Question about Polaroid i631 Digital Camera
My daughters camera was dropped by the younger child and i thiknk the lcd screen is broken; is it possible to order this part and replace ourselves?
    Brigadier General:
  • 4,090 Answers
Not unless you are skilled in electronics and understand ribbon cables etc. The repair is expensive too. Almost cheaper to buy a new one and ensure tiny tots are not given the opportunity to play with expensive items. If you have home insurance you may want to try a claim depending on your excess liability
Posted on Jul 22, 2009
Can i repair broken display?
Yes you can, but you will most likely want to. If the screen is broken it will cost about $120.00 to get the replacement. You are better off using it as is or buying a newer model. If all else works on the camera, I would suggest using it as is or giving it to a teenager. My daughter uses or 'broken' camera and is very happy with it.
Mar 01, 2011 | HP CB350 Digital Camera
LCD screen powers up but is bright white
TRY SEARCING THROUGH ALL YOUR MENU MODES. MY CAMERA IS DIFFERENT THAN YOURS BUT MOST CAMERAS IT HAVE AN ADJUSMENT MODE TO BRIGHTEN OR DARKEN YOUR DISPLAY ... JUST A SUGGESTION NOT A SOLUTION
Jun 19, 2007 | JVC Cybercam GR-DVL120 Mini DV Digital...
Dropped camera. Now screen is part picture, part
maybe your lcd screen is broken.
you could try to buy a replacement and fix up it yourself.
from belwo you will find it.
http://szaideal.diytrade.com/sdp/975724/4/pl-4820089/0/Product_Catalog.html
Sep 10, 2009 | Cameras
My daughter dropped my camera. Screen broken.
That screen is the lcd screen (liquid crystal display)
I had a fuji E900 that was dropped when the lens was extended , and it broke the lens mount ring inside the camera.
I took the camera apart to try and repaair it.
as part of the dissasembly I removed the lcd .
If you can find a parts camera.with a good lcd, it is worth the effort to simply replace your lcd.
if you need mor info email me , and I will try to describe the dissasenbly sequence for the fuji that I had, perhaps it will be the same for your camera.
Tom
Jan 05, 2009 | Fuji FinePix S5500 Digital Camera
Vivitar 7100 damaged lcd scren
Yes. You can get them (to fit yourself) from the manufacture or you can simply take it in to an outlet (like curries etc) or a repair center and they will fix it or have it sent away.
However, it may be cheaper to buy a new camera than to have the screen fixed. You can also get an older broken 7100 with a working screen and remove it and replace your broken one...tho if you are not up to doing that I would take it to a repair center.
Sep 05, 2008 | Vivitar ViviCam 5100 Digital Camera
Casio exilim digital camera 7.2 mp
I bought a non functioning camera like mine on ebay and put the new screen in. Not a project for the faint hearted. Requires magnification, a really good jewelers phillips and some soldering skills. The most practical solution, for what it will cost to have it done, is get another camera, there are some pretty good deals on ebay on demos and used cameras.
Mar 08, 2008 | Casio Exilim EX-S600 Digital Camera
Casio camera LCD screen broken?
There is a guy in South Carolina that sells used Casio parts. I got a LCD for mine and it works fine. I think his email is gerald.ray@aa-ark.com
Feb 28, 2008 | Casio Exilim EXZ75 Digital Camera
I have used LCD's for your Casio Z75 at a reasonable price. gerald.ray@aa-ark.com. Thanks papasgirl
Feb 12, 2008 | Casio Exilim EX-S600 Digital Camera
Camera Screen
The following procedure works on the V603. It uses the same LCD screen as the V803 & V1003.
It would appear you have a damaged LCD screen. The same problem happened to my daughter's V803. The camera will take pictures fine but you will only be able to see them if you download them onto a PC. A replacement screen can be easily ordered and replaced. Call Eastman Kodak. Their parts department can be reached at (800) 431-7278 ext 3. Tell them the model number of your camera and tell them you want to order a LCD screen for it. The cost of the new screen is $31.00 + $15.00 shipping. Don't let them talk you into sending it back for repair. You are looking at a repair bill over $80.00. To replace the screen, remove all of the small philips head screws that are in the chrome band that runs around the center ridge of the camera. After removing the screws, you will be able to separate the rear half of the camera from the front half. The LCD screen is pressed into a rubber gasket in the rear half of the camera. You will see that there is a small, flat orange ribbon cable that connects the old LCD screen to a black connector on the camera's motherboard. Using a VERY small flat blade screw driver, pry up the top tab on black connector. This will unlock the connector and allow you to remove the flat ribbon cable from the black connector. Remember the orientation of the old screen and its cable, as you will want to replaced the new screen and cable exactly the way the original was installed. Using the same small flat blade screw driver, pry out the old display. Install the new display into the rubber gasket into the back half of the camera. Insert the ribbon cable into the mother board's black connector and press down on the panel to lock the cable into place. Lay the rear half of the camera face down on the table (rear buttons facing down) and place the front half of the camera over top of the rear half. This will allow you to put the camera back together and help prevent the new LCD screen from falling back out. The LCD screen has pads attached to the surface behind it. When you reinstall the front half of the camera, those pads help hold the LCD screen in place with pressure from the motherboard. Replace all of the screws. If you did it correctly, the camera will operate like new. Last word of advice. Buy a padded hard shell case for this camera. These cameras are well known for LCD screen failures due to shocks and drops.
Good Luck!
- Jim
Jan 25, 2008 | Kodak EasyShare V603 Digital Camera
Casio Exilim 1050 broken screen
If it is simply a crack and other wize still OK
Best way is to go to a photo store and purchase lcd screen protector film or heavy duty transparent repair tape[camping store]
Taking a camera apart is no easy task unless your are used to fine instruments and reassembling them ditto
Buying spares new is a nono usually .Secondhand -well its a gamble isn't it?
If you can find the model you want and if it is in good nick.
Jan 07, 2008 | Kodak EasyShare V1003 Digital Camera
Polaroid i631 Digital Camera Logo
76 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
