The power rating of the equipment that is plugged into the battery-supported outlets must not exceed the UPS capacity. To make sure it doesn't, add together the power rating for each piece of equipment and compare the total requirements to the capacity of the unit, which is listed a) on the bottom of the UPS, or b) on the Specification tab on Tripp Lite's product page. If the total power draw of the connected equipment exceeds the capacity of the UPS, the load MUST be reduced for the UPS to perform properly.
If this is NOT the case, disconnect the unit from the wall outlet and check the battery voltage- it may be at its end-of-life cycle. It may not be holding the charge or not take a charge anymore.
Testimonial: "Thank you. Tremendously helpful answer. I'm saving it to file in case I need to refer to it again. Thanks again, Norm"
