozzle and then the top cover will lift off from the back to the front and then you can get in to change the belt. Always use the Factory Genuine belts instead of the replacement belts, they last longer and the average belt change for a flat belt is every 4 to 6 months as a rule for the best cleaning. In order to change the belt, lift up the pulley side of the brushroll and slide off the old belt and then slide on the new belt and re-install the brushroll, then use a belt puller or screwdriver with a hook on the end and to pull or stretch the belt onto the motor pulley, once you have it on the vacuum track the belt in a straight line and then reinstall the top cover and screws in reverse. If you have questions please feel free to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 03, 2008 | Vacuums
Hoover dimension 1000 dead after hot
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=557355
Hoover Dimension 1000 dead after
Posted by ecmga on Apr 29, 2008
If I remember correctly there is a heat sensor in the control panel that might need replacing or the hose could be clogged or the bag too full or the filter could be dirty, this was one of the first computer board models @the time they introduced the model to the market and the heat sensor could be attached to the main computer board, so I would check your owners manual to see if that could be the problem or check the factory’s website to see if you can down load the owner’s manual or a schematic on the vacuum itself, or to call the factory to have them send one out or check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Apr 29, 2008 | Vacuums
Hoover Model S3281, disassembly instructions
GET TO THE REEL AS FOLLOWS:
(BEFORE YOU START, BE SURE TO UNPLUG THE DIMENSION FROM THE OUTLET)
1). TURN VACUUM OVER AND USE A FLAT-BLADE SCREWDRIVER TO WEDGE/SLIDE THE WHEELS OFF (PUT THE SCREWDRIVER BLADE BETWEEN THE LITTLE BLACK WHEEL BRACKET PIECE AND THE GREY CHASSIS OF THE VACUUM AND SLIDE/WIGGLE THE WHEELS OFF);
2). THE 2 DEEP HOLES AT THE TOP OF EACH WHEEL RECESS LEAD TO 1-1/2" LONG PHILLIPS SCREWS >> UNSCREW THEM;
3). AFTER REMOVING ALL 4 SCREWS, YOU SHOULD BE ABLE TO EASILY LIFT OFF THE TOP OF THE REEL/MOTOR COMPARTMENT.
4). CAREFULLY LIFT AND ROTATE THE CONTROL PANEL TO THE SIDE.
5). THE REEL IS NOW IN PLAIN SIGHT.
6). I’M STILL TRYING TO FIGURE-OUT HOW TO SAFELY ACCESS THE GUTS OF THE REEL MYSELF. I HAVE A PROBLEM WITH INTERMITTENT VACUUM POWER AND ALSO WITH WEAK CORD RETRACTION.
ANYWAY, GOOD LUCK TO YOU !!!
Jan 01, 2008 | Vacuums
Vacuums Logo
272 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
