Question about Watts Onan Portable Generator - 4000 , Model# 5500
Onan microquiet 40000 in toyhauler ,runs for 15minutes and off
This unit only has 100 hrs on it and well maintained,it will run about15 to 20 minutes then shut down , once it cools down it will restart and do the same?
  • 77 Answers
Take and locate the oil pressure switch and try bypassing it,if that aint it check fuel filter and pump.
Posted on Aug 10, 2009
Onan 4000 Microquiet shuts down after running for 20-30 minutes. If I direct 2 high power (400+ CFM) fans to the underside of it -it will keep running indefinitely.
check the current draw from the machine
being a 4000 watt machine if you are drawing 4000 watts it is overloaded as that is the surge power available not constant power which is around 3500 watts
that would account for the requirement of fans to keep it cool
even if It is not 4000 watt what ever capacity it is it is running in an overload situation
Jul 10, 2016 | Onan Microquiet 3600 & 4000 Generator
Onan 4000 microquiet generator
Check the ignition circuit, and trigger coil for correct resistance on the trigger coil, and the ignition coil. The trigger coil is a small module on the engine shaft near the flywheel.
Jan 31, 2015 | Onan Microquiet 3600 & 4000 Generator
Cant run both a/c at same time
A 5KW is too small to run two HVAC at once, especially if they do not have interlock relays where only one at a time can cycle. It needs a 7KW for two HVAC units
Mar 16, 2014 | Onan 5500 Microquiet Generator
Will not run without manuely chocking
Sounds like the unit has sat, and carb gum, Try draining the carb bowl and re-filling. There is a screw at the base of the bowl. Also make sure when cold choke is closed. And it opens fully after 3 minutes. Check battery voltage on choke coil.
Dec 17, 2013 | Onan 5500 Microquiet Generator
Onan generator
When you say no fuel, are you indication the fuel pump has no fuel from the vehicle? if so the pickup tube in the tank should be looked at. If you have fuel at the pump inlet, and the pump makes a load clatter whilst priming check by installing a cheap clear gas fuel filter between the pump out and the carb, run the gen to see if the carb is been starved of fuel, if so replace the fuel pump. Anothe rpoint make sure it is an OEM pump as they are low pressure and an automotive fuel pump is too much pressure and can lock the carb and cause dangerous leaks
May 24, 2013 | Onan Microquiet 3600 & 4000 Generator
Onan generator microquiet 4000
Check the pickup tube in the vehicle, the fuel pump is suspect. If you check the fuel pump pressure and it is ok, then try installing a test check valve between the fuel delivery hose to the generator. If it solves the problem the pump is losing it's prime internally, so replace the fuel pump.
Onan MicroQuiet 4000 Generator
Remove the air cleaner and inside near the throat of the carb is two bolts holding the carb to the intake remove these. Unhook the fuel line and twist the carb to allow the linkages to remove.
Sep 14, 2009 | Watts Onan Portable Generator - 4000 ,...
Watts Onan Portable Generator - 4000 , Model# 5500 Logo
718 people viewed this question
Top Watts Electrical Supplies Experts
rlev_7
Level 1 Expert
Steve
Jim London
Jim London
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
