Question about Brother GX-6750 Typewriter
My set margins and tabs clear from memory when I turn off the typewriter.
I was able to reach someone at Brother. He said that the typewriter does not store the margins and tabs. Seems unusual to me, but I guess I will have to take his word for it unless someone out there knows something different.
Posted on Jul 23, 2009
Clear tabs
TAB to stop depress tab clear, one way shut off, hold down on MR key margin release and turn on, will print configuration and ver then shut off, taps will be set at preset positions....
Sep 28, 2013 | Swintec 7040 Typewriter
How do i release the tab position?
At each tab stop, press the "tab release" button. Then tab to the next tab position and do the same. OR
You can put the machine in "service mode" which will erase all tab stops and reset your margins to their default positions. Easily done by turning the typewriter OFF. Then while off, press and hold "mar rel" (margin release) key on upper left side of keyboard. While holding it down and keeping it down, turn the typewriter ON. Then take your finger off the Margin Release key. The typewriter will start typing all by itself. Turn the typewriter off, then on. That will reset everything. All tab stops will be erased and margins reset to their defaults.
Jan 04, 2012 | Swintec 7040 Typewriter
KXR00 I have a panasonic elfec electronic typewriter r200 and I don't have a manual. I am having trouble setting the Left & Right Margins Regaards Lesley
I have a manual...
To clear margins and have do the following: depress the "return" key so the carriage returns to the left margin. Then depressed the "code" "tab clr" keys.
To set margins and tad do the following: clear your margins in tabs using the steps above. Depressed space bar until you reach the desired left margin. Depressed the "L. MAR" key... you're left margin is now set. Depress the "space bar" until you reach the first required tab stop. Depressed the "tab set" key... your first tab stop is now set. Repeat steps 4and 5 for each tab stop required on the writing line up 13 can be set on each line. Depress the spacebar to move the carriage to the desired right margin. Depressed the "r. mar" key. Finally depress the return key.
May 28, 2011 | Office Equipment & Supplies
How do I release the set tabs
Try pressing key marked "T clr", tab clear, and then press return key.If that doesn't work, remove the AA batteries and turn machine on. If tabs are cleared, you can re-install the batteries. The only job the batteries perform is to keep your tabs and margin sets in memory when you turn machine off.
Jun 04, 2010 | Lexmark Wheelwriter 1500 Typewriter
Wheelwriter 30 Typewriter: I have a tab set that I can't figure out how to cl...
The "tab" is probably the R. margin. Go to that point, press margin rel, space to the place you desire, press R mar key.
DickyO
May 18, 2010 | IBM Wheelwriter 30 Typewriter
How do you clear a tab someone preset. when I get to the far right of page and hit return it will on return to a tab. How do I clear all the preset margins or tabs.?? thanks
To clear margins, you have to hit the return button to find the left margin, then hit margin release and back space to move the margin left or spacebar to move to the right, then hit left margin button to set the new position. Right margin now. Hold spacebar down and find right margin position, hit margin rease and either spacebar to the right or backspace to the left to the new margin position then hit right margin button to set the new position. Tabs now. hit the tab key, when it goes to the first set tab, hit the tab clear key, then hit the tab key again, then tab clear again etc.
Dec 29, 2009 | Swintec 7040 Typewriter
How do I set Decimal Tabs?
From the User's Manual:
Margins and For each setting, move point. key(s) indicated:
• LMar to set left margino
• RMar to set the right margino
• MarRei to the!" left of the margino
• TSet to set a tab. Vou set at the left and right margins. Vou • TClr to clear a tab.
• TClr + CRln elear ali The earrier does not margino when the carrier is tive margino Vou type or space through ríght margino saved when the oft.
Tabs
the carrier to the desired point, and press the
the margin.
margin.
MarRel release the left margin, ther Backspace or +- to move
margi n.
You can up to 26 tabs. Permanent tabs exist
You cannot clear these tabs.
CRtn to clear all tabs.
carrier lock at the right margin. The typewriter beeps
about five spaces before the right margin. You can
the right margin. Margin and tab settings are
typewriter is turned.
You can download the User's Manual from LEXMARK:
http://images.lexmark.com/publications/pdfs/2007/index/en.html
Look for the title 'IBM Typewriters' at the end of the page, open the list box and select your typewritter model.
Aug 07, 2009 | Lexmark Wheelwriter 1000 Typewriter
Changing tabs and move the right margin over some
On the L. side of the T/W ketboard are the keysmar left, mar right,tab set, tab clear and mar rel. Space to the location thayou want th R. mar and press right mar key, if it stops at the R. mar. press and release the mar rel key. To clear tabs tab to the one you want cleared and press tab clear. To set a tab space to the position and press tab set.
DickyO
May 26, 2009 | Nakajima AE-740 Typewriter
Tab Release
You can reset all functions to original settings by doing this simple self test.
1. Turn typewriter off
2. Hold down the margin release key.
3. While holding down margin release key, turn on typewriter.
4. release margin release key
typewriter will now begin to type on it's own.
5. Turn typewriter off and then on again
all settings will now be cleared.
Feb 02, 2009 | Swintec 7040 Typewriter
How to clear the full memory on my Panasonic electric typewriter
To clear ALL memory, turn the machine off, then hold down the SHIFT and CODE keys while turning it back on.
Here's a halfway measure. While in normal typing mode, hold down CODE and touch TAB CLEAR to clear all tabs and margins at once. Does not affect any stored text memory.
These work with the KX-R340 and all the KX-E series. I presume they'll work with your KX-R440 also.
Eric
Nov 28, 2008 | Office Equipment & Supplies
Brother GX-6750 Typewriter Logo
182 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
