Question about Whirlpool Washing Machines
Out flow in wall is backing up
Out flow from cloths washing machine is backing up and overflowing into laundry room?
  • Whirlpool Master
  • 3,463 Answers
You neeed to dismantle waste pipe assy if it goes outside and clear obstruction in same.
Please rate my solution.
Thanks.
Posted on Jul 22, 2009
The machine is doing yellow spots on several clothes and it is clean from inside and nothing could cause rust stains inside
Search Results
    Washing Machine Stains: Possible Causes And Cures
    www.stain-removal-101.com/washing-machine-stains.html
    Have you ever experienced washing machine stains, where your machine is the culprit for ... Just never put clothes in when doing this as it will discolor them. ... I get largeyellow spots on my Battenberg linens after washing, or maybe they ...
    Removing Yellow Stains from Washing ' Clorox
    https://www.clorox.com/...laundry/removing-yello...
    The Clorox CompanyFeb 4, 2010 - I do my laundry at a neighborhood laundry that has. ... into the machinefor the wash cycle but still get the yellow spots. ... Since you diluted it in a gallon of water, the yellow spots/splotches should not be from the liquid bleach. ... Rinse and air-dry to see if it has any effect before doing a large number of items ...
    Weird yellow spots on whites - Home Forums - GardenWeb
    ths.gardenweb.com > Home Forums > Laundry Room
    Jul 27, 2010 - I wash on warm/cold using powdered Tide and nothing else. The laundryemerges from the machine with yellow spots in places. Not pale ...
    Mysterious yellow spots on clothes, bedding, etc ..
Feb 03, 2016 | Washing Machines
Our washer drains and overflows... we have had the lines checked and any clogs removed less than 24 hours ago. Doing laundry tonight and it overflowed again. When cleaning up all the water we tipped t
If the drained water is overflowing at the drain in or on the wall, that drain may be too small in diameter for the volume of water being pumped out of the washer. Because it is pumped out, it is generally moving faster than water that would be drained by gravity. ALSO very important is the height of the drain connection. I had that problem and had to extend the drain pipe about a foot vertically. The entry point of the pipe can be too close to the P trap, which slows down the flow as it changes the direction of flow. If there is not sufficient volume above the trap, it can back up and overflow due to slower flow through the trap.
Aug 15, 2014 | Washing Machines
Sewage backing up into laundry room when we use our dishwasher. We have a septic tank. Both toilets flush fine, and no back up in tub
The drain leaving the laundry room going to the main needs to be cleaned. The first thing you can try is what is called a product called Drain King . This is connected to a garden hose and inserted into a drain where the p-trap is removed from the wall When the garden hose is turned on full blast it will try pushing out the clog You should hear it pulsate first slowly then more quickly as the clog is washed away.he water flowing with Finally you should hear water flowing freely. it helps to use warm water if possible. If that won't work the drain will need to be snaked , Turn off the hose and remove the Drain King by loosening the hose connection Then follow that pipe downhill toward the main drain, and look for a clean-out plug. You can loosen the plug SLOWLY, have a bucket, mop, and rags ready and wear old clothes. Place the bucket under the clean-out plug if possible while slowly removing it Water will come out unless the clog is between the laundry sink and the clean-out. If water comes out when the clean-out plug is removed place your snake drain cleaning device into the clean-out and run until the clog is cleared. then run water through it for a while to wash away any residual residue. Put everything back together and test for leaks.
Jul 30, 2014 | Home
Hot point wm vlsr1090g3ww leaking
Is this a top loading machine? Are you seeing water flowing through the overflow or are you thinking that may be your problem? Asking because I've personally never had a prob with that tube. Leaks have always been attributed to other causes. Top loading hotpoint leaks are usually caused by a leaking transmission seal, water drain pump, inlet valve or faulty pressure switch. Need more info sorry.
Dec 08, 2012 | Washing Machines
Error code Unb: After the last rinse finishes, spinning fails completely due to unbalanced of the laundry (What does this mean) and How do I clear the error. Machine does not spin the clothes.Every thing...
I have had the same problem with the same model and rang up the help line to be told that the machine cannot sense the clothes in the drum. I tilted the machine forward and this worked for a while, sometimes i have to unplug at the wall so there is no electricity flowing through the machine for an hour and it resets itself,. Its not adequate but it works.
Sep 02, 2010 | Haier Washing Machines
My washing machine keeps getting water in it after the cycle is over. This morning I came in and my empty washer was filled with water and had overflowed onto the floor. Help! There are also times when...
mine also remains wet and soggy, even after the spin cycle. However, I have not, as of yet, (and hopefully won't) begin having overflow problems.
Mine is jumping around the laundry room - as though in an unbalanced cycle. We discovered that one of the "feet" that the washer stands on needs to be adjusted, upward or down, so that the washer stands balanced and evenly. The "foot" does not make contact, and when we turn it to change its height, it just goes in circles without changing height.
Mar 09, 2010 | Whirlpool Washing Machines
My Whirlpool Cabrio washer is backing up into and overflowing my toilet every once in a while during the spin cylce. But today, the washer was not running and the toilet overflowed. The toilet is located...
Your problem is not with the washing machine. I suspect that the drain line for your toilet is obstructed further down the line than your snake can reach. If you have a clean out riser to your sewer system, flush the toilet while someone else is watching the flow past the clean out. I would say that renting a sewer line snake at a tool rental like Home Depot would solve your problem. Good luck
Mar 05, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
Maytag a112 manual on how to add bleach AND fabric softener
Hi
Choosing Your Detergent, Bleach, and Fabric Softener..
Learn what the different items you need to wash your laundry.
Liquid Laundry Detergent and Fabric Softeners
When using liquid laundry detergent, you do not want to poor it directly on your laundry. The dyes in the liquid laundry soap could stain your clothing. You will want to start your washing machine and add the liquid laundry soap while the water is filling the washing machine.
You then can add your laundry once you have about and eighth of the washing machine tub filled. This will ensure your laundry doesn't become stained by the detergent. You should only add the amount that is poured into the cup to the fill line. When you add more, you could find yourself wading through mounds of bubbles overflowing from your washing machine.
The same reasoning applies to liquid fabric softeners. However, liquid fabric softeners are added to the washing cycle after the initial washing cycle is finished. You will want to add the fabric softener once the washing machine has filled with water and started to agitate. This keeps the fabric softener from touching the laundry and will work it into your clothing better.
Powdered Laundry Detergent
You will want to add one cup of loose laundry detergent to your washing machine in the same manner you would do the liquid laundry detergent. By doing this, the powdered laundry detergent will dissolve easier.
Bleach
When adding bleach to your laundry, there is a small triangular cup in the corner of your washing machine. By adding one cup of bleach into that dispenser, the bleach will be added to the laundry at a precise time during the wash cycle.
Setting Your Washing Machine
Most washing machines have three or four cycles. For instance, the Maytag Washer I have has four cycles, regular, permanent press, delicate, and soak.
Regular Washing Cycle
The regular cycle is used for the following types of clothes and other apparel:
• Jeans
• Towels
• Blankets
• Sheets
• Quilts
• Bedspreads
The soil types for this cycle are heavy, normal, and light. This means clothes or other articles that are lightly too heavily soiled should be washed in this cycle. This is due to the washing cycles can be set from a minimum of eight to fourteen minutes maximum. You can use all three of the water temperatures in this cycle.
1Permanent Press Washing Cycle
The permanent press washing cycle is used on the clothes that may or may not need to be ironed.
Such as:
• Blouses
• Shirts
• T-shirts
• Under garments. This would be your unmentionables and socks.
• Jackets
• Sheets
• Baby Clothing
The soil types for this wash cycle are normal and light. The washing times for the permanent press cycle are six minutes to ten minutes. You can use all three washing temperature modes for this cycle as well.
Delicate Washing Cycle
The delicate washing cycle is normally used for sweaters, cotton, silks, and other fabrics that need to be washed with care.
The soil types for the delicate cycle are normal and light. The washing times for the delicate cycle are four and six minutes. It is best to wash your delicate clothes in warm or cold water. Always wash clothing that is more than forty percent cotton in cold water to prevent shrinking.
Soak Washing Cycle
The soak cycle would be used for heavily soiled clothing, such as, football and baseball uniforms. This will help rid the uniforms of caked on mud and grass stains.
You can also use this cycle if you wish to only bleach your white's once a week or once a month with bleach.
Washing Your Laundry
Choose the cycle you need for your laundry. Add the laundry detergent, fabric softener, and bleach (remember regular liquid bleach is for white clothes only.) Start the washing machine and let fill to dissolve the dry detergent or to mix in the liquid detergent.
Now add your clothes to the washing machine. Clothes the lid so the washing machine will continue to wash your clothes.
If you are using a Laundromat, put your clothes in the washing area and shut the lid or door. Add your detergent and other cleaning items in the correct compartments. Put in the correct amount of change so the washer will start.
Thanks for contacting fixya.com
Nov 13, 2009 | Maytag Washing Machines
How do I removethe lint? Clothes are coming out with fluff...
Sorry for the obvious.....
Fluff on the cloths is from the lint trap not capturing it from the air flow.
Air is passed into the clothes from the laundry room. It is heated and then passed over the clothes... then filtered air is forwarded to the outside exhaust.
If you are seeing lint on your clothes, then the air coming in from your laundry area is not lint free.
1. check the back/bottom of the dryer for lint accumulation.
2. Remove the lint trap and clean out the duct work.
3. Inspect all the flooring and areas around the dryer for dust/lint - and clean any that you find.
I believe that you will then have a clean and dry load.
The proceedure of cleaning described above should be repeated every 6 months or so....
-Jim
Nov 05, 2009 | Roper RAX4232KQ Top Load Washer
Condensation is forming on the walls when I use my clothes dryer
Simpson may have a kit available for accomplishing this. Also, your dryer may have several optional ways of venting.
Mar 27, 2017 | Dryers
Washing Machines Logo
27 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
