Question about Canon BubbleJet i560 InkJet Printer
I have a canon i560. Had no problems, but now it does not respond to computer commands. Even cleaning or test page. a yellow light blinks 7 yellows/1 green, repeatedly. all tanks have ink What to do?
SOURCE:
  • 59 Answers
SOURCE: Magenta printing as yellow
Well, first off, are the alignment, and nozzle check sheets looking good? If not, then work on that. If so, then we have a problem. Try creating a test sheet in Word. Make red, yellow blue & black text and see if anything else prints wrong. Get back to me!
Posted on Jun 19, 2007
jimmynuetron
  • 24 Answers
SOURCE: Missing Colors
This is a simple problem just reset your printer's color management settings!!!!!!!!!!!!!!!!!!!! :-)
Posted on Oct 24, 2007
SOURCE: Canon i560 printer
I have similar problem. I found this solution that may help you. My problem insists tho.
>>> 5 flashes indicates a faulty printhead or possibly a problem with the p/head contacts. Try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt.
If that doesn't work it may be that the waste ink tank is full. Try this ...
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Posted on Aug 12, 2008
komguy
  • 2306 Answers
SOURCE: Print head problems 7 yellow lights 1 green light, how do I fix
That's not a printhead problem, it's saying that the waste ink absorber is full. You need to have them replaced at a shop where they can also reset the waste ink counter.
Posted on Aug 24, 2009
I have got Canon i560 printer but not recieving print order the software is loaded what is the solution ?
Try i560 Reset Procedures for Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
Pl let me know if this works
Nov 12, 2010 | Office Equipment & Supplies
The yellow light is blinking intermitentli
Hi Worth tryin it may do the trick for you
Problem for Canon BubbleJet i560 InkJet
The waste ink is in the inside of your printer you need to get at it to clean out,
It may be all screwed down so you need to open all up or get a shop to do it for you.
It not an easy job but maybe you are handy with a screwdriver, it can be messy job.
But after this, you will have to reset the waist ink counter or it will still not work,
But but but but you can always try this to reset it first and clean it out again some time.
Canon Reset waste ink counter
1. Turn off printer
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 25, 2010 | Canon BubbleJet i560 InkJet Printer
Yellow light keeps coming on and there is ink and paper. I reset and I get a Operator error. Press printer's RESUME button. If this doesn't clear the error, cancel printing and turn the printer off and...
Hi
1. Turn off printer
Jan 21, 2010 | Canon BubbleJet i560 InkJet Printer
Canon i560. It stopped printing when i changed black ink cartridge. None of the maintenance functions work. They all show the same message: Press resume, then turn printer off & back on. 1st green...
Blinking 5 times in orange means print head not detected by the printer. You may try following procedure: remove and reinstall the print head. If the problem not solve find good print head to compare. More information please check below link
Blinking in orange 5 times
Oct 18, 2009 | Canon BubbleJet i560 InkJet Printer
I have a Cannon i560 and I am getting 5 blinking yellow light the green and then it repeats. All indications is that I need a new print head. I want to be sure this is it before buying the print head.
5 blinking yellow or 7 blinking yellow in canon printers means you need to replace the ink cartridge or head with a new one. If you want to be sure, then take the print head and see if there is any burned area or damaged near the head and sometimes it is very small like a needle puncture. if there is, you need to buy a new one. if not, try to clean the head with 96% alcohol, let them dry before you try to put it back.
Sep 14, 2009 | Canon BubbleJet i560 InkJet Printer
Yellow light blinks 7 times with 1 long green blink
Jennifer, According to an answer by kev1952 on 19 Sept, to my similar error condition ( "repeating sequence of 7 orange and 1 longer green flash of power LED" ) in a Canon i550 printer, and assuming that what you called yellow I called orange, then you too may have a printhead fault. kev1952 recommended to try to get it cleaned and checked at an ink refilling specialist service.
gp26, on 21 Sept 2009
Aug 17, 2009 | Canon PIXMA iP1600 Printer
My old canon S400 is not printing anything. Trying maintenance checks but still will not print pages. The on off light flashes yellow 8 times follwed by 1 green light flash. What is the problem?
1. Turn off printer
All the best Pineworks
May 15, 2009 | Canon S400 InkJet Printer
I560s Won't Print -- operator error -- can't fix
This sounds familiar; try holding the rest button for an extended time.
May not work but won't hurt anything either.
May 28, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Canon i560 printer
1. Turn off printer
May 28, 2008 | Canon BubbleJet i560 InkJet Printer
Canon BubbleJet i560 InkJet Printer Logo
60 people viewed this question
Clive
Clive
old marine
old marine
