Question about GE WBSE3120B Top Load Washer
THE START BTTON ON WASHER PUSHES IN BUT DOES NOT TURN WASHER ON
  • 6,784 Answers
HI, check the lid switch for its operational value. if the lid switch is showing good Resistance, replace the start button.
Posted on Jul 22, 2009
The start button on my lg tromm washer does not work
The plastic piece that you push may be broken or the switch that it pushes may be broke. Sometimes you have to hold the start button for a few seconds before the actual start will take place.
Feb 19, 2015 | LG Tromm Front Load Washer And Dryer Set
Bosch Nexxt 100 series washer wfmc1001uc
According to the manual, you have to:
1. Turn program selector to "off"
2. Turn selector to Drain or Spin
3. Press the start / pause
Wait until program ends.
Open door.
or
Press "start / pause" until the start / pause light flashes.
Jan 10, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Code E 21 Error on Affinity Washer Front Loader
I've had problems starting my washer because the door does not close properly, and then I get an error or pau code
What has worked is to unplug the washer for a minute, close the door, and then plug it back in. it then starts normally with 2 pushes on the start button
Jul 06, 2014 | Frigidaire Affinity ATF6000F Front Load...
When I turn on the washer, the code "F24" flashes
Greetings,
its detecting a water temp failure, heater problem, or even a kinked washer hose.
I would unplug washer and remove the three bottom screws...look for a loose connector on the sensor.. Its located on the heater bracket right between the element terminals.... .It has a connection that pushes on...these come loose or burn off. It also can be a defective element..This can be checked with a ohm meter. The hoses should be checked for a kink or lack of water pressure...The hose should be checked for clogged screens. I think one of these mentioned will find your problem.....
Feb 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
"An error has occureed. Press and hold Power Btton
therw is a factory reset code hold all the button at the same time
left,right,start,select..........
this will reset your dsi to factory settings
Jan 13, 2011 | Nintendo DSi Black Console
Washer will not start. when we turn it to spin it will do that? we have checked water source thanks
It must first fill with water before it washes. Might be a bad water valve, water temp switch, water level switch or timer. Your timer has a big block that pushes into for the connection, sometimes it backs out a hair or gets corrosion in it so check that.
Here are some videos that show how to get into the machine.
Jan 07, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Cycle wont start
does it just beep 3 times when the start btton is depressed?? the numbers continue toflash??? if so sounds like a bad lock/ latch assy, and the uint is not recognizing the door being closed
Mar 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 80 series washing machine
There is a small tab or finger on the lid of your washer that pushes a button through a small opening on the washer as you close the lid. This is the spin safety shut off. It also will prevent the washer motor from starting "IF" the button is broken. It is plastic and will break over time due to vibration. With some experience you can remove housing to get access to the button. They can be purchased at local appliance repair shop. The job is easier than you think, and you can save the labor charges. That happened to me and I thought my washer was done.
Dec 14, 2007 | Kenmore 24032\24036 Top Load Washer
GE WBSE3120B Top Load Washer Logo
90 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
