Question about Dryers
Kenmore Oasis Dryer Model 7704 F 2 Error
I just returned from vacation to find that my dryer is not working. When I follow the normal start process once the "start" button is pushed the F 2 error flashes and the dryer will not run.
The Dryer was purchased in Sept 2006 so is just out of warranty and Sears will not offer any assistance over the phone.
Does anyone have any suggestions?
Thanks,
Geo
  • Sadly Susan Dec 31, 2007
    Kenmore Oasis dryer won't start . Tech came out and says it us a user interface board at a cost of $295 to repair.
After haveing read through some blogs here, the F02 code is either a short in the interface board or the ribbon is loose. I'm having a similiar problem, mine started beeping all by itself, when it was not even turned on, am presently running a load through and is doing fine so far, also, I had unplugged the dryer last night, not sure if that helped but so far is working properly, other advise I read was to make sure the ribbon was seated properly, next step for me will be to do that then order the part (?), sorry I can't be more helpful
Posted on Nov 24, 2007
How do I set the time on adrenaline digital watch?
two standard digi watch setting processes
1 press and hold mode button until time start to flash
then use the start button to move between hour , minute sec etc and the reset to adjust the time, when correct time set press hold once more to return to normal time.
2 press hold button one push at a time on the third push the time should start flashing , follow the above processes.
Mar 04, 2015 | Freestyle Adrenaline watch
I need to know how to set a h005 haffstreuner watch after battery change
This is for the HA005:
B) SETTING THE TIME
1. Pull the crown out to the 2nd position.
2. Turn the crown to set hour and minute hands.
3. When the crown is pushed back to the normal position, small second hand begins to run.
C) SETTING THE DATE
1. Pull the crown out to the 1st position.
2. Turn the crown clockwise to set the date.
*If the date is set between the hours of around 9:00 PM and 1:00 AM, the date may not change on
the following day.
3. After the date has been set, push the crown back to the normal position.
E) CHRONOGRAPH RESET (INCL. AFTER REPLACING BATTERY)
This procedure shoud be performed when the chronograph second hand does not return to zero position
after the chronograph has been reset, and including after the battery has been replaced.
2. Press button "A" to set the chronograph second hand to the zero position. The chronograph hand can
be advanced rapidly by continuously pressing button "A".
3. Once the hand have been zeroed, return the crown to the normal position.
* Do not push crown to normal position while the chronograph second hand returns to zero position.It
stops on the way when crown are returned to normal position and its position is recognized as zero
position.
May 25, 2014 | Hitachi HA00593 Power Supply
2004 camry ac light blinking and throws hot air. Suggestions?
My 2003 Toyota Camry AC often starts blowing hot air and the AC light starts blinking. I don't know why the following process works, but it does. Using the temp selector (left) reduce the temperature all the way down to Max Cold and then push the Auto button. It will start blowing out very cold air. After a little while push the temp selector to the desired temperature.
Apr 03, 2012 | Cars & Trucks
I just bought the armani ar0142 but the second hand doesn't work. Is this normal?
Take closer look and you will notice the small seconds hand which should be working. The dig seconds hand actually is chronometer hand and will work only when the chronometer function is engaged. Push the top button once=chronometer will start. Push the top button once more=chronometer will stop. Push the bottom button once=chronometer will return to zero. Rate me, please.
May 18, 2010 | Giorgio Armani Emporio Armani Black/Steel...
Dryer won't stay on
http://136.166.4.200/contents/Laundry/DLE8377/DLE8377_Service_Manual.pdf
Hi, above is a service manual, download, this has all troubleshooting and repair advice. Follow the troubleshooting procedure and you will soon isolate your problem, and hopefully fix.
May 12, 2010 | Whirlpool ET8CHEXSQ Dryer
The timer was a little tough to get started sometimes, I'd have to pull the knob out and push it back in several times before it would start.
The start switch is going out. You will have to replace the whole timer on this model. Check the first 2 numbers of your serial number if it is 10 - 15 the part number is 33002855 if the first 2 numbers are 16 or greater the part number is 33002803. Please rate me after reading.
Dec 13, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
1985.5 PORSCHE 944 digital clock (changing time)
There are three buttons, let's call them 1, 2, and 3, from left to right.
Clock
Time setting
A. 12 AM, PM or 24.00 h
With the clock in the time readout mode, keep
button (2) depressed for 4 seconds -12 AM, PM
or 24.00 flashing. After pushing button (1), either
a 12-hour (AM + PM) or a 24-hour setting
program can be selected. If you only want to
change the display mode, push button (3). The
clock then returns to its normal timekeeping
function.
B. Hours
Push button (2) a second time - hour display
flashes. Set hour by pushing button (1). After
pushing button (3)*, the clock returns to the time
readout mode with new hour setting.
C. Minutes
Push button (2) once more - minute display
flashes. Set minute by pushing button (1). Upon
pushing button (3)*, the clock is started -
accurate to within 1 second.
Stop watch function
The stop watch can only be set in motion if the
clock is in its normal timekeeping mode and not
during setting operations.
A. Push button (3) - 00:00 display appears;
B. Push button (1) - stop watch is on;
C. Push button (1) a second time - watch stops.
(Additional times can be added by pushing button
(1) again - stop watch keeps running. Push button
(1) once more to stop timing.)
D. Push button (2) - 00:00 display appears;
E. Push button (3) - normal timekeeping mode.
If button (3) is pushed during operation A and
B, the setting procedure must be restarted
Apr 17, 2009 | 1985 Porsche 944
DECADE WATCH HAS NO SETTINGS MANUAL
If your Decade watch is like mine it has 4 push buttons (10, 2, 4 and 8 "o'clock" positions respectively; and one pull and turn stem (at 3 o'clock position) -
For the purpose of setting the watch and functions mentally label the push buttons as follows:
10 o'clock position "A"
8 o'clock position "B"
2 o'clock position "C"
4 o'clock position "D"
NORMAL TIME SETTING
1) In normal time readout press B (3x) to get to normal time setting mode: "SEC" will start flashing, press C for synchronization
2) Press D once: "MIN" will be flashing, press C to advance
3) Press D once: "HOUR" will be flashing, press C to advance ("A" is for am, "P" is for pm, "H" is for 24 Hour format)
4) Press D once: "DATE" should be flashing, press C to advance
5) Press D once: "MONTH" should be flashing, press C to advance
6) Press D once: "DAY OF WEEK" should be flashing, press C to advance
7) Press B once: Setting is completed, return to normal time readout
ALARM TIMES SETTING
1) In normal time readout press B (2x): Alarm time "HOUR" should be flashing, press C to advance
2) Press D once: Alarm time "MIN" should be flashing, press C to advance
3) Press B once: Setting is completed, return to normal time readout
ALARM FUNCTION
1) In normal time readout press C and D simultaneously: Alarm signal should appear
2) In normal time readout disarm alarm by pressing C and D simultaneously: alarm signal should disappear
Note: Alarm (when activated) will stop itself after 1 minute; or can be silenced by pressing D or press C to snooze for 5 minutes (operates for 1 hour)
CHIME
1) In normal time readout press D and B simultaneously: Chime signal should appear
2) In normal time readout disarm chime by pressing C and D simultaneously: alarm signal should disappear
CHRONOGRAPH (STOP WATCH FUNCTION)
1) In normal time readout press B once to get into "CHRONO" mode: press C for to start counting event -
While in Chrono mode there are two options
a) During a counting event: press C to stop counting, press D to clear and reset stopwatch to 0:00
b) During a counting event: press D to see a "split" time (IE first leg of a relay time is shown while the counting event continues, press D again to return to running counting event; press C at end of event, press D to reset stopwatch to 0:00
2) press B to return to normal time mode
Mar 27, 2009 | JCPenney Watches
Electric Kenmore Dryer
possible bad timer but first ck thermal fuse ..if top mount filter remove back fuse is small white object on blower housing ..if door mount filter remove bottom panel remove lint screen remove 2 screws each side holing lint screen housing in place fuse is behind it ..if fuse cks good suspect timer ..
Sep 07, 2008 | Kenmore 62602 Electric Dryer
Dryer turns off as soon as I release the Start Button
there is a relay that is not doing its job...it is supposed to "take over" as the button holder, but the relay has problems. find the relay by following all wires to/from start switch. Once found, read it looking for letters "NO" (normally open). If 2 of those wires traced earlier go to NO connections, first see if the relay has 2 more unused NO connectors. If it does, swap the wires over to those. If not, replace the relay.
Nov 28, 2007 | Kenmore 63942 Dryer
Dryers Logo
336 people viewed this question
Top Dryers Experts
