Question about Toro Lawn Mower With Toro Power Tools
How do I clean the carb on my Lawn Mower - Toro Lawn Mower With Toro Power Tools
  • fittr May 11, 2010
    what brand of motor and what size
    Scholar:
  • 71 Answers
Without completely removing the carb you can just start the engine and squirt carb cleaner in it after removing the air filter. If it needs additional cleaning(float sticking,dirt in the bowl, gas overflow etc.) you'll have to pull it from the motor and take it apart.
Posted on Jul 23, 2009
AFTER RUNNING OUT OF GAS, THE MOWER WONT START
Neal, If lawn mower does not start after running out of gas, change fuel filter if equipped, chances are the carburetor has gotten clogged with sediment/dirt from bottom of tank. Remove carb. and disassemble, clean/rebuild. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
REPAIR BRIGGS STRATTON LAWNMOWER TUNE UP CARBURETOR CLEAN
How to clean out the carb on small engine
WelcomeLawnmower Man FREE Lawn Mower andSmall Engine Repair Help
Lawn Mower Won Start
Jul 25, 2016 | Garden
Lawn mower will start and run for 5 seconds and shut down
will it stay running with your choke on? if so then clean your carb. if not then look for a blockage from tank to carb. ie fuel shut off, deteriorated fuel line. plugged filter etc
Oct 17, 2014 | Toro Power Lawn Mower
My mower revs up and down
This is a case of partially blocked jet in the carb, you need to remove and clean the carb, or remove and get it cleaned sonic cleaned by your local dealer.
Jan 11, 2013 | Garden
Toro recycler lawn mower
if old gas was left in the engine a good carb cleaning will need to be done
May 11, 2012 | Toro Power Lawn Mower
Briggs mod 216112011E. Won't start, carb cleaned wiith no change. I'd like to see a carb diagram to make sure the re-assembly was correct . I suspect the float could out of position but I'm not sure.Any...
This should help. As far as the float being out of position, if you invert the carb body (carb off mower) with the float hinge clip attatched, it should rest just about parallel to the body of the carb..a small straight edge will help..here are some diagrams
http://www.lawn-mower-shop.com/carb2.htm
Please vote on this solution.
Sep 08, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Mower will only run in choke position
Partially obstructed main jet. Remove carb bowl and clean main jet with small strand of wire. Drain carb bowl and clean out any dirt or rust.
Good luck and be careful.
Aug 04, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Do you have any info on lawn mower carbs?
If this is a carb-on-the-tank Briggs engine, replace the rubber diaphragm that fits between the carb and the tank. Almost certain fix.
Sep 30, 2009 | Garden
Lawn mower will not stay cranked unless you keep pouring gas into
common problems to all older lawnmower, lots of dirt and dust the mower goes through and ages. I would first start by taking the carb apart and clean the filter with soap and water, allow it to air dry. also carburetor prob need rebuilding or replacing. Pick up some Carburetor cleaner at any auto part store and spay it down the carb, dont be afraid to spray allot in there and let it dry for 1/2 and hours. carb tend wear and parts need replacing just like any engines. 99% of the time lawn mower carb goes out before the engine will and common problems with all lawn mower. If you not mechanical incline or dont want to rebuilt it, just buy the whole new carb and replace it, fairly cheap easy to replace and will last you another 10 + years or more. www.briggsandstratton.com
Sep 01, 2009 | Omega Rear Drive Wheel Snapper Mowers
GOT GASOLINE IN OIL TANK OF MY LAWN MOWER BY ACCIDENT. sTARTED THE MOWER ONCE .IT STARTED BUT GAVE A GREY SMOKE AND DIED.I HAVE A MACHINE YARD MOWER FROM MTD.IT IS 22'' SIDE DISCHARGER.PLEASE...
Empty the tank of the tainted gasoline (Maybe add the right amount of oil and use it for a trimmer, etc), fill tank with fresh gas and clean the spark plug, since it is probably fouled out. You may have to clean the carb with some carb cleaner, and clean your plug a few extra times, but it should be fine. Hope this helps. Good luck.
Jul 15, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Cannot start lawn mower model YP5HY22CA (Honda)
Clean the carb with some carb cleaner this will solve your issue at hand. When you go to store the lawn mower make sure to add some fuel additive in the gas to keep the fuel from gumming up in the system
Jun 01, 2009 | Garden
Toro Lawn Mower With Toro Power Tools Logo
441 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
